File "louie/__init__.py", line 1, in <module>
from . import dispatcher, error, plugin, robustapply, saferef, sender, signal, version
File "louie/dispatcher.py", line 44
f"Louie connects: {connects}
SyntaxError: invalid syntax
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-AmnD8D/louie/
+ echo 6
+ sudo pip2 install --force-reinstall --upgrade requests
Collecting requests
Cache entry deserialization failed, entry ignored
Using cached https://files.pythonhosted.org/packages/2d/61/08076519c80041bc0ffa1a8af0cbd3bf3e2b62af10435d269a9d0f40564d/requests-2.27.1-py2.py3-none-any.whl
Collecting certifi>=2017.4.17 (from requests)
Using cached https://files.pythonhosted.org/packages/37/45/946c02767aabb873146011e665728b680884cd8fe70dde973c640e45b775/certifi-2021.10.8-py2.py3-none-any.whl
Collecting urllib3<1.27,>=1.21.1 (from requests)
Using cached https://files.pythonhosted.org/packages/6f/de/5be2e3eed8426f871b170663333a0f627fc2924cc386cd41be065e7ea870/urllib3-1.26.12-py2.py3-none-any.whl
Collecting idna<3,>=2.5; python_version < "3" (from requests)
Using cached https://files.pythonhosted.org/packages/a2/38/928ddce2273eaa564f6f50de919327bf3a00f091b5baba8dfa9460f3a8a8/idna-2.10-py2.py3-none-any.whl
Collecting chardet<5,>=3.0.2; python_version < "3" (from requests)
Using cached https://files.pythonhosted.org/packages/19/c7/fa589626997dd07bd87d9269342ccb74b1720384a4d739a1872bd84fbe68/chardet-4.0.0-py2.py3-none-any.whl
Installing collected packages: certifi, urllib3, idna, chardet, requests
Found existing installation: certifi 2021.10.8
Uninstalling certifi-2021.10.8:
Successfully uninstalled certifi-2021.10.8
Found existing installation: urllib3 1.26.12
Uninstalling urllib3-1.26.12:
Successfully uninstalled urllib3-1.26.12
Found existing installation: idna 2.10
Uninstalling idna-2.10:
Successfully uninstalled idna-2.10
Found existing installation: chardet 4.0.0
Uninstalling chardet-4.0.0:
Successfully uninstalled chardet-4.0.0
Found existing installation: requests 2.27.1
Uninstalling requests-2.27.1:
Successfully uninstalled requests-2.27.1
Successfully installed certifi-2021.10.8 chardet-4.0.0 idna-2.10 requests-2.27.1 urllib3-1.26.12
+ echo 7
+ sudo pip2 install --force-reinstall --upgrade setuptools
Collecting setuptools
Using cached https://files.pythonhosted.org/packages/e1/b7/182161210a13158cd3ccc41ee19aadef54496b74f2817cc147006ec932b4/setuptools-44.1.1-py2.py3-none-any.whl
Installing collected packages: setuptools
Found existing installation: setuptools 44.1.1
Uninstalling setuptools-44.1.1:
Successfully uninstalled setuptools-44.1.1
Successfully installed setuptools-44.1.1
+ echo 8
+ sudo pip2 install --force-reinstall --upgrade pyserial
Collecting pyserial
Using cached https://files.pythonhosted.org/packages/07/bc/587a445451b253b285629263eb51c2d8e9bcea4fc97826266d186f96f558/pyserial-3.5-py2.py3-none-any.whl
Installing collected packages: pyserial
Found existing installation: pyserial 3.5
Uninstalling pyserial-3.5:
Successfully uninstalled pyserial-3.5
Successfully installed pyserial-3.5
+ echo 9
+ sudo pip2 install --force-reinstall --upgrade six
Collecting six
Using cached https://files.pythonhosted.org/packages/d9/5a/e7c31adbe875f2abbb91bd84cf2dc52d792b5a01506781dbcf25c91daf11/six-1.16.0-py2.py3-none-any.whl
Installing collected packages: six
Found existing installation: six 1.16.0
Uninstalling six-1.16.0:
Successfully uninstalled six-1.16.0
Successfully installed six-1.16.0
+ echo 10
+ sudo pip2 install --force-reinstall --upgrade tornado
Collecting tornado
Collecting backports-abc>=0.4 (from tornado)
Using cached https://files.pythonhosted.org/packages/7d/56/6f3ac1b816d0cd8994e83d0c4e55bc64567532f7dc543378bd87f81cebc7/backports_abc-0.5-py2.py3-none-any.whl
Collecting futures (from tornado)
Using cached https://files.pythonhosted.org/packages/d8/a6/f46ae3f1da0cd4361c344888f59ec2f5785e69c872e175a748ef6071cdb5/futures-3.3.0-py2-none-any.whl
Collecting singledispatch (from tornado)
Using cached https://files.pythonhosted.org/packages/3f/09/2a17c6505a8373229cb3de6161e3af74ff90afcf4516719aa6cf32fad151/singledispatch-3.7.0-py2.py3-none-any.whl
Collecting six (from singledispatch->tornado)
Installing collected packages: backports-abc, futures, six, singledispatch, tornado
Found existing installation: backports-abc 0.5
Uninstalling backports-abc-0.5:
Successfully uninstalled backports-abc-0.5
Found existing installation: futures 3.3.0
