Je suis sous Jeedom 4.1.27 raspberry 3b debian 10
jmqtt pour MQTT
conbee II avec rallonge urb
32 périphériques zigbee multimarque avec plusieurs routeurs
J’ai un plantage suite à une inclusion d’un module Ikea, similaire à ce post: « Zigbee2mqtt est arreté » et ne démarre plus après une inclusion avec Zigbeelinker - Plugins / Protocole domotique - Communauté Jeedom
Voici le log en mode debug lors de l’inclusion:
[32mZigbee2MQTT:info e[39m 2021-11-25 19:12:44: MQTT publish: topic 'zigbee2mqtt/Lumière Douche', payload '{"device":{"applicationVersion":11,"dateCode":"01-12-2021","friendlyName":"Lumière Douche","hardwareVersion":1,"ieeeAddr":"0x54ef4410000fd324","manufacturerID":4447,"manufacturerName":"LUMI","model":"WS-EUK01","networkAddress":45943,"powerSource":"Mains (single phase)","stackVersion":2,"type":"EndDevice","zclVersion":3},"linkquality":255,"operation_mode":"control_relay","power_outage_memory":false,"state":"OFF","temperature":23}'
2021-11-25T18:12:47.616Z zigbee-herdsman:deconz:driver send read device state from queue. seqNr: 41
2021-11-25T18:12:47.619Z zigbee-herdsman:deconz:frameParser device state: 10100010
2021-11-25T18:12:47.619Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-11-25T18:12:57.617Z zigbee-herdsman:deconz:driver send read device state from queue. seqNr: 42
2021-11-25T18:12:57.619Z zigbee-herdsman:deconz:frameParser device state: 10100010
2021-11-25T18:12:57.620Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-11-25T18:13:05.817Z zigbee-herdsman:deconz:frameParser DEVICE_STATE changed: 10101010
2021-11-25T18:13:05.818Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
2021-11-25T18:13:05.821Z zigbee-herdsman:deconz:driver query aps data indication
2021-11-25T18:13:05.825Z zigbee-herdsman:deconz:driver DATA_INDICATION - sending read data request - SeqNr. 43
2021-11-25T18:13:05.829Z zigbee-herdsman:deconz:frameParser DATA_INDICATION RESPONSE - seqNr. 43 srcAddr: 0x5e7 destAddr: 0xfffd profile id: 0x0 cluster id: 0x13 lqi: 255
2021-11-25T18:13:05.829Z zigbee-herdsman:deconz:frameParser response payload: 129,231,5,194,204,204,254,255,80,75,128,142
2021-11-25T18:13:05.832Z zigbee-herdsman:controller:log Device '0x804b50fffeccccc2' joined
2021-11-25T18:13:05.833Z zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
2021-11-25T18:13:05.833Z zigbee-herdsman:controller:log Device '0x804b50fffeccccc2' accepted by handler
2021-11-25T18:13:05.833Z zigbee-herdsman:controller:log New device '0x804b50fffeccccc2' joined
2021-11-25T18:13:05.834Z zigbee-herdsman:controller:log Creating device '0x804b50fffeccccc2'
TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be of type string. Received undefined
at new NodeError (internal/errors.js:322:7)
at validateString (internal/validators.js:124:11)
at Object.join (path.js:1148:7)
at Object.joinPath (/opt/zigbee2mqtt/lib/util/data.ts:17:17)
at writeDevicesOrGroups (/opt/zigbee2mqtt/lib/util/settings.ts:205:38)
at write (/opt/zigbee2mqtt/lib/util/settings.ts:211:5)
at Object.addDevice (/opt/zigbee2mqtt/lib/util/settings.ts:512:5)
at Device.ensureInSettings (/opt/zigbee2mqtt/lib/model/device.ts:28:22)
at Zigbee.resolveDevice (/opt/zigbee2mqtt/lib/zigbee.ts:230:20)
at Controller.<anonymous> (/opt/zigbee2mqtt/lib/zigbee.ts:88:33)
Après ça le daemon s’arrête et le seul moyen pour qu’il reparte est de supprimer dans Database la dernière ligne de ce type:
{"id":45,"type":"Unknown","ieeeAddr":"0x804b50fffeccccc2","nwkAddr":1511,"epList":[],"endpoints":{},"interviewCompleted":false,"meta":{},"lastSeen":null}
J’ai essayé avec un capteur d’une autre marque et même résultat.
Une piste?
Bien sur j’ai déjà désinstallé zigbee2mqtt
merci d’avance
