J’ai essayé aujourd’hui de passer du plugin deconz à JeeZigbee mais j’ai un problème avec le plugin mqtt-manager.
Après de multiples relances je n’arrive pas à installer les dépendances du plugin mqtt-manager.
Je suis sur une VM sur un nas synology.
Voici les logs :
Log mqtt2_packages
+ touch /tmp/jeedom_install_in_progress_mqtt2
+ echo 1
+ echo 2
Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
Get:2 http://deb.debian.org/debian buster InRelease [122 kB]
Get:3 http://deb.debian.org/debian buster-updates InRelease [56.6 kB]
Hit:4 http://phoscon.de/apt/deconz buster InRelease
Reading package lists...
E: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://deb.debian.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://deb.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'oldstable-updates' to 'oldoldstable-updates'
Building dependency tree...
Reading state information...
apt-utils is already the newest version (1.8.2.3).
build-essential is already the newest version (12.6).
git is already the newest version (1:2.20.1-2+deb10u3).
lsb-release is already the newest version (10.2019051400).
0 upgraded, 0 newly installed, 0 to remove and 204 not upgraded.
[Check Version NodeJS actuelle : v10.24.0 : [ KO ]
Installation de NodeJS 16
Utilisation du dépot officiel
## Installing the NodeSource Node.js 16.x repo...
## Populating apt-get cache...
+ apt-get update
Hit:3 http://phoscon.de/apt/deconz buster InRelease
Get:4 http://deb.debian.org/debian buster-updates InRelease [56.6 kB]
Error executing command, exiting
The following additional packages will be installed:
libc-ares2 libnode64 nodejs-doc
Suggested packages:
npm
libc-ares2 libnode64 nodejs nodejs-doc
0 upgraded, 4 newly installed, 0 to remove and 204 not upgraded.
Need to get 0 B/6778 kB of archives.
After this operation, 30.8 MB of additional disk space will be used.
Selecting previously unselected package libc-ares2:amd64.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 63278 files and directories currently installed.)
Preparing to unpack .../libc-ares2_1.14.0-1+deb10u1_amd64.deb ...
Unpacking libc-ares2:amd64 (1.14.0-1+deb10u1) ...
Selecting previously unselected package libnode64:amd64.
Preparing to unpack .../libnode64_10.24.0~dfsg-1~deb10u1_amd64.deb ...
Unpacking libnode64:amd64 (10.24.0~dfsg-1~deb10u1) ...
Selecting previously unselected package nodejs.
Preparing to unpack .../nodejs_10.24.0~dfsg-1~deb10u1_amd64.deb ...
Unpacking nodejs (10.24.0~dfsg-1~deb10u1) ...
Selecting previously unselected package nodejs-doc.
Preparing to unpack .../nodejs-doc_10.24.0~dfsg-1~deb10u1_all.deb ...
Unpacking nodejs-doc (10.24.0~dfsg-1~deb10u1) ...
Setting up libc-ares2:amd64 (1.14.0-1+deb10u1) ...
Setting up libnode64:amd64 (10.24.0~dfsg-1~deb10u1) ...
Setting up nodejs-doc (10.24.0~dfsg-1~deb10u1) ...
Setting up nodejs (10.24.0~dfsg-1~deb10u1) ...
update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
Processing triggers for libc-bin (2.28-10) ...
Processing triggers for man-db (2.8.5-2) ...
[Check Version NodeJS après install : v10.24.0 : [ KO ] -> relancez les dépendances
gyp libjs-inherits libjs-is-typedarray libnode-dev libuv1-dev node-abbrev
node-ajv node-ansi node-ansi-align node-ansi-regex node-ansi-styles
node-ansistyles node-aproba node-archy node-are-we-there-yet node-asn1
node-assert-plus node-asynckit node-aws-sign2 node-aws4 node-balanced-match
node-bcrypt-pbkdf node-bluebird node-boxen node-brace-expansion
node-builtin-modules node-builtins node-cacache node-call-limit
node-camelcase node-caseless node-chalk node-chownr node-cli-boxes
node-cliui node-clone node-co node-color-convert node-color-name
node-combined-stream node-concat-map node-concat-stream node-config-chain
node-console-control-strings node-copy-concurrently node-core-util-is
node-cross-spawn node-cyclist node-dashdash node-decamelize
node-decompress-response node-deep-extend node-defaults node-delayed-stream
node-delegates node-detect-indent node-detect-newline node-duplexer3
node-duplexify node-ecc-jsbn node-editor node-encoding node-end-of-stream
node-errno node-escape-string-regexp node-execa node-extend node-extsprintf
node-find-up node-flush-write-stream node-forever-agent node-form-data
node-from2 node-fs-vacuum node-fs-write-stream-atomic node-fs.realpath
node-gauge node-get-caller-file node-get-stream node-getpass node-glob
node-got node-graceful-fs node-gyp node-har-schema node-har-validator
node-has-flag node-has-symbol-support-x node-has-to-string-tag-x
node-has-unicode node-hosted-git-info node-http-signature node-iconv-lite