Uninstalling futures-3.3.0:
Successfully uninstalled futures-3.3.0
Found existing installation: singledispatch 3.7.0
Uninstalling singledispatch-3.7.0:
Successfully uninstalled singledispatch-3.7.0
Found existing installation: tornado 5.1.1
Uninstalling tornado-5.1.1:
Successfully uninstalled tornado-5.1.1
Successfully installed backports-abc-0.5 futures-3.3.0 singledispatch-3.7.0 six-1.16.0 tornado-5.1.1
+ echo 11
+ sudo chmod +x /var/www/html/core/class/../../plugins/openzwave/resources/post_install.sh
+ sudo /var/www/html/core/class/../../plugins/openzwave/resources/post_install.sh
Lancement de l'installation/mise à jour des dépendances openzwave
mkdir: cannot create directory '/opt': File exists
Désinstallation de la version précédente
Installation de Python-OpenZwave
WARNING: Skipping Cython as it is not installed.
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
apt-get install --force-yes -y cython
Reading package lists...
Building dependency tree...
Reading state information...
cython is already the newest version (0.29.2-2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
W: --force-yes is deprecated, use one of the options starting with --allow instead.
Installing dependencies for python : 2 7 16
apt-get install --force-yes -y python-pip python-dev python-docutils python-setuptools python-louie
python-louie is already the newest version (1.1-4).
python-dev is already the newest version (2.7.16-1).
python-docutils is already the newest version (0.14+dfsg-4).
python-pip is already the newest version (18.1-5).
python-setuptools is already the newest version (40.8.0-1).
apt-get install --force-yes -y build-essential libudev-dev g++
build-essential is already the newest version (12.6).
g++ is already the newest version (4:8.3.0-1).
libudev-dev is already the newest version (241-7~deb10u8).
pip install nose-html
Requirement already satisfied: nose-html in /usr/local/lib/python3.7/dist-packages (1.1)
Requirement already satisfied: nose>=0.11.1 in /usr/local/lib/python3.7/dist-packages (from nose-html) (1.3.7)
pip install nose-progressive
Collecting nose-progressive
Using cached nose-progressive-1.5.2.tar.gz (32 kB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'error'
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [1 lines of output]
error in nose-progressive setup command: use_2to3 is invalid.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
make: *** [Makefile:160: tests-deps] Error 1
sed -i -e '253s/.*//' openzwave/cpp/src/value_classes/ValueID.h
cd openzwave && make
make[1]: Entering directory '/opt/python-openzwave/openzwave'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/build/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/build'
Building OpenZWave Version 1.4.-1
Building tinystr.o
Building tinyxmlerror.o
Building tinyxml.o
Building tinyxmlparser.o
Building hid.o
Building aeskey.o
Building aescrypt.o
Building aestab.o
Building aes_modes.o
Building Association.o
Building EnergyProduction.o
Building MultiCmd.o
Building SensorBinary.o
Building WakeUp.o
Building SwitchMultilevel.o
Building ZWavePlusInfo.o
Building Indicator.o
Building CRC16Encap.o
Building MultiInstance.o
Building Language.o
Building MeterPulse.o
Building DoorLock.o
Building DeviceResetLocally.o
Building SwitchBinary.o
Building Configuration.o
Building SwitchToggleBinary.o
Building Hail.o
Building ThermostatMode.o
Building SensorMultilevel.o
Building TimeParameters.o
Building ThermostatFanMode.o
Building UserCode.o
Building Alarm.o
Building BarrierOperator.o
Building ThermostatFanState.o
Building ThermostatSetpoint.o
Building SoundSwitch.o
Building ApplicationStatus.o
Building CentralScene.o
Building ClimateControlSchedule.o
Building Protection.o
Building ThermostatOperatingState.o
Building NodeNaming.o
Building ManufacturerProprietary.o
Building SwitchAll.o
Building Lock.o
Building Color.o
Building Clock.o
Building SceneActivation.o
Building Powerlevel.o
Building Meter.o
Building AssociationCommandConfiguration.o
Building SensorAlarm.o
Building Battery.o
Building MultiChannelAssociation.o
Building Version.o
Building Security.o
Building Proprietary.o
Building CommandClasses.o
Building ManufacturerSpecific.o
In file included from /usr/include/c++/8/map:60,
from /opt/python-openzwave/openzwave/cpp/src/command_classes/CommandClasses.h:32,
from /opt/python-openzwave/openzwave/cpp/src/command_classes/ManufacturerSpecific.cpp:28:
