HUAWEI E3372-320 + Pugin SMS : Clé non détectée
Je poste ici car après avoir parcouru le forum et le net, je reste bloqué sur mon souci qui est le suivant :
Ma clé HUAWEI E3372-320 n’est pas détectée dans le plugin Jeeddom SMS.
** Les tests que j’ai déjà effectué **
  • lsusb
Bus 001 Device 004: ID 12d1:14db Huawei Technologies Co., Ltd. E353/E3131
  • dmesg | grep HUAWEI
RIEN
  • dmesg | grep USB
[ 0.672043] ehci_hcd: USB 2.0 ‹ Enhanced › Host Controller (EHCI) Driver
[ 0.672165] ohci_hcd: USB 1.1 ‹ Open › Host Controller (OHCI) Driver
[ 0.672240] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.672465] usbserial: USB Serial support registered for generic
[ 0.674125] usbhid: USB HID core driver
[ 2.480171] dwc_otg dwc2_b: new USB bus registered, assigned bus number 1
[ 2.505486] hub 1-0:1.0: USB hub found
[ 2.563115] dwc_otg dwc2_a: new USB bus registered, assigned bus number 2
[ 2.575224] hub 2-0:1.0: USB hub found
[ 2.893984] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.178895] hub 1-1:1.0: USB hub found
[ 18.724052] usb 1-1.3: new high-speed USB device number 3 using dwc_otg
[ 18.826654] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[ 19.846585] usb 1-1.3: USB disconnect, device number 3
[ 20.514032] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
  • dmesg | grep usb
[ 0.232071] usbcore: registered new interface driver usbfs
[ 0.232116] usbcore: registered new interface driver hub
[ 0.232193] usbcore: registered new device driver usb
[ 0.671839] usbcore: registered new interface driver cdc_ether
[ 0.671909] usbcore: registered new interface driver cdc_ncm
[ 0.672230] usbcore: registered new interface driver cdc_acm
[ 0.672294] usbcore: registered new interface driver usb-storage
[ 0.672397] usbcore: registered new interface driver usbserial
[ 0.672429] usbcore: registered new interface driver usbserial_generic
[ 0.674115] usbcore: registered new interface driver usbhid
[ 2.445476] dwc_otg: usb1: type: 1 speed: 0, config: 0, dma: 0, id: 1, phy: c0000020, ctrl: 0
[ 2.512779] dwc_otg: usb0: type: 0 speed: 0, config: 0, dma: 0, id: 0, phy: c0000000, ctrl: 0
[ 18.829347] scsi0 : usb-storage 1-1.3:1.0
[ 20.693651] cdc_ether 1-1.3:1.0 eth1: register ‹ cdc_ether › at usb-dwc2_b-1.3, CDC Ethernet Device, 00:1e:10:1f:00:00
  • Créé le fichier « 12d1:1f01 » + reboot
Dans « /etc/usb_modeswitch.d », j’ai créé le fichier « 12d1:1f01 » avec le contenu suivant :
TargetVendor=0x12d1
TargetProduct=0x14db
MessageContent=« 55534243123456780000000000000011063000000100010000000000000000 »
Résultat : Après reboot, toujours pareil, la clé n’est pas détectée
  • Essayé de changer le firmware
En suivant le tuto : Huawei E3372 : installer / mettre à jour le firmware HiLink ou Stick – Le Crabe Info
Par contre, j’ai une clé E3372-320 et non E3372-153, du coup, est-ce-que c’est compatible ?
