Avant de jeter la clé Zigbee à la poubelle je sollicite la communauté pour conseils.
Depuis 1 semaine la communication était très instable avec des « endormissements » intempestifs de mes modules Xiaomi. Et depuis hier, impossible d’inclure quoi que ce soit, aucun module n’est capté par la clé.
Est-il possible qu’elle soit « dead »?
Ci dessous le log pendant la tentative d’inclusion.
[2022-04-24 13:35:40]DEBUG : Application frame 170 (getValue) received: b'0001f9'
[2022-04-24 13:35:40]DEBUG : Free buffers status EzspStatus.SUCCESS, value: 249
[2022-04-24 13:35:40]DEBUG : ezsp_counters: [MAC_RX_BROADCAST = 17, MAC_TX_BROADCAST = 113, MAC_RX_UNICAST = 0, MAC_TX_UNICAST_SUCCESS = 0, MAC_TX_UNICAST_RETRY = 0, MAC_TX_UNICAST_FAILED = 17, APS_DATA_RX_BROADCAST = 2, APS_DATA_TX_BROADCAST = 2, APS_DATA_RX_UNICAST = 0, APS_DATA_TX_UNICAST_SUCCESS = 0, APS_DATA_TX_UNICAST_RETRY = 0, APS_DATA_TX_UNICAST_FAILED = 0, ROUTE_DISCOVERY_INITIATED = 0, NEIGHBOR_ADDED = 0, NEIGHBOR_REMOVED = 0, NEIGHBOR_STALE = 0, JOIN_INDICATION = 0, CHILD_REMOVED = 0, ASH_OVERFLOW_ERROR = 0, ASH_FRAMING_ERROR = 0, ASH_OVERRUN_ERROR = 0, NWK_FRAME_COUNTER_FAILURE = 0, APS_FRAME_COUNTER_FAILURE = 0, UTILITY = 0, APS_LINK_KEY_NOT_AUTHORIZED = 0, NWK_DECRYPTION_FAILURE = 0, APS_DECRYPTION_FAILURE = 0, ALLOCATE_PACKET_BUFFER_FAILURE = 0, RELAYED_UNICAST = 0, PHY_TO_MAC_QUEUE_LIMIT_REACHED = 0, PACKET_VALIDATE_LIBRARY_DROPPED_COUNT = 0, TYPE_NWK_RETRY_OVERFLOW = 0, PHY_CCA_FAIL_COUNT = 130, BROADCAST_TABLE_FULL = 0, PTA_LO_PRI_REQUESTED = 0, PTA_HI_PRI_REQUESTED = 0, PTA_LO_PRI_DENIED = 0, PTA_HI_PRI_DENIED = 0, PTA_LO_PRI_TX_ABORTED = 0, PTA_HI_PRI_TX_ABORTED = 0, ADDRESS_CONFLICT_SENT = 0, EZSP_FREE_BUFFERS = 249]
[2022-04-24 13:35:50]DEBUG : Send command readCounters: ()
[2022-04-24 13:35:50]DEBUG : Sending: b'03dd21a9a52ad33c7e'
[2022-04-24 13:35:50]DEBUG : Data frame: b'31dda1a9a52a00b228944a25aa559249894e25abefce678bfdc66389fc7e3fa7ebcdde6f8fffc7dbd5d2698c4623a9ec763ba5ea758241984c2613b1e070381c0e07bbe5ca650c459a4d9e4f9ff7c3d9d46a35a2519048248d467e'
[2022-04-24 13:35:50]DEBUG : Sending: b'8430fc7e'
[2022-04-24 13:35:50]DEBUG : Application frame 241 (readCounters) received: b'15007100000000000000150002000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000860000000000000000000000000000000000'
[2022-04-24 13:35:50]DEBUG : Send command getValue: (,)
