Bonjour.
je rencontre le même problème sur un Raspberry PI zéro et sur un Raspberry PI3B, cela fait plusieurs mois que tout fonctionnait, j’ai voulu faire la mise à jour de l’antenne et depuis hier soir, les deux bloquent à ce niveau:
[2024-11-19 05:35:37] *************************************
[2024-11-19 05:35:37] * Launch install of dependencies *
[2024-11-19 05:35:38] *************************************
[2024-11-19 05:35:38] == Version Debian:11
[2024-11-19 05:35:38] == Version Python:3.9.2
[2024-11-19 05:35:41] Reading package lists...
[2024-11-19 05:35:42] Building dependency tree...
[2024-11-19 05:35:42] Reading state information...
[2024-11-19 05:35:43] curl is already the newest version (7.74.0-1.3+deb11u14).
[2024-11-19 05:35:43] 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 2 100 2 0 0 6 0 --:--:-- --:--:-- --:--:-- 6
[2024-11-19 05:35:44] Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
[2024-11-19 05:35:44] Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
[2024-11-19 05:35:46] Fetched 15.0 kB in 2s (8,903 B/s)
[2024-11-19 05:35:54] Reading package lists...
[2024-11-19 05:35:54] ********************************
[2024-11-19 05:35:54] * Install dependencies & venv *
100 2 100 2 0 0 5 0 --:--:-- --:--:-- --:--:-- 5
[2024-11-19 05:35:55] Reading package lists...
[2024-11-19 05:35:56] Building dependency tree...
[2024-11-19 05:35:56] Reading state information...
[2024-11-19 05:35:58] logrotate is already the newest version (3.18.0-2+deb11u2).
[2024-11-19 05:35:58] python3 is already the newest version (3.9.2-3).
[2024-11-19 05:35:58] python3-venv is already the newest version (3.9.2-3).
[2024-11-19 05:35:58] python3-pip is already the newest version (20.3.4-4+rpt1+deb11u1).
[2024-11-19 05:35:58] 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[2024-11-19 05:35:59] Reading package lists...
[2024-11-19 05:35:59] Building dependency tree...
[2024-11-19 05:35:59] Reading state information...
[2024-11-19 05:36:01] 0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
[2024-11-19 05:36:01] Need to get 845 kB of archives.
[2024-11-19 05:36:01] After this operation, 0 B of additional disk space will be used.
[2024-11-19 05:36:01] Get:1 http://archive.raspberrypi.org/debian bullseye/main armhf bluez armhf 5.55-3.1+rpt2+deb11u2 [845 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
[2024-11-19 05:36:04] Fetched 845 kB in 0s (3,675 kB/s)
[2024-11-19 05:36:05] (Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 44806 files and directories currently installed.)
[2024-11-19 05:36:05] Preparing to unpack .../bluez_5.55-3.1+rpt2+deb11u2_armhf.deb ...
[2024-11-19 05:36:05] Unpacking bluez (5.55-3.1+rpt2+deb11u2) over (5.55-3.1+rpt2+deb11u2) ...
[2024-11-19 05:36:06] Setting up bluez (5.55-3.1+rpt2+deb11u2) ...
[2024-11-19 05:36:12] Processing triggers for man-db (2.9.4-2) ...
[2024-11-19 05:36:13] Processing triggers for dbus (1.12.28-0+deb11u1) ...
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: pip in /opt/TheengsGateway/lib/python3.9/site-packages (24.3.1)
Requirement already satisfied: setuptools in /opt/TheengsGateway/lib/python3.9/site-packages (75.5.0)
[2024-11-19 05:36:41] ****************************
[2024-11-19 05:36:41] * Install TheengsGateway *
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0```
L’installation est « en cours », ces deux messages apparaissent :
2024-11-19 06:43:33 tgw Erreur sur tgw::pullGatewayVersion() : Veuillez d’abord installer l’antenne. Log tgw
2024-11-19 06:43:33 tgw Veuillez d’abord installer l’antenne. Log tgw
et ensuite, l’installation passe en NOK.
Raspberry débian bullseye lite, 32 bits, mise à jour ok et j’ai également refait une installation pour être sur mais sans succès.
