Yes j’ai suivi pas à pas, ce qui m’a facilité l’intégration de la platform, par contre je sèche après …
En relançant le daemon, j’ai ça :
[3/16/2021, 8:31:49 AM] [Jeedom] Initializing Jeedom platform...
[3/16/2021, 8:31:49 AM] [Jeedom] debugLevel:400
[3/16/2021, 8:31:49 AM] [Config] Initializing config platform...
[3/16/2021, 8:31:50 AM] [Config] Spawning homebridge-config-ui-x with PID 7396
[3/16/2021, 8:31:50 AM] [Broadlink RM] Initializing BroadlinkRM platform...
[3/16/2021, 8:31:50 AM] [Broadlink RM] e[35m[INFO]e[0m Automatically discovering Broadlink RM devices.
[3/16/2021, 8:31:50 AM] Loading 1 accessories...
[3/16/2021, 8:31:50 AM] Error loading accessory requested in your config.json at position 1
[3/16/2021, 8:31:50 AM] [Broadlink RM] No accessories have been added to the "Broadlink RM" platform config.
[3/16/2021, 8:31:50 AM] Initializing platform accessory 'Learn'...
[3/16/2021, 8:31:50 AM] Initializing platform accessory 'Scan Frequency'...
**[3/16/2021, 8:31:50 AM] Error: The requested accessory 'TV Test ' was not registered by any plugin.**
at PluginManager.getPluginForAccessory (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/src/pluginManager.ts:198:15)
at /var/www/html/plugins/homebridge/resources/node_modules/homebridge/src/server.ts:347:37
at Array.forEach (<anonymous>)
at Server._loadAccessories (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/src/server.ts:330:29)
at Server.start (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/src/server.ts:156:12)
at cli (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/src/cli.ts:80:10)
at Object.<anonymous> (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/bin/homebridge:17:22)
at Module._compile (internal/modules/cjs/loader.js:999:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
at Module.load (internal/modules/cjs/loader.js:863:32)
e[35m[INFO]e[0m Adding RF Support to device 780f77633d0f with type 279d
[3/16/2021, 8:31:50 AM] Got SIGTERM, shutting down Homebridge...
[3/16/2021, 8:31:50 AM] [Broadlink RM] e[35m[INFO]e[0m Discovered Broadlink RM3 Pro Plus (279d) at 192.XXX.XXX.XXX (78:0f:XX:XX:XX:XX)
[3/16/2021, 8:31:51 AM] [Broadlink RM]
[3/16/2021, 8:31:51 AM] [Broadlink RM] **************************************************************************************************************
[3/16/2021, 8:31:51 AM] [Broadlink RM] ** Welcome to version e[32m4.4.1e[0m of the e[34mHomebridge Broadlink RM Plugine[0m!
[3/16/2021, 8:31:51 AM] [Broadlink RM] ** Find out what's in the latest release here: e[4mhttps://github.com/kiwi-cam/homebridge-broadlink-rm/blob/master/CHANGELOG.mde[0m
[3/16/2021, 8:31:51 AM] [Broadlink RM] ** If you like this plugin then please star it on GitHub or better yet
[3/16/2021, 8:31:51 AM] [Broadlink RM] ** buy me a drink using Paypal e[4mhttps://paypal.me/kiwicamRMe[0m.
[3/16/2021, 8:31:51 AM] [Broadlink RM] ** You can disable this message by adding "hideWelcomeMessage": true to the config (see config-sample.json).
Ma platform est défini comme ça :
"platform": "BroadlinkRM",
"name": "Broadlink RM"
Et du coup j’ai mis (en suivant la doc de kiwicam) dans mes accessoires :
"accessory": "TV Test ",
"name": "TV On/Off",
"type": "switch",
"data": {
"off": "260050000001279512141114111412381213123911391213123812391114123813131139113913121213133812131213133713121313121312381312133713381213133713371338130005280001284a13000d050000000000000000",
"on" : "2600500000012596121410151015103a1114113a11391015103a113a1015113911141139113a11141015103a11141115103a101511141114113a1015103a11391114113a103a11391200052a0001254c12000d050000000000000000"
Et dès que je relance le deamon après avoir mis l’accessoire plus rien ne prend …
Je pense que mon souci vient de l’association platform/accessoire mais je ne sais pas faire.
Pour info les accessoire Learn IR et Scan Frequency sont des accessoire que la platform créée automatiquement
Merci d’avance pour ton coup de main
