Fixes
| Category | Description |
| BLUFI | Fix SSID return by @1technophile in #2108 |
| BLUFI | Fix max buffer size for BluFi by @1technophile in #1972 |
| BROKER | Fix BT start by @1technophile in #2112 |
| BT | Fix crash when sending multiple BT commands at the same time by @1technophile in #2059 |
| BT | Fix BT command triggering a stack trace due to conflict by @1technophile in #2104 |
| CI | Fix development deployment by @1technophile in #1866 |
| DISC | Fix empty topic publication by @1technophile in #1858 |
| DISC | Fix via device discovery when using a secondary module by @1technophile in #2077 |
| DISC | Fix device name discovery by @1technophile in #2093 |
| DOCS | Fix sponsor button by @1technophile in #1859 |
| DOCS | Fix config.js for sitemap by @1technophile in #1869 |
| DOCS | Fix image sizing and path by @1technophile in #1926 |
| DOCS | Fix capitalization of rssithreshold in documentation by @kamaradclimber in #1993 |
| DOCS | Fix image path by @1technophile in #2006 |
| HCSR501 | Fix not logging by @diepeterpan in #1897 |
| IR | Fix errors noticed when sending IR codes by @GRMrGecko in #1991 |
| LORA | Fix message without json not being transmitted by @1technophile in #1875 |
| LORA | Fix save function for parameters that are not frequency by @1technophile in #1987 |
| ONBOARD | Fix failsafe mode by @1technophile in #2080 |
| RF | Fix Mqtt Device Trigger announcement message by @Odyno in #2091 |
| SYS | Avoid queue overloading at start by @1technophile in #2114 |
| SYS | Fix wrong connection index record during onboarding by @1technophile in #1961 |
| SYS | Fix default connection by @1technophile in #1966 |
| SYS | Fix Ethernet network check on MQTT failure by @1technophile in #2013 |
| SYS | Fix disconnection detection by @1technophile in #2031 |
| SYS | Fixed data corruption associated with jsonQueue enqueueing and dequeuing by @puterboy in #2035 |
| SYS | Fix connection validation on unknown indexes and improve erase method by @1technophile in #2075 |
| SYS | Fix erase function for ESP8266 by @1technophile in #2101 |
| SYS | Fix ESP8266 discovery publications by @1technophile in #2100 |
| SYS | Fix webUI OTA update free memory by @1technophile in #2103 |
| SYS | Fix capacity to onboard ethernet board without WiFi AP by @1technophile in #2106 |
| WEBUI | Fix web serial console by @1technophile in #1863 |
| WEBUI | Fix index by @1technophile in #1992 |
New Contributors
- @j-paulus made their first contribution in #1847
- @simowilso made their first contribution in #1884
- @maxnowack made their first contribution in #1898
- @ivankravets made their first contribution in #1917
- @ayetee made their first contribution in #1915
- @evlas made their first contribution in #1941
- @riegelbrau made their first contribution in #1960
- @mlesniew made their first contribution in #1954
- @GRMrGecko made their first contribution in #1991
- @puterboy made their first contribution in #2007
- @peshovec made their first contribution in #2072
- @mhaberler made their first contribution in #2088
- @JamiePhonic made their first contribution in #2057
Full Changelog: v1.7.0…v1.8.0