Info « DC Unlocker » :
Version matérielle CL4E3372HM
Version logicielle 10.0.3.1(H192SP1C983)
Version UI WebWEBUI 10.0.3.1(W13SP2C7110)
Version du fichier de configuration E3372h-320-CUST 10.0.3.2(C1217)
Adresse IP WANInconnu
Adresse IPv6 WANInconnu
Résultat : Impossible de passer la clé en mode « Project Mode »
  • usb_modeswitch
J’ai lancé :
usb_modeswitch -v 12d1 -p 14db -M 55534243123456780000000000000011063000000100010000000000000000
Résultat :
Look for default devices …
Found devices in default mode (1)
Access device 004 on bus 001
Get the current device configuration …
Current configuration number is 1
Use interface number 0
with class 2
Error: can’t use storage command in MessageContent with interface 0; interface class is 2, expected 8. Abort
Bref, je ne sais plus quoi faire, si quelqu’un a une idée, je suis preneur :slight_smile:
Par avance merci
As tu regardé du coté du tuto d’ @akenad ?
Oui, j’ai aussi fait suivi ce topic, mais je ne sais pas comment interpréter cette phrase :
la clé est reconnue par défaut. (/!\ ATTENTION : pas le modèle E3372H-320)
Ma clé est compatible et pas reconnue par défaut ou c’est entièrement foutu ?
Attention @LuffyyffuL pas exactement !
Le tuto d’ @akenad fait bien la différence entre 2 modèle de clef Huawei E3372 et E3531.
Tu n’as pas copié le bon code en générant le fichier « 12d1:1f01 », si tu relis bien ton message et le tuto, tu as copié un mauvais code…
Il faut faire ça:
vérifier que le paquet usb-modeswitch est installé, sinon l’installer.
Pour la E3372 :
Créer le fichier /etc/usb_modeswitch.d/12d1:1f01 avec comme contenu :
# Huawei E3372s-153 ou E3372h-153 switch mode vers 12d1:1442 (mode GSM modem) :
TargetVendor=0x12d1
Targetproduct=0x1f01
MessageContent="55534243000000000000000000000011060000000000000000000000000000"
@LuffyyffuL as-tu essayé ?
Bonjour, oui, j’ai réesayé mais ça ne marche toujours pas, du coup, j’ai renvoyé la clé :confused:
Merci pour votre aide
J’ai également des problèmes de façon aléatoires (interruption démon),
cela arrive au bout de 2-3 jours d’utilisation.
Pour l’instant, la solution que j’ai trouvé est de redémarrer le Pi tous les soirs… pas l’idéal ! :thinking:
Bonjour a tous,
J’ai la même clef, E3372h-320 et impossible de m’en sortir avec.
Elle n’est pas reconnue sur ma jeedom, j’ai suivi les différents tutoriels que j’ai pu trouver, mais sans flasher le firmware. Je n’en viens pas à bout.
J’aimerai beaucoup persévérer et trouver une solution pour les E3372-320 deux commandes, deux 320 reçues.
Je ne sais plus par ou prendre le bout pour finaliser tout ça.
Si quelqu’un veut bien passer de son temps pour m’aider à éclaircir tout ça…
A bientôt
@johan99 :
Voici le lien que j’ai suivi (merci à @Klan), pour faire fonctionner ma clé E3372H-320
https://community.jeedom.com/t/re-sms-jeedom-pas-de-reception-e3372h-320/33426/2?u=loutre38
Bon courage.
ce lien n’existe pas ou est privé, ou puis-je trouver l’info ?
Merci pour la réponse.
ça a marché pour moi : Using a Huawei WWAN dongle on Linux · GitHub
Merci pour l’info…
Je met à jour suite à mes dernières modifications matérielles, si ça peut vous aider.
