Après avoir vu que IFTT devenait payant et du coup avec la volonté de tout contrôler en lan,
j’ai essayé d’installer la version 2.0 du plugin (avec le contrôle LAN) mais impossible d’installer les dépendances ou de lancer le démon.
voici mon log :
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/string/#/uncapitalize.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/array/#/uniq.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/array/#/uniq.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/object/unserialize.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/object/unserialize.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/array/valid-array.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/array/valid-array.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/object/valid-callable.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/object/valid-callable.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/date/valid-date.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/date/valid-date.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/error/valid-error.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/error/valid-error.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/function/valid-function.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/function/valid-function.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/object/valid-object.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/object/valid-object.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/reg-exp/valid-reg-exp.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/reg-exp/valid-reg-exp.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/object/valid-value.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/object/valid-value.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/object/validate-array-like-object.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/object/validate-array-like-object.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/object/validate-array-like.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/object/validate-array-like.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/iterable/validate-object.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/iterable/validate-object.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/object/validate-stringifiable-value.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/object/validate-stringifiable-value.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/object/validate-stringifiable.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/object/validate-stringifiable.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/iterable/validate.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/iterable/validate.js'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/promise/.eslintrc.json'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/.eslintrc.json'
npm WARN tar ENOENT: no such file or directory, lstat '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/test/promise'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/package.json'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/CHANGELOG.md'
npm WARN tar ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/node_modules/.staging/es5-ext-f75e11dc/README.md'
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2020-09-15T13_55_24_986Z-debug.log
--70%
npm WARN saveError ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/package.json'
npm notice created a lockfile as package-lock.json. You should commit this file.
npm WARN enoent ENOENT: no such file or directory, open '/var/www/html/plugins/ewejee/core/js/package.json'
npm WARN js No description
npm WARN js No repository field.
npm WARN js No README data
npm WARN js No license field.
--80%
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
--90%
--95%
--100%
Installation des dépendances eWeJee terminée, vérifiez qu'il n'y a pas d'erreur
Je tourne sur Raspberry Pi 4 4Go, Raspbian GNU/Linux 10 (buster) Release 10,Jeedom 4.0.61
une petite idée ?