[2022-04-24 13:35:50]DEBUG : Sending: b'14e221a9fe2a16df667e'
[2022-04-24 13:35:50]DEBUG : Data frame: b'42e2a1a9fe2a15b3a053cb7e'
[2022-04-24 13:35:50]DEBUG : Sending: b'8520dd7e'
[2022-04-24 13:35:50]DEBUG : Application frame 170 (getValue) received: b'0001f9'
[2022-04-24 13:35:50]DEBUG : Free buffers status EzspStatus.SUCCESS, value: 249
[2022-04-24 13:35:50]DEBUG : ezsp_counters: [MAC_RX_BROADCAST = 21, MAC_TX_BROADCAST = 113, MAC_RX_UNICAST = 0, MAC_TX_UNICAST_SUCCESS = 0, MAC_TX_UNICAST_RETRY = 0, MAC_TX_UNICAST_FAILED = 21, APS_DATA_RX_BROADCAST = 2, APS_DATA_TX_BROADCAST = 2, APS_DATA_RX_UNICAST = 0, APS_DATA_TX_UNICAST_SUCCESS = 0, APS_DATA_TX_UNICAST_RETRY = 0, APS_DATA_TX_UNICAST_FAILED = 0, ROUTE_DISCOVERY_INITIATED = 0, NEIGHBOR_ADDED = 0, NEIGHBOR_REMOVED = 0, NEIGHBOR_STALE = 0, JOIN_INDICATION = 0, CHILD_REMOVED = 0, ASH_OVERFLOW_ERROR = 0, ASH_FRAMING_ERROR = 0, ASH_OVERRUN_ERROR = 0, NWK_FRAME_COUNTER_FAILURE = 0, APS_FRAME_COUNTER_FAILURE = 0, UTILITY = 0, APS_LINK_KEY_NOT_AUTHORIZED = 0, NWK_DECRYPTION_FAILURE = 0, APS_DECRYPTION_FAILURE = 0, ALLOCATE_PACKET_BUFFER_FAILURE = 0, RELAYED_UNICAST = 0, PHY_TO_MAC_QUEUE_LIMIT_REACHED = 0, PACKET_VALIDATE_LIBRARY_DROPPED_COUNT = 0, TYPE_NWK_RETRY_OVERFLOW = 0, PHY_CCA_FAIL_COUNT = 134, BROADCAST_TABLE_FULL = 0, PTA_LO_PRI_REQUESTED = 0, PTA_HI_PRI_REQUESTED = 0, PTA_LO_PRI_DENIED = 0, PTA_HI_PRI_DENIED = 0, PTA_LO_PRI_TX_ABORTED = 0, PTA_HI_PRI_TX_ABORTED = 0, ADDRESS_CONFLICT_SENT = 0, EZSP_FREE_BUFFERS = 249]
[2022-04-24 13:36:00]DEBUG : Send command readCounters: ()
[2022-04-24 13:36:00]DEBUG : Sending: b'25e321a9a52aa8937e'
[2022-04-24 13:36:00]DEBUG : Data frame: b'53e3a1a9a52a0cb22b944a25aa559249854e25abefce678bfdc66389fc7e3fa7ebcdde6f8fffc7dbd5d2698c4623a9ec763ba5ea758241984c2613b1e070381c0e07bbe5ca6501459a4d9e4f9ff7c3d9d46a35a25190482441657e'
[2022-04-24 13:36:00]DEBUG : Sending: b'8610be7e'
[2022-04-24 13:36:00]DEBUG : Application frame 241 (readCounters) received: b'190072000000000000001900020002000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000008b0000000000000000000000000000000000'
[2022-04-24 13:36:00]DEBUG : Send command getValue: (,)
[2022-04-24 13:36:00]DEBUG : Sending: b'36e021a9fe2a165a337e'
[2022-04-24 13:36:00]DEBUG : Data frame: b'64e0a1a9fe2a15b3a021197e'
[2022-04-24 13:36:00]DEBUG : Sending: b'87009f7e'