node-iferr node-import-lazy node-imurmurhash node-inflight node-inherits
node-ini node-invert-kv node-is-builtin-module node-is-npm node-is-object
node-is-plain-obj node-is-retry-allowed node-is-stream node-is-typedarray
node-isarray node-isexe node-isstream node-isurl node-jsbn
node-json-parse-better-errors node-json-schema node-json-stable-stringify
node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream
node-jsprim node-latest-version node-lazy-property node-lcid node-libnpx
node-locate-path node-lockfile node-lowercase-keys node-lru-cache node-mem
node-mime-types node-mimic-fn node-mimic-response node-minimatch
node-minimist node-mississippi node-mkdirp node-move-concurrently
node-mute-stream node-node-uuid node-nopt node-normalize-package-data
node-npm-package-arg node-npm-run-path node-npmlog node-oauth-sign
node-object-assign node-once node-opener node-os-locale node-osenv
node-p-cancelable node-p-finally node-p-limit node-p-locate node-p-timeout
node-package-json node-parallel-transform node-path-exists
node-path-is-absolute node-path-is-inside node-performance-now
node-prepend-http node-process-nextick-args node-promise-inflight
node-promzard node-proto-list node-prr node-pump node-pumpify node-punycode
node-qs node-qw node-rc node-read node-read-package-json
node-readable-stream node-registry-auth-token node-registry-url node-request
node-require-directory node-require-main-filename node-resolve-from
node-retry node-rimraf node-run-queue node-safe-buffer node-semver
node-semver-diff node-set-blocking node-sha node-shebang-command
node-shebang-regex node-signal-exit node-slash node-slide node-sorted-object
node-spdx-correct node-spdx-expression-parse node-spdx-license-ids
node-sshpk node-ssri node-stream-each node-stream-iterate node-stream-shift
node-string-decoder node-string-width node-strip-ansi node-strip-eof
node-strip-json-comments node-supports-color node-tar node-term-size
node-text-table node-through node-through2 node-timed-out node-tough-cookie
node-tunnel-agent node-tweetnacl node-typedarray node-uid-number
node-unique-filename node-unpipe node-url-parse-lax node-url-to-options
node-util-deprecate node-uuid node-validate-npm-package-license
node-validate-npm-package-name node-verror node-wcwidth.js node-which
node-which-module node-wide-align node-widest-line node-wrap-ansi
node-wrappy node-write-file-atomic node-xdg-basedir node-xtend node-y18n
node-yallist node-yargs node-yargs-parser
node-yallist node-yargs node-yargs-parser npm
0 upgraded, 245 newly installed, 0 to remove and 204 not upgraded.
Need to get 9836 B/3699 kB of archives.
After this operation, 19.9 MB of additional disk space will be used.
Err:1 http://deb.debian.org/debian buster/main amd64 node-end-of-stream all 1.4.1-1
404 Not Found [IP: 2a04:4e42:6a::644 80]
Err:2 http://deb.debian.org/debian buster/main amd64 node-minimist all 1.2.0-1+deb10u1
E: Failed to fetch http://deb.debian.org/debian/pool/main/n/node-end-of-stream/node-end-of-stream_1.4.1-1_all.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
E: Failed to fetch http://deb.debian.org/debian/pool/main/n/node-minimist/node-minimist_1.2.0-1+deb10u1_all.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
sudo: npm: command not found
+ echo 3
Get:1 http://deb.debian.org/debian buster InRelease [122 kB]
Get:2 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
+ apt-get update
Suggested packages:
npm
+ echo 4
+ cd /var/www/html/core/class/../../plugins/mqtt2/resources/mqtt2d
+ rm -rf node_modules
+ sudo npm install
+ chown -R www-data:www-data jeedom mqtt2d.js package.json
+ echo 5
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end mqtt2
Synchronizing state of mosquitto.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable mosquitto
+ rm /tmp/jeedom_install_in_progress_mqtt2
Log mqtt2d
internal/modules/cjs/loader.js:638
throw err;
Error: Cannot find module 'request'
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
at Function.Module._load (internal/modules/cjs/loader.js:562:25)
at Module.require (internal/modules/cjs/loader.js:692:17)
at require (internal/modules/cjs/helpers.js:25:18)
at Object. (/var/www/html/plugins/mqtt2/resources/mqtt2d/jeedom/jeedom.js:17:17)
at Module._compile (internal/modules/cjs/loader.js:778:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
at Module.load (internal/modules/cjs/loader.js:653:32)
at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
at Function.Module._load (internal/modules/cjs/loader.js:585:3)
throw err;
Voici une image de l’onglet santé :
Merci d’avance pour votre retour.
Bonne journée
