Bonjour, j’ai un soucis dans l’instalation du plugin il m’est impossible d’installer mitmproxy
J’ai debian 10 la version python3.7 qui semblait etre le blocage des précedent soucis mais la je sais pas pourquoi.
Voici le log de l’instalation :
* Install kTwinkly plugin dependencies *
> Progress file: /tmp/jeedom/kTwinkly/dependencies
Mon Nov 21 17:04:29 CET 2022
* Update package list
Hit:1 http://ftp.fr.debian.org/debian buster InRelease
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:3 http://ftp.fr.debian.org/debian buster-updates InRelease
Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
Reading package lists...
* Remove apt package for mitmproxy
Building dependency tree...
Reading state information...
Package 'mitmproxy' is not installed, so not removed
The following packages were automatically installed and are no longer required:
python3-pyinotify python3-systemd
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
* Checking if default Python3 is version 3.7+
** Found Python 3.7.3
** Installing python3-setuptools
python3-setuptools is already the newest version (40.8.0-1).
python3-dev is already the newest version (3.7.3-1).
python3-wheel is already the newest version (0.32.3-2).
Python 3.7.3
* Install mitmproxy module and dependencies on Python 3
libffi-dev is already the newest version (3.2.1-9).
Requirement already satisfied: tornado in /usr/local/lib/python3.7/dist-packages (6.1)
Requirement already satisfied: mitmproxy in /usr/local/lib/python3.7/dist-packages (5.3.0)
Requirement already satisfied: h2<5,>=4.0 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (4.1.0)
Requirement already satisfied: flask<1.2,>=1.1.1 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (1.1.4)
Requirement already satisfied: Brotli<1.1,>=1.0 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (1.0.9)
Requirement already satisfied: wsproto<0.16,>=0.14 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (0.15.0)
Requirement already satisfied: asgiref<3.4,>=3.2.10 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (3.3.4)
Requirement already satisfied: urwid<2.2,>=2.1.1 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (2.1.2)
Requirement already satisfied: cryptography<3.3,>=3.2 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (3.2.1)
Requirement already satisfied: zstandard<0.15,>=0.11 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (0.14.1)
Requirement already satisfied: sortedcontainers<2.3,>=2.1 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (2.2.2)
Requirement already satisfied: protobuf<3.14,>=3.6.0 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (3.13.0)
Requirement already satisfied: ruamel.yaml<0.17,>=0.16 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (0.16.13)
Requirement already satisfied: kaitaistruct<0.10,>=0.7 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (0.9)
Requirement already satisfied: click<8,>=7.0 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (7.1.2)
Requirement already satisfied: ldap3<2.9,>=2.8 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (2.8.1)
Requirement already satisfied: passlib<1.8,>=1.6.5 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (1.7.4)
Requirement already satisfied: hyperframe<7,>=6.0 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (6.0.1)
Requirement already satisfied: pyasn1<0.5,>=0.3.1 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (0.4.8)
Requirement already satisfied: certifi>=2019.9.11 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (2021.10.8)
Requirement already satisfied: pyperclip<1.9,>=1.6.0 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (1.8.2)
Requirement already satisfied: blinker<1.5,>=1.4 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (1.4)
Requirement already satisfied: pyOpenSSL<19.2,>=19.1.0 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (19.1.0)
Requirement already satisfied: publicsuffix2<3,>=2.20190812 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (2.20191221)
Requirement already satisfied: pyparsing<2.5,>=2.4.2 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (2.4.7)
Requirement already satisfied: msgpack<1.1.0,>=1.0.0 in /usr/local/lib/python3.7/dist-packages (from mitmproxy) (1.0.4)
Requirement already satisfied: typing-extensions in /usr/local/lib/python3.7/dist-packages (from asgiref<3.4,>=3.2.10->mitmproxy) (4.2.0)