[2022-04-24 13:36:00]DEBUG : Application frame 170 (getValue) received: b'0001f9'
[2022-04-24 13:36:00]DEBUG : Free buffers status EzspStatus.SUCCESS, value: 249
[2022-04-24 13:36:00]DEBUG : ezsp_counters: [MAC_RX_BROADCAST = 25, MAC_TX_BROADCAST = 114, MAC_RX_UNICAST = 0, MAC_TX_UNICAST_SUCCESS = 0, MAC_TX_UNICAST_RETRY = 0, MAC_TX_UNICAST_FAILED = 25, APS_DATA_RX_BROADCAST = 2, APS_DATA_TX_BROADCAST = 2, APS_DATA_RX_UNICAST = 0, APS_DATA_TX_UNICAST_SUCCESS = 0, APS_DATA_TX_UNICAST_RETRY = 0, APS_DATA_TX_UNICAST_FAILED = 0, ROUTE_DISCOVERY_INITIATED = 0, NEIGHBOR_ADDED = 0, NEIGHBOR_REMOVED = 0, NEIGHBOR_STALE = 0, JOIN_INDICATION = 0, CHILD_REMOVED = 0, ASH_OVERFLOW_ERROR = 0, ASH_FRAMING_ERROR = 0, ASH_OVERRUN_ERROR = 0, NWK_FRAME_COUNTER_FAILURE = 0, APS_FRAME_COUNTER_FAILURE = 0, UTILITY = 0, APS_LINK_KEY_NOT_AUTHORIZED = 0, NWK_DECRYPTION_FAILURE = 0, APS_DECRYPTION_FAILURE = 0, ALLOCATE_PACKET_BUFFER_FAILURE = 0, RELAYED_UNICAST = 0, PHY_TO_MAC_QUEUE_LIMIT_REACHED = 0, PACKET_VALIDATE_LIBRARY_DROPPED_COUNT = 0, TYPE_NWK_RETRY_OVERFLOW = 0, PHY_CCA_FAIL_COUNT = 139, BROADCAST_TABLE_FULL = 0, PTA_LO_PRI_REQUESTED = 0, PTA_HI_PRI_REQUESTED = 0, PTA_LO_PRI_DENIED = 0, PTA_HI_PRI_DENIED = 0, PTA_LO_PRI_TX_ABORTED = 0, PTA_HI_PRI_TX_ABORTED = 0, ADDRESS_CONFLICT_SENT = 0, EZSP_FREE_BUFFERS = 249]
[2022-04-24 13:36:10]DEBUG : Send command readCounters: ()
[2022-04-24 13:36:10]DEBUG : Sending: b'47e121a9a52a38487e'
[2022-04-24 13:36:10]DEBUG : Data frame: b'75e1a1a9a52a0bb22a944a25aa559249824e25abefce678bfdc66389fc7e3fa7ebcdde6f8fffc7dbd5d2698c4623a9ec763ba5ea758241984c2613b1e070381c0e07bbe5ca651b459a4d9e4f9ff7c3d9d46a35a25190482496057e'
[2022-04-24 13:36:10]DEBUG : Sending: b'8070787e'
[2022-04-24 13:36:10]DEBUG : Application frame 241 (readCounters) received: b'1e0073000000000000001e0002000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000910000000000000000000000000000000000'
[2022-04-24 13:36:10]DEBUG : Send command getValue: (,)
[2022-04-24 13:36:10]DEBUG : Sending: b'50e621a9fe2a16c5ed7e'
[2022-04-24 13:36:10]DEBUG : Data frame: b'06e6a1a9fe2a15b3a09f907e'
[2022-04-24 13:36:10]DEBUG : Sending: b'8160597e'
[2022-04-24 13:36:10]DEBUG : Application frame 170 (getValue) received: b'0001f9'
[2022-04-24 13:36:10]DEBUG : Free buffers status EzspStatus.SUCCESS, value: 249