Matériel :
  • Nuc sous Proxmox hébergeant une VM Jeedom
  • une clé huawei E3372h-320 branchée sur un hub usb alimenté
  • une sim Free à 2 euros
  • le plugin SMS de Jeedom installé sur Debian 11
Etape 1 : On branche la clé sur le Nuc
Dans la console Proxmox en root (/!\ ça ne marche pas sur la VM) :
apt install usb_modeswitch
nano /etc/usb_modeswitch.d/12d1:1f01
Et vous y coller ça:
# Huawei E353 (3.se) and others
# Switch from default mass storage device mode 12d1:1f01 to …
TargetVendor=0x12d1
# WWAN mode 12d1:155e
TargetProduct=0x155e
MessageContent="55534243123456780000000000000011063000000100010000000000000000"
# Broadband modem mode 12d1:1442
#TargetProduct=0x1442
#MessageContent="55534243000000000000000000000011060000000000000000000000000000"
# « ethernet » mode
#TargetProductList="14db,14dc"
#HuaweiNewMode=1
Ensuite on redémarre le Nuc pour que la config soit pris en compte.
Etape 3 : Associer la clé à la VM
Dans Proxmox, il faut aller sur la VM Jeedom.
Dans Hardware → Add → USB Device
Use USB Vendor/Device ID
Et la votre clé doit apparaitre sous la forme 12d1:155e (mode WWAN)
Valider votre association.
Etape 4 : Configuration du plugin SMS de Jeedom
Pour le port 3 valeurs apparaissent, il faut les essayer les unes après les autres jusqu’à ce que le démon passe au vert, la 3ème a été la bonne pour moi.
Port SMS : HUAWEI_MOBILE HUAWEI_MOBILE 3
Vitesse de communication (bauds) : 115200
Code pin (laisser vide s’il n’y en a pas) : ••••
Texte mode : décoché
Découper les messages par paquet de caractères : 140
Passerelle SMS / SMS Gateway (en cas d’erreur : CMS 330 SMSC number not set) :
Force du signal : 15 / 30
Réseau : Free
Port socket interne : 55002 (laisser la valeur par défaut)
Cycle (s) : 30
L’erreur CMS 302 est probablement provoquée par la passerelle SMS, à laisser vide.
Une fois cela fait on relance le démon et tout doit être au vert.
Etape 5 : Créer un user
Dans le plugin SMS on ajoute un nouveau user. On lui donne un petit nom. On l’active on le rend visible. On lui met un objet parent.
Dans commande, on laisse les commandes existantes et on ajoute un numéro:
On définit un Nom, un Nom d’utilisateur et un Téléphone du destinataire du SMS au format +336012345678
Etape 5 : Envoi de SMS
On va dans le dashboard, on repère notre nouvel objet. On saisit un message dans la zone texte et on clique sur l’utilisateur pour lui envoyer le SMS. Et là ça fonctionne.
Etape 5 bis : si jamais cela ne fonctionne toujours pas il peur être judicieux d’aller voir dans réglages–> système → configuration–>réseaux et s’assurer que l’adresse défini est bien une IP du type 192.168.X.X, cela ne fonctionne pas avec un localhost ou un 127.0.0.1.
Voilà j’ai pris 15 min pour formaliser la prise de tête de 3 jours à parcourir tous les forums.
J’espère que ça vous fera perdre moins de temps et que vous ne balancerez pas votre clé à la poubelle ou dans un mur :wink:
Quand tu parle de clé h-320 reconnue avec un libellé HiLink tu parles de ca ?
Si oui je suis bon pour faire la suite du tuto ?
Ou il faut regarder dans les périphériques du PC ?
Merci d’avance,
Sans effectuer de modification sur Jeedom, en remplaçant ma clé h-153 par une h-320, ca fonctionne direct.
A voir sur le long terme. Pour l’instant aucun problème.
Tu nous confirmes que tu n’as pas de démon qui tombe en NOK ou autre de temps en temps ?
J’ai la e3372-153 qui m’avait donné pas mal de fil à retordre. Je cherche une solution de remplacement pour le jour où elle me lâchera…
La E3372H-320 fonctionne très bien, elle tourne chez moi depuis 2ans et demi sans plantage
Merci, avais-tu mis en place quelquechose de particulier pour l’utiliser sur Jeedom ?
Pour moi elle fonctionne bien. Le demon est toujours Ok.
Mais pour moi la 153 fonctionnait tres bien aussi