Requirement already satisfied: cffi!=1.11.3,>=1.8 in /usr/local/lib/python3.7/dist-packages (from cryptography<3.3,>=3.2->mitmproxy) (1.15.0)
Requirement already satisfied: six>=1.4.1 in /usr/local/lib/python3.7/dist-packages (from cryptography<3.3,>=3.2->mitmproxy) (1.14.0)
Requirement already satisfied: Werkzeug<2.0,>=0.15 in /usr/local/lib/python3.7/dist-packages (from flask<1.2,>=1.1.1->mitmproxy) (1.0.1)
Requirement already satisfied: itsdangerous<2.0,>=0.24 in /usr/local/lib/python3.7/dist-packages (from flask<1.2,>=1.1.1->mitmproxy) (1.1.0)
Requirement already satisfied: Jinja2<3.0,>=2.10.1 in /usr/local/lib/python3.7/dist-packages (from flask<1.2,>=1.1.1->mitmproxy) (2.11.3)
Requirement already satisfied: hpack<5,>=4.0 in /usr/local/lib/python3.7/dist-packages (from h2<5,>=4.0->mitmproxy) (4.0.0)
Requirement already satisfied: setuptools in /usr/local/lib/python3.7/dist-packages (from protobuf<3.14,>=3.6.0->mitmproxy) (65.3.0)
Requirement already satisfied: ruamel.yaml.clib>=0.1.2 in /usr/local/lib/python3.7/dist-packages (from ruamel.yaml<0.17,>=0.16->mitmproxy) (0.2.7)
Requirement already satisfied: h11>=0.8.1 in /usr/local/lib/python3.7/dist-packages (from wsproto<0.16,>=0.14->mitmproxy) (0.14.0)
Requirement already satisfied: pycparser in /usr/local/lib/python3.7/dist-packages (from cffi!=1.11.3,>=1.8->cryptography<3.3,>=3.2->mitmproxy) (2.21)
Requirement already satisfied: MarkupSafe>=0.23 in /usr/local/lib/python3.7/dist-packages (from Jinja2<3.0,>=2.10.1->flask<1.2,>=1.1.1->mitmproxy) (2.1.1)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
--- Logging error ---
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/logging.py", line 177, in emit
self.console.print(renderable, overflow="ignore", crop=False, style=style)
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/console.py", line 1673, in print
extend(render(renderable, render_options))
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/console.py", line 1305, in render
for render_output in iter_render:
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/logging.py", line 134, in __rich_console__
for line in lines:
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/segment.py", line 249, in split_lines
for segment in segments:
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/console.py", line 1283, in render
renderable = rich_cast(renderable)
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/protocol.py", line 36, in rich_cast
renderable = cast_method()
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/self_outdated_check.py", line 130, in __rich__
pip_cmd = get_best_invocation_for_this_pip()
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/entrypoints.py", line 60, in get_best_invocation_for_this_pip
os.path.join(binary_prefix, exe_name),
File "/usr/lib/python3.7/genericpath.py", line 97, in samefile
s2 = os.stat(f2)
FileNotFoundError: [Errno 2] No such file or directory: '/usr/bin/pip3.7'
Call stack:
File "/usr/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/local/lib/python3.7/dist-packages/pip/__main__.py", line 31, in <module>
sys.exit(_main())
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/main.py", line 70, in main
return command.main(cmd_args)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/base_command.py", line 101, in main
return self._main(args)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/base_command.py", line 223, in _main
self.handle_pip_version_check(options)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/req_command.py", line 190, in handle_pip_version_check
pip_self_version_check(session, options)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/self_outdated_check.py", line 236, in pip_self_version_check
logger.warning("[present-rich] %s", upgrade_prompt)
File "/usr/lib/python3.7/logging/__init__.py", line 1395, in warning
self._log(WARNING, msg, args, **kwargs)
File "/usr/lib/python3.7/logging/__init__.py", line 1519, in _log
self.handle(record)
File "/usr/lib/python3.7/logging/__init__.py", line 1529, in handle
self.callHandlers(record)
File "/usr/lib/python3.7/logging/__init__.py", line 1591, in callHandlers
hdlr.handle(record)
File "/usr/lib/python3.7/logging/__init__.py", line 905, in handle
self.emit(record)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/logging.py", line 179, in emit
self.handleError(record)
Message: '[present-rich] %s'
Arguments: (UpgradePrompt(old='22.2.2', new='22.3.1'),)
Mon Nov 21 17:04:41 CET 2022
* End dependencies Installation *