/usr/include/c++/8/bits/stl_tree.h: In function 'std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::iterator std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::_M_emplace_hint_unique(std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::const_iterator, _Args&& ...) [with _Args = {const std::piecewise_construct_t&, std::tuple<long long int&&>, std::tuple<>}; _Key = long long int; _Val = std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*>; _KeyOfValue = std::_Select1st<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >; _Compare = std::less<long long int>; _Alloc = std::allocator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >]':
/usr/include/c++/8/bits/stl_tree.h:2411:7: note: parameter passing for argument of type 'std::_Rb_tree<long long int, std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*>, std::_Select1st<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >, std::less<long long int>, std::allocator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> > >::const_iterator' {aka 'std::_Rb_tree_const_iterator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >'} changed in GCC 7.1
In file included from /usr/include/c++/8/map:61,
/usr/include/c++/8/bits/stl_map.h: In static member function 'static bool OpenZWave::ManufacturerSpecific::LoadProductXML()':
/usr/include/c++/8/bits/stl_map.h:518:8: note: parameter passing for argument of type 'std::_Rb_tree<long long int, std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*>, std::_Select1st<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >, std::less<long long int>, std::allocator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> > >::const_iterator' {aka 'std::_Rb_tree_const_iterator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >'} changed in GCC 7.1
__i = _M_t._M_emplace_hint_unique(__i, std::piecewise_construct,
Building NoOperation.o
Building BasicWindowCovering.o
Building Basic.o
Building CommandClass.o
Building DoorLockLogging.o
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp: In member function 'virtual bool OpenZWave::DoorLockLogging::HandleMsg(const uint8*, uint32, uint32)':
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp:312:15: warning: passing argument 1 to restrict-qualified parameter aliases with argument 4 [-Wrestrict]
snprintf(usercode, sizeof(usercode), "%s %d", usercode, (int)_data[12+i]);
Building ControllerReplication.o
Building SwitchToggleMultilevel.o
Building Value.o
Building ValueList.o
Building ValueButton.o
Building ValueInt.o
Building ValueStore.o
Building ValueDecimal.o
Building ValueRaw.o
Building ValueString.o
Building ValueByte.o
Building ValueBool.o
Building ValueSchedule.o
Building ValueShort.o
Building Wait.o
Building Thread.o
Building Controller.o
Building Stream.o
Building Log.o
Building HidController.o
Building Mutex.o
Building SerialController.o
Building Event.o
Building FileOps.o
Building TimeStamp.o
Building FileOpsImpl.o
Building TimeStampImpl.o
Building WaitImpl.o
Building ThreadImpl.o
Building LogImpl.o
Building MutexImpl.o
Building SerialControllerImpl.o
Building EventImpl.o
Building Options.o
Building Scene.o
Building Utils.o
Building Driver.o
Building ZWSecurity.o
Building Group.o
Building Node.o
Building Manager.o
Building Msg.o
Building Notification.o
Creating vers.cpp
Building vers.o
Linking Static Library
Linking Shared Library
Making ozw_config file
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/build'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/examples/MinOZW/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
Building Main.o
Linking /opt/python-openzwave/openzwave/.lib/MinOZW
g++ -o /opt/python-openzwave/openzwave/.lib/MinOZW /opt/python-openzwave/openzwave/.lib/Main.o /opt/python-openzwave/openzwave/libopenzwave.so -pthread
Creating Temporary Shell Launch Script
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
make[1]: Leaving directory '/opt/python-openzwave/openzwave'
python setup-lib.py build
running build
running build_ext
cythoning src-lib/libopenzwave/libopenzwave.pyx to src-lib/libopenzwave/libopenzwave.cpp
/usr/lib/python2.7/dist-packages/Cython/Compiler/Main.py:367: FutureWarning: Cython directive 'language_level' not set, using 2 for now (Py2). This will change in a later release! File: /opt/python-openzwave/src-lib/libopenzwave/libopenzwave.pyx
