Je repost mon message dans le bon endroit
Je viens d’acheter 16 € le plugin SomfyUnified. Il est impossible d’installer les dépendances, elles se terminent par NOK !.
Voici les logs :
== 21/05/2025 13:37:10 == Dependencies installation for SomfyUnified
[ 5% ] : Clean apt...
[ 9% ] : Clean apt : [ OK ]
[ 10% ] : Update apt...
[ 14% ] : Update apt : [ OK ]
[ 15% ] : Install apt packages...
[ 19% ] : Install apt packages : [ OK ]
[ 20% ] : Init python3 & prerequisites...
[ 29% ] : Init python3 & prerequisites : [ OK ]
[ 30% ] : Init PyEnv...
** PyEnv required: 3.9.2 < 3.11 **
[ 39% ] : Init PyEnv : [ OK ]
[ 40% ] : install or update PyEnv...
[ 49% ] : install or update PyEnv : [ OK ]
[ 50% ] : Install Python 3.11 with PyEnv...
** python3 path: /opt/pyenv/versions/3.11.12/bin/python3 **
[ 59% ] : Install Python 3.11 with PyEnv : [ OK ]
[ 60% ] : Setting up virtual environment...
[ 99% ] : Setting up virtual environment : ERROR
[100% ] : Finished !
==KO== Installation Error
== ANALYSING LOGS...
== NO KNOWN ERROR DETECTED
== Error in step : Setting up virtual environment
== Line 225
== The command `createVenv' has an issue
== Return code is 2
== Error message :
** use /opt/pyenv/versions/3.11.12/bin/python3 to setup /var/www/html/plugins/SomfyUnified/core/python/dependencymanagement/../../../py_venv **
Python version in Venv is ok: 3.11.12==3.11.12
ERROR: Exception:
File "/var/www/html/plugins/SomfyUnified/py_venv/lib/python3.11/site-packages/pip/_internal/cli/base_command.py", line 180, in exc_logging_wrapper
status = run_func(*args)
File "/var/www/html/plugins/SomfyUnified/py_venv/lib/python3.11/site-packages/pip/_internal/cli/req_command.py", line 245, in wrapper
return func(self, options, args)
File "/var/www/html/plugins/SomfyUnified/py_venv/lib/python3.11/site-packages/pip/_internal/commands/install.py", line 362, in run
resolver = self.make_resolver(
File "/var/www/html/plugins/SomfyUnified/py_venv/lib/python3.11/site-packages/pip/_internal/cli/req_command.py", line 353, in make_resolver
import pip._internal.resolution.resolvelib.resolver
File "/var/www/html/plugins/SomfyUnified/py_venv/lib/python3.11/site-packages/pip/_internal/resolution/resolvelib/resolver.py", line 8, in <module>
from pip._vendor.resolvelib import BaseReporter, ResolutionImpossible
File "/var/www/html/plugins/SomfyUnified/py_venv/lib/python3.11/site-packages/pip/_vendor/resolvelib/__init__.py", line 19, in <module>
from .resolvers import (
File "/var/www/html/plugins/SomfyUnified/py_venv/lib/python3.11/site-packages/pip/_vendor/resolvelib/resolvers/__init__.py", line 1, in <module>
from ..structs import RequirementInformation
ImportError: cannot import name 'RequirementInformation' from 'pip._vendor.resolvelib.structs' (/var/www/html/plugins/SomfyUnified/py_venv/lib/python3.11/site-packages/pip/_vendor/resolvelib/structs.py)
[notice] A new release of pip is available: 24.0 -> 25.1.1
[notice] To update, run: /var/www/html/plugins/SomfyUnified/py_venv/bin/python3 -m pip install --upgrade pip
Error: Command '['/var/www/html/plugins/SomfyUnified/py_venv/bin/python3', '-m', 'pip', 'install', '--upgrade', 'pip', 'setuptools']' returned non-zero exit status 2.
ERROR: Exception:
Le résultat : Setting up virtual environment : ERROR
**Informations Jeedom**
Core : 4.4.19 (master)
DNS Jeedom : oui
Plugin : SomfyUnified
Version : 2025-05-11 13:54:25 (stable)
Statut Démon : Stoppé - (Inconnue)
