bonjour
oui j’ai bien fait cette manip et j’ai bien ma pizigate branché, elle s’allume en bleu très faible…
bonjour
Je n’ai pas cet appareil, mais il faut s’assurer qu’elle est bien branché, car cela a été vue ici plusieurs fois, ou les cartes d’extension sur GPIO n’étaient pas correctement branchée, décalée d’une rangée par exemple.
Je peux voir le fichier /boot/config.txt ?
En SSH, saisissez cette commande :
sudo systemctl disable hciuart
Puis, redémarrer.
For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
gpu_mem=16 disable_l2cache=0 gpu_freq=250 dtoverlay=pi3-disable-bt
enable_uart=1 dtoverlay=disable-bt
Bah, du coup elle y est présente 3 fois ce n’est pas très grave. Mais alors pourquoi cela fonctionne encore ?
Vous avez arrêté le service ?
Faites :
hciconfig
je n’ai rien lorsque je fais hciconfig…
Et l’arrêt du service ?
Je ne sais pas quoi dire de plus
Il faut redémarrer, vous l’avez fait ?
j’ai fait sudo reboot
Attendez les experts de cette clé.
La, le fil est un peu pourir, car vous avez fait un tour de pass pass avec le titre et le tag
ok merci a vous
Le port ne semble pas être le bon dans l’une des 1ere copie d’écran.
oui j’avoue que j’ai suivi les tuto sans trop savoir ce que je fesait, il etait ecrit soit tty s0
Dans le config.txt, ajoutez cela à la fin :
dtoverlay=miniuart-bt
Et reboot.
argh c’est de pire en pire je n’ai carrement plus dans le port serie le tty s0 il a disparu…
C’est étonnant, car c’est la solution dans un autre fil.
Vous êtes sur que le port est le bon ?
Pour le retour arrière :
Commentez cette ligne avec un #devant.
Puis redémarrez.
non je ne suis sur de rien… comment puis je savoir que je port est bon?
ls -l /dev/serial*