tree = Parsing.p_module(s, pxd, full_module_name)
building 'libopenzwave' extension
creating build
creating build/temp.linux-armv7l-2.7
creating build/temp.linux-armv7l-2.7/src-lib
creating build/temp.linux-armv7l-2.7/src-lib/libopenzwave
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-RT6aMn/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DPY_SSIZE_T_CLEAN=1 -Iopenzwave/cpp/src/ -Iopenzwave/cpp/src/value_classes/ -Iopenzwave/cpp/src/platform/ -Iopenzwave/cpp/build/linux/ -I/usr/include/python2.7 -c src-lib/libopenzwave/libopenzwave.cpp -o build/temp.linux-armv7l-2.7/src-lib/libopenzwave/libopenzwave.o
cc1plus: warning: command line option '-Wstrict-prototypes' is valid for C/ObjC but not for C++
src-lib/libopenzwave/libopenzwave.cpp:3: warning: "PY_SSIZE_T_CLEAN" redefined
#define PY_SSIZE_T_CLEAN
<command-line>: note: this is the location of the previous definition
In file included from openzwave/cpp/src/aes/aescpp.h:26,
from openzwave/cpp/src/Driver.h:42,
from src-lib/libopenzwave/libopenzwave.cpp:638:
openzwave/cpp/src/aes/aes.h:75: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( disable : 4324 )
openzwave/cpp/src/aes/aes.h:93: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( default : 4324 )
src-lib/libopenzwave/libopenzwave.cpp: In function 'PyObject* __pyx_pf_12libopenzwave_9PyManager_268beginControllerCommand(__pyx_obj_12libopenzwave_PyManager*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*)':
src-lib/libopenzwave/libopenzwave.cpp:30325:204: warning: 'bool OpenZWave::Manager::BeginControllerCommand(uint32, OpenZWave::Driver::ControllerCommand, OpenZWave::Driver::pfnControllerCallback_t, void*, bool, uint8, uint8)' is deprecated [-Wdeprecated-declarations]
__pyx_t_6 = __Pyx_PyBool_FromLong(__pyx_v_self->manager->BeginControllerCommand(__pyx_t_1, __pyx_t_2, __pyx_f_12libopenzwave_ctrl_callback, ((void *)__pyx_v_pythonfunc), __pyx_t_3, __pyx_t_4, __pyx_t_5)); if (unlikely(!__pyx_t_6)) __PYX_ERR(0, 4120, __pyx_L1_error)
In file included from src-lib/libopenzwave/libopenzwave.cpp:643:
openzwave/cpp/src/Manager.h:1731:19: note: declared here
DEPRECATED bool BeginControllerCommand( uint32 const _homeId, Driver::ControllerCommand _command, Driver::pfnControllerCallback_t _callback = NULL, void* _context = NULL, bool _highPower = false, uint8 _nodeId = 0xff, uint8 _arg = 0 );
creating build/lib.linux-armv7l-2.7
arm-linux-gnueabihf-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-RT6aMn/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security -Wl,-z,relro -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-RT6aMn/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security build/temp.linux-armv7l-2.7/src-lib/libopenzwave/libopenzwave.o openzwave/libopenzwave.a -ludev -lstdc++ -o build/lib.linux-armv7l-2.7/libopenzwave.so
python setup-lib.py install
running install
running bdist_egg
running egg_info
creating src-lib/libopenzwave.egg-info
writing requirements to src-lib/libopenzwave.egg-info/requires.txt
writing src-lib/libopenzwave.egg-info/PKG-INFO
writing top-level names to src-lib/libopenzwave.egg-info/top_level.txt
writing dependency_links to src-lib/libopenzwave.egg-info/dependency_links.txt
writing manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
reading manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-armv7l/egg
running install_lib
running build_ext
skipping 'src-lib/libopenzwave/libopenzwave.cpp' Cython extension (up-to-date)
creating build/bdist.linux-armv7l
creating build/bdist.linux-armv7l/egg
copying build/lib.linux-armv7l-2.7/libopenzwave.so -> build/bdist.linux-armv7l/egg
creating stub loader for libopenzwave.so
byte-compiling build/bdist.linux-armv7l/egg/libopenzwave.py to libopenzwave.pyc
installing package data to build/bdist.linux-armv7l/egg
running install_data
creating build/bdist.linux-armv7l/egg/config
creating build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/not-zip-safe -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/requires.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
writing build/bdist.linux-armv7l/egg/EGG-INFO/native_libs.txt
creating dist
creating 'dist/libopenzwave-0.3.1-py2.7-linux-armv7l.egg' and adding 'build/bdist.linux-armv7l/egg' to it
removing 'build/bdist.linux-armv7l/egg' (and everything under it)
Processing libopenzwave-0.3.1-py2.7-linux-armv7l.egg
creating /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
