Mais pour BLEA, toujours pareil, impossible d’initialiser les dépendances :
J’ai des gros doute sur la corrélation avec mon problème d’espace remonté par d’autres utilisateur comme :
Autre post
Mes log restent vides sauf :
blea_update_v28_06.txt (30,5 Ko)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/base_command.py", line 223, in _main
self.handle_pip_version_check(options)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/req_command.py", line 190, in handle_pip_version_check
pip_self_version_check(session, options)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/self_outdated_check.py", line 236, in pip_self_version_check
logger.warning("[present-rich] %s", upgrade_prompt)
File "/usr/lib/python3.7/logging/__init__.py", line 1395, in warning
self._log(WARNING, msg, args, **kwargs)
File "/usr/lib/python3.7/logging/__init__.py", line 1519, in _log
self.handle(record)
File "/usr/lib/python3.7/logging/__init__.py", line 1529, in handle
self.callHandlers(record)
File "/usr/lib/python3.7/logging/__init__.py", line 1591, in callHandlers
hdlr.handle(record)
File "/usr/lib/python3.7/logging/__init__.py", line 905, in handle
self.emit(record)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/logging.py", line 179, in emit
self.handleError(record)
Message: '[present-rich] %s'
Arguments: (UpgradePrompt(old='22.2.2', new='23.1.2'),)
Requirement already satisfied: requests in /usr/local/lib/python3.7/dist-packages (2.28.1)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.7/dist-packages (from requests) (3.4)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests) (2022.9.24)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests) (1.26.12)
Requirement already satisfied: charset-normalizer<3,>=2 in /usr/local/lib/python3.7/dist-packages (from requests) (2.0.12)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
--- Logging error ---
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/logging.py", line 177, in emit
self.console.print(renderable, overflow="ignore", crop=False, style=style)
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/console.py", line 1673, in print
extend(render(renderable, render_options))
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/console.py", line 1305, in render
for render_output in iter_render:
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/logging.py", line 134, in __rich_console__
for line in lines:
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/segment.py", line 249, in split_lines
for segment in segments:
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/console.py", line 1283, in render
renderable = rich_cast(renderable)
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/protocol.py", line 36, in rich_cast
renderable = cast_method()
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/self_outdated_check.py", line 130, in __rich__
pip_cmd = get_best_invocation_for_this_pip()
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/entrypoints.py", line 60, in get_best_invocation_for_this_pip
os.path.join(binary_prefix, exe_name),
File "/usr/lib/python3.7/genericpath.py", line 97, in samefile
s2 = os.stat(f2)
FileNotFoundError: [Errno 2] No such file or directory: '/usr/bin/pip'
Call stack:
File "/usr/local/bin/pip3", line 8, in <module>
sys.exit(main())
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/main.py", line 70, in main
return command.main(cmd_args)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/base_command.py", line 101, in main
return self._main(args)
self.handle(record)
hdlr.handle(record)
self.emit(record)
Requirement already satisfied: pybluez in /usr/local/lib/python3.7/dist-packages (0.23)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
Requirement already satisfied: pillow in /usr/local/lib/python3.7/dist-packages (8.3.1)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.21.0)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
Requirement already satisfied: bluepy in /usr/local/lib/python3.7/dist-packages (1.3.0)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
Cloning into 'bluepy'...
running build
running build_py
creating build
creating build/lib
creating build/lib/bluepy
copying bluepy/sensortag.py -> build/lib/bluepy
copying bluepy/btle.py -> build/lib/bluepy
copying bluepy/__init__.py -> build/lib/bluepy
copying bluepy/scan_fuzz.py -> build/lib/bluepy
copying bluepy/blescan.py -> build/lib/bluepy
copying bluepy/thingy52.py -> build/lib/bluepy
copying bluepy/get_services.py -> build/lib/bluepy
copying bluepy/scanner.py -> build/lib/bluepy
copying bluepy/uuids.json -> build/lib/bluepy
copying bluepy/bluez-src.tgz -> build/lib/bluepy
copying bluepy/bluepy-helper.c -> build/lib/bluepy
copying bluepy/Makefile -> build/lib/bluepy
/usr/local/lib/python3.7/dist-packages/setuptools/dist.py:745: SetuptoolsDeprecationWarning: Invalid dash-separated options
Usage of dash-separated 'description-file' will not be supported in future
versions. Please use the underscore name 'description_file' instead.
By 2023-Sep-26, you need to update your project and remove deprecated calls
or your builds will no longer be supported.
See https://setuptools.pypa.io/en/latest/userguide/declarative_config.html for details.
opt = self.warn_dash_deprecation(opt, section)
running install
Working dir is /tmp/bluepy
execute make -C ./bluepy clean
execute make -C bluepy -j1
running build
running build_py
copying bluepy/bluepy-helper -> build/lib/bluepy
running install_lib
copying build/lib/bluepy/sensortag.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluepy-helper.c -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluepy-helper -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/btle.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/__init__.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/scan_fuzz.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluez-src.tgz -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/uuids.json -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/blescan.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/thingy52.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/Makefile -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/get_services.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/scanner.py -> /usr/lib/python3.7/site-packages/bluepy
byte-compiling /usr/lib/python3.7/site-packages/bluepy/sensortag.py to sensortag.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/btle.py to btle.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/__init__.py to __init__.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/scan_fuzz.py to scan_fuzz.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/blescan.py to blescan.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/thingy52.py to thingy52.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/get_services.py to get_services.cpython-37.pyc
byte-compiling /usr/lib/python3.7/site-packages/bluepy/scanner.py to scanner.cpython-37.pyc
running install_egg_info
running egg_info
creating bluepy.egg-info
writing bluepy.egg-info/PKG-INFO
writing dependency_links to bluepy.egg-info/dependency_links.txt
writing entry points to bluepy.egg-info/entry_points.txt
writing top-level names to bluepy.egg-info/top_level.txt
writing manifest file 'bluepy.egg-info/SOURCES.txt'
reading manifest file 'bluepy.egg-info/SOURCES.txt'
adding license file 'LICENSE.txt'
removing '/usr/lib/python3.7/site-packages/bluepy-1.1.4-py3.7.egg-info' (and everything under it)
Copying bluepy.egg-info to /usr/lib/python3.7/site-packages/bluepy-1.1.4-py3.7.egg-info
running install_scripts
Installing blescan script to /usr/bin
Installing sensortag script to /usr/bin
Installing thingy52 script to /usr/bin
/usr/local/lib/python3.7/dist-packages/setuptools/_distutils/cmd.py:66: SetuptoolsDeprecationWarning: setup.py install is deprecated.
Please avoid running ``setup.py`` directly.
Instead, use pypa/build, pypa/installer or other
standards-based tools.
See https://blog.ganssle.io/articles/2021/10/setup-py-deprecated.html for details.
self.initialize_options()
Requirement already satisfied: cryptography in /usr/local/lib/python3.7/dist-packages (38.0.1)
Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.7/dist-packages (from cryptography) (1.15.1)
Requirement already satisfied: pycparser in /usr/local/lib/python3.7/dist-packages (from cffi>=1.12->cryptography) (2.21)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
Requirement already satisfied: pycrypto in /usr/local/lib/python3.7/dist-packages (2.6.1)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
* Installation terminée *
Je suis preneur de vos avis…
