sur une fresh install jeedom 4 sur debian 10, j’ai installer le plugin gcat (officiel)
impossible de faire parler ma GH
j’ai fait la config avec le moteur TTS « jeedom »
voici le debug log:
[2019-11-06 22:29:19][DEBUG] : /usr/bin/python /var/www/html/plugins/gcast/core/class/../../resources/action.py parle 172.17.247.103 "je parle pas " "http://172.17.247.245:80" /tmp/jeedom/tts/36dbaefe4f9b9a2a8459a18f522f7e27.mp3 jeedom >> /var/www/html/core/class/../../log/gcast 2>&1 &
/var/www/html/plugins/gcast/resources/pydub/utils.py:165: RuntimeWarning: Couldn't find ffmpeg or avconv - defaulting to ffmpeg, but may not work
warn("Couldn't find ffmpeg or avconv - defaulting to ffmpeg, but may not work", RuntimeWarning)
File "/var/www/html/plugins/gcast/core/class/../../resources/action.py", line 94, in <module>
actions[sys.argv[1]]()
File "/var/www/html/plugins/gcast/core/class/../../resources/action.py", line 72, in parle
song = AudioSegment.from_mp3(sys.argv[5])
File "/var/www/html/plugins/gcast/resources/pydub/audio_segment.py", line 358, in from_mp3
return cls.from_file(file, 'mp3')
File "/var/www/html/plugins/gcast/resources/pydub/audio_segment.py", line 307, in from_file
file = _fd_or_path_or_tempfile(file, 'rb', tempfile=False)
File "/var/www/html/plugins/gcast/resources/pydub/utils.py", line 59, in _fd_or_path_or_tempfile
fd = open(fd, mode=mode)
IOError: [Errno 2] No such file or directory: '/tmp/jeedom/tts/36dbaefe4f9b9a2a8459a18f522f7e27.mp3'
sa coince encore, il faut aussi installer avconv ?
le debug:
[2019-11-06 23:03:47][DEBUG] : /usr/bin/python /var/www/html/plugins/gcast/core/class/../../resources/action.py parle 172.17.247.103 "coucou" "http://172.17.247.245:80" /tmp/jeedom/tts/721a9b52bfceacc503c056e3b9b93cfa.mp3 jeedom >> /var/www/html/core/class/../../log/gcast 2>&1 &
IOError: [Errno 2] No such file or directory: '/tmp/jeedom/tts/721a9b52bfceacc503c056e3b9b93cfa.mp3'
merci
EDIT:
j’ai tester le chemin: /tmp/jeedom/tts/721a9b52bfceacc503c056e3b9b93cfa.mp3
jusque /tmp/jeedom → OK
quand je veux aller dans /tmp/jeedom/tts → Permission non accordée
Je suis debutant en linux, je suis avec mon compte admin mais qui n’a pas les droits.
un changement a faire pour autoriser jeedom à accèder à ce folder ?
Voilà les commandes sont passée et voici le résultat:
hanscadm@Jeedom-prod-01:~$
hanscadm@Jeedom-prod-01:~$ sudo apt-get -y install libsox-fmt-mp3 sox libttspico-utils
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
libsox-fmt-mp3 est déjà la version la plus récente (14.4.2+git20190427-1).
sox est déjà la version la plus récente (14.4.2+git20190427-1).
libttspico-utils est déjà la version la plus récente (1.0+git20130326-9).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
hanscadm@Jeedom-prod-01:~$ a
-bash: a : commande introuvable
hanscadm@Jeedom-prod-01:~$ sudo apt-get -y install espeak
espeak est déjà la version la plus récente (1.48.04+dfsg-7).
hanscadm@Jeedom-prod-01:~$ sudo apt-get -y install mbrola
Aucune version du paquet mbrola n'est disponible, mais il existe dans la base
de données. Cela signifie en général que le paquet est manquant, qu'il est devenu obsolète
ou qu'il n'est disponible que sur une autre source
E: Le paquet « mbrola » n'a pas de version susceptible d'être installée
bon petit changement de config, avec la config jeedom sa ne fonctionne pas, j’ai remis la config sur picotts et voix en FR là je parvient bien à faire parler la GH
le log debug avec les 2 test:
[2019-11-07 18:20:03][DEBUG] : /usr/bin/python /var/www/html/plugins/gcast/core/class/../../resources/action.py parle 172.17.247.103 "coucou" "http://172.17.247.245:80" /tmp/jeedom/tts/721a9b52bfceacc503c056e3b9b93cfa.mp3 jeedom >> /var/www/html/core/class/../../log/gcast 2>&1 &
[2019-11-07 18:21:18][DEBUG] : /usr/bin/python /var/www/html/plugins/gcast/core/class/../../resources/action.py parle 172.17.247.103 "coucou" "http://172.17.247.245:80" fr-FR picotts >> /var/www/html/core/class/../../log/gcast 2>&1 &
[2019-11-07 18:21:38][DEBUG] : /usr/bin/python /var/www/html/plugins/gcast/core/class/../../resources/action.py parle 172.17.247.103 "bonjour je suis la Google home" "http://172.17.247.245:80" fr-FR picotts >> /var/www/html/core/class/../../log/gcast 2>&1 &
