merci pour tes logs
Il faut maintenant que je les analyse. J’y travaillerai ce week-end je pense
merci pour tes logs
Bonjour, merci @JAG !
Bonjour, je réponds à ma question suite à un retour de home@freebox.fr : Tout est en local pour Somfy.
Hello
Je viens déjà analyser les logs
=> LOG NODE :
"adapter":3,
"category":"shutter",
"group":{
"label":"Chambre"
"id":12,
"label":"Soren",
"name":"node_12",
"props":{
"Address":4126040,
"ArcId":5
"show_endpoints":[
"category":"",
"ep_type":"slot",
"id":0,
"label":"Consigne d'ouverture",
"name":"position_set",
"ui":{
"access":"w",
"display":"slider",
"icon_url":"/resources/images/home/pictos/volet_3.png",
"range":[
0,
100
"unit":"%"
"value":0,
"value_type":"int",
"visibility":"normal"
"category":"",
"ep_type":"slot",
"id":1,
"label":"Stop",
"name":"stop",
"ui":{
"access":"w",
"display":"button"
"value":null,
"value_type":"void",
"category":"",
"ep_type":"slot",
"id":2,
"label":"Toggle",
"name":"toggle",
"ui":{
"access":"w",
"display":"button"
"value":null,
"category":"",
"ep_type":"signal",
"id":4,
"refresh":2000,
"ui":{
"access":"r",
"display":"slider",
"range":[
0,
100
"unit":"%"
"value":0,
"value_type":"int",
"category":"",
"ep_type":"signal",
"id":5,
"label":"État",
"name":"state",
"refresh":2000,
"ui":{
"access":"r",
"display":"text"
"value":"WPU+gAAAT1hJTU8gaW8AAAAAAAAAAAL//wAAYBMAIDRYMjI1MTAwNDkxQjE1BQAAAAAAAABg3QAAAAA=",
"value_type":"string",
"signal_links":[
"slot_links":[
"status":"active",
"type":{
"abstract":false,
"endpoints":[
"ep_type":"slot",
"id":0,
"value_type":"int",
"visiblity":"normal"
"ep_type":"slot",
"id":1,
"label":"Stop",
"name":"stop",
"ep_type":"slot",
"id":2,
"label":"Toggle",
"name":"toggle",
"ep_type":"slot",
"id":3,
"name":"position",
"value_type":"int",
"ep_type":"signal",
"id":4,
"param_type":"void",
"value_type":"int",
"ep_type":"signal",
"id":5,
"label":"État",
"name":"state",
"generic":false,
"icon":"/resources/images/home/pictos/volet_3.png",
"inherit":"node::ios",
"label":"Volet roulant",
"name":"node::ios::2",
"params":{
"physical":true
=> LOG TILES :
"action":"store_slider",
"data":[
"ep_id":3,
"name":"position",
"refresh":2000,
"signal_id":4,
"slot_id":3,
"ui":{
"access":"rw",
"display":"icon",
"icon_range":[
0,
11,
22,
33,
44,
55,
66,
77,
88,
95
"icon_url":"/resources/images/home/pictos/volet_%.png",
"unit":"%"
"value":0,
"value_type":"int"
"ep_id":1,
"label":"Stop",
"name":"stop",
"slot_id":1,
"ui":{
"access":"w",
"display":"button"
"value":null,
"value_type":"void"
"group":{
"label":"Chambre"
"label":"Soren",
"node_id":12,
"type":"info"
On peut s’apercevoir que les commandes non pas les même ID. en particulier pour la commande d’ouverture
Je vais deja demander pourquoi cette différence a Free
Fais attention j’avais fait ça aussi et au bout de plusieurs semaines j’ai eu un kernel panic
De quoi parles-tu ?
Merci ! ![]()
Autant pour moi ma citation a sauté.
Je parlais d’un hard reboot de jeedom tout les jours.
Il y a 3 semaines chez moi ça a tenu 8j de suite sans aucun reboot. Mais depuis max48h
Moi depuis que j’ai fait mon scénario spécial rafraîchissement comme dit plus haut, plus de plantage. (Avant ça ne tenait pas plus de 2 jours).
Bonsoir
J’ai comme vous le plantage des commandes de mes 12 volets Somfy IO que se soit via Jeedom installer dans la Delta ou via l’application Freebox rubrique Maison.
En attendant une solution pérenne pour supprimer ce plantage, quel est la meilleure solution pour s’en affranchir.
Merci par avance
J’ai répondu juste au dessus
Comment avez-vous fait pour ce point ?
Décoché la case dans les configuration du pluging ! où il y a un autre moyen ?
Moi j’ai tout simplement passé l’actualisation de chaque équipement à une fois par an puisqu’on ne peu pas la désactiver complètement depuis là.
J’ai mis " 0 0 1 1 * ".
Et du coup le retour d’état ?
C’est à dire ?
Comment tu connais l’état de tes volets(Ouvert fermé 30% 50%…)
Ben comme avant. Ça ça ne change pas. J’ai juste modifié le temps entre les refresh.
ça va faire une semaine que mon Jeedom n’a pas eu à redémarrer à cause d’un plantage.
Je n’ai pas beaucoup d’interactions, mais j’en ai suffisamment pour l’avoir fait planter précédemment.
La seule chose de différent par rapport à avant, c’est que ma box Delta n’a plus de connexion internet depuis vendredi dernier, est-ce une coïncidence ou est-ce une potentiel cause du plantage régulier lorsqu’il y a internet ?
Je précise que j’ai désactivé tous les équipements hormis les volets, par contre je n’ai pas touché à l’auto-actualisation.
Quelqu’un a t il eu une réponse de Free par rapport à notre problème
A aujourd’hui j’attend encore sur 1 réponse de leurs part
Message envoyé en janvier
Bonjour à tous
Bon mon Jeedom ne tient pas 2 jours sans plantage.
Je suis actuellement en 4.2.9 sur le serveur, je vais faire la MAJ d’hier pour voir si ça change quelques choses.
Par contre, lorsque je n’avais plus internet je confirme que mon Jeedom a tenu plus d’une semaine. Je ne pense pas que ça soit une coïncidence.
A voir avec les développeurs pour regarder de ce côté là.