Extracting libopenzwave-0.3.1-py2.7-linux-armv7l.egg to /usr/local/lib/python2.7/dist-packages
Adding libopenzwave 0.3.1 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
Processing dependencies for libopenzwave==0.3.1
Searching for six==1.16.0
Best match: six 1.16.0
Adding six 1.16.0 to easy-install.pth file
Using /usr/local/lib/python2.7/dist-packages
Finished processing dependencies for libopenzwave==0.3.1
Installation of lib finished.
python setup-api.py install
running install
running bdist_egg
running egg_info
creating src-api/openzwave.egg-info
writing requirements to src-api/openzwave.egg-info/requires.txt
writing src-api/openzwave.egg-info/PKG-INFO
writing top-level names to src-api/openzwave.egg-info/top_level.txt
writing dependency_links to src-api/openzwave.egg-info/dependency_links.txt
writing manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
reading manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
running install_lib
running build_py
creating build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/__init__.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/network.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/node.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/option.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/controller.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/scene.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/singleton.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/command.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/group.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/value.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/object.py -> build/lib.linux-armv7l-2.7/openzwave
creating build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/__init__.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/network.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/node.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/option.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/controller.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/scene.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/singleton.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/command.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/group.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/value.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/object.py -> build/bdist.linux-armv7l/egg/openzwave
byte-compiling build/bdist.linux-armv7l/egg/openzwave/__init__.py to __init__.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/network.py to network.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/node.py to node.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/option.py to option.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/controller.py to controller.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/scene.py to scene.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/singleton.py to singleton.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/command.py to command.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/group.py to group.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/value.py to value.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/object.py to object.pyc
copying src-api/openzwave.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/not-zip-safe -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/requires.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
creating 'dist/openzwave-0.3.1-py2.7.egg' and adding 'build/bdist.linux-armv7l/egg' to it
Processing openzwave-0.3.1-py2.7.egg
creating /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Extracting openzwave-0.3.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages
Adding openzwave 0.3.1 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Processing dependencies for openzwave==0.3.1
Searching for libopenzwave==0.3.1
Best match: libopenzwave 0.3.1
libopenzwave 0.3.1 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
Searching for Louie==1.1
Best match: Louie 1.1
Adding Louie 1.1 to easy-install.pth file
Using /usr/lib/python2.7/dist-packages
Finished processing dependencies for openzwave==0.3.1
Installation of API finished.
Everything is successfully installed!
+ echo 12
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end openzwave
+ rm /tmp/jeedom_install_in_progress_openzwave