[2022-04-24 13:36:10]DEBUG : ezsp_counters: [MAC_RX_BROADCAST = 30, MAC_TX_BROADCAST = 115, MAC_RX_UNICAST = 0, MAC_TX_UNICAST_SUCCESS = 0, MAC_TX_UNICAST_RETRY = 0, MAC_TX_UNICAST_FAILED = 30, APS_DATA_RX_BROADCAST = 2, APS_DATA_TX_BROADCAST = 2, APS_DATA_RX_UNICAST = 0, APS_DATA_TX_UNICAST_SUCCESS = 0, APS_DATA_TX_UNICAST_RETRY = 0, APS_DATA_TX_UNICAST_FAILED = 0, ROUTE_DISCOVERY_INITIATED = 0, NEIGHBOR_ADDED = 0, NEIGHBOR_REMOVED = 0, NEIGHBOR_STALE = 0, JOIN_INDICATION = 0, CHILD_REMOVED = 0, ASH_OVERFLOW_ERROR = 0, ASH_FRAMING_ERROR = 0, ASH_OVERRUN_ERROR = 0, NWK_FRAME_COUNTER_FAILURE = 0, APS_FRAME_COUNTER_FAILURE = 0, UTILITY = 0, APS_LINK_KEY_NOT_AUTHORIZED = 0, NWK_DECRYPTION_FAILURE = 0, APS_DECRYPTION_FAILURE = 0, ALLOCATE_PACKET_BUFFER_FAILURE = 0, RELAYED_UNICAST = 0, PHY_TO_MAC_QUEUE_LIMIT_REACHED = 0, PACKET_VALIDATE_LIBRARY_DROPPED_COUNT = 0, TYPE_NWK_RETRY_OVERFLOW = 0, PHY_CCA_FAIL_COUNT = 145, BROADCAST_TABLE_FULL = 0, PTA_LO_PRI_REQUESTED = 0, PTA_HI_PRI_REQUESTED = 0, PTA_LO_PRI_DENIED = 0, PTA_HI_PRI_DENIED = 0, PTA_LO_PRI_TX_ABORTED = 0, PTA_HI_PRI_TX_ABORTED = 0, ADDRESS_CONFLICT_SENT = 0, EZSP_FREE_BUFFERS = 249]
[2022-04-24 13:36:20]DEBUG : Send command readCounters: ()
[2022-04-24 13:36:20]DEBUG : Sending: b'61e721a9a52a4d247e'
[2022-04-24 13:36:20]DEBUG : Data frame: b'17e7a1a9a52a37b22a944a25aa559249be4e25abefce678bfdc66389fc7e3fa7ebcdde6f8fffc7dbd5d2698c4623a9ec763ba5ea758241984c2613b1e070381c0e07bbe5ca651f459a4d9e4f9ff7c3d9d46a35a251904824a5ac7e'
[2022-04-24 13:36:20]DEBUG : Sending: b'82503a7e'
[2022-04-24 13:36:20]DEBUG : Application frame 241 (readCounters) received: b'22007300000000000000220002000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000950000000000000000000000000000000000'
[2022-04-24 13:36:20]DEBUG : Send command getValue: (,)
[2022-04-24 13:36:20]DEBUG : Sending: b'72e421a9fe2a1640b87e'
[2022-04-24 13:36:20]DEBUG : Data frame: b'20e4a1a9fe2a15b3a0ed427e'
[2022-04-24 13:36:20]DEBUG : Sending: b'83401b7e'
[2022-04-24 13:36:20]DEBUG : Application frame 170 (getValue) received: b'0001f9'
[2022-04-24 13:36:20]DEBUG : Free buffers status EzspStatus.SUCCESS, value: 249
[2022-04-24 13:36:20]DEBUG : ezsp_counters: [MAC_RX_BROADCAST = 34, MAC_TX_BROADCAST = 115, MAC_RX_UNICAST = 0, MAC_TX_UNICAST_SUCCESS = 0, MAC_TX_UNICAST_RETRY = 0, MAC_TX_UNICAST_FAILED = 34, APS_DATA_RX_BROADCAST = 2, APS_DATA_TX_BROADCAST =
