C’est bien ce que j’ai fais actuellement :
Onglet Platforms :
"platform": "BroadlinkRM",
"name": "Broadlink RM",
"accessories": {
"name": "TV",
"type": "switch",
"data": {
"Eteindre": "260050000001279512141114111412381213123911391213123812391114123813131139113913121213133812131213133713121313121312381312133713381213133713371338130005280001284a13000d050000000000000000",
"Allumer": "2600500000012596121410151015103a1114113a11391015103a113a1015113911141139113a11141015103a11141115103a101511141114113a1015103a11391114113a103a11391200052a0001254c12000d050000000000000000"
Onglet Accessoire : (je ne peux pas le laisser vide sinon je peux pas le sauvegarder donc)
Et du coups les logs :
[3/16/2021, 11:23:20 AM] Got SIGTERM, shutting down Homebridge...
[3/16/2021, 11:23:34 AM] Loaded config.json with 1 accessories and 3 platforms.
[3/16/2021, 11:23:34 AM] ---
[3/16/2021, 11:23:35 AM] Loaded plugin: homebridge-jeedom@1.5.0
[3/16/2021, 11:23:38 AM] Registering platform 'homebridge-jeedom.Jeedom'
[3/16/2021, 11:23:38 AM] ---
[3/16/2021, 11:23:42 AM] Loaded plugin: homebridge-alexa@0.5.26
[3/16/2021, 11:23:42 AM] Registering platform 'homebridge-alexa.Alexa'
[3/16/2021, 11:23:42 AM] ---
[3/16/2021, 11:23:42 AM] Loaded plugin: homebridge-broadlink-rm-pro@4.4.1
[3/16/2021, 11:23:42 AM] Registering platform 'homebridge-broadlink-rm-pro.BroadlinkRM'
[3/16/2021, 11:23:43 AM] Loaded plugin: homebridge-camera-ffmpeg@3.0.3
[3/16/2021, 11:23:43 AM] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[3/16/2021, 11:23:43 AM] ---
[3/16/2021, 11:23:43 AM] Loaded plugin: homebridge-config-ui-x@4.38.0
[3/16/2021, 11:23:43 AM] Registering platform 'homebridge-config-ui-x.config'
[3/16/2021, 11:23:43 AM] Loaded plugin: homebridge-gsh@2.0.1
[3/16/2021, 11:23:43 AM] Registering platform 'homebridge-gsh.google-smarthome'
[3/16/2021, 11:23:43 AM] Loading 3 platforms...
[3/16/2021, 11:23:43 AM] [Jeedom] Initializing Jeedom platform...
[3/16/2021, 11:23:43 AM] [Jeedom] debugLevel:400
[3/16/2021, 11:23:43 AM] [Config] Initializing config platform...
[3/16/2021, 11:23:43 AM] [Config] Spawning homebridge-config-ui-x with PID 25606
[3/16/2021, 11:23:43 AM] [Broadlink RM] Initializing BroadlinkRM platform...
[3/16/2021, 11:23:43 AM] [Broadlink RM] e[35m[INFO]e[0m Automatically discovering Broadlink RM devices.
[3/16/2021, 11:23:43 AM] Loading 1 accessories...
[3/16/2021, 11:23:43 AM] Your config.json contains an illegal accessory configuration object at position 1. Missing property 'accessory'. Skipping entry...
[3/16/2021, 11:23:43 AM] [Jeedom] Synchronisation Jeedom <> Homebridge...
(node:25128) UnhandledPromiseRejectionWarning: TypeError: config.accessories.forEach is not a function
at BroadlinkRMPlatform.addAccessories (/usr/lib/node_modules/homebridge-broadlink-rm-pro/platform.js:71:24)
at BroadlinkRMPlatform.accessories (/usr/lib/node_modules/homebridge-broadlink-rm-pro/base/platform.js:28:16)
at /var/www/html/plugins/homebridge/resources/node_modules/homebridge/src/server.ts:415:24
at new Promise (<anonymous>)
at Server.loadPlatformAccessories (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/src/server.ts:414:12)
at /var/www/html/plugins/homebridge/resources/node_modules/homebridge/src/server.ts:402:28
at Array.forEach (<anonymous>)
at Server.loadPlatforms (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/src/server.ts:374:27)
at Server.start (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/src/server.ts:153:29)
at cli (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/src/cli.ts:80:10)
(node:25128) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
(node:25128) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
e[35m[INFO]e[0m Adding RF Support to device 780f77633d0f with type 279d
[3/16/2021, 11:23:44 AM] [Broadlink RM] e[35m[INFO]e[0m Discovered Broadlink RM3 Pro Plus (279d) at 192.168.1.68 (78:0f:77:63:3d:0f)
[3/16/2021, 11:23:45 AM] [Broadlink RM]
[3/16/2021, 11:23:45 AM] [Broadlink RM] **************************************************************************************************************
[3/16/2021, 11:23:45 AM] [Broadlink RM] ** Welcome to version e[32m4.4.1e[0m of the e[34mHomebridge Broadlink RM Plugine[0m!
[3/16/2021, 11:23:45 AM] [Broadlink RM] ** Find out what's in the latest release here: e[4mhttps://github.com/kiwi-cam/homebridge-broadlink-rm/blob/master/CHANGELOG.mde[0m
[3/16/2021, 11:23:45 AM] [Broadlink RM] ** If you like this plugin then please star it on GitHub or better yet
[3/16/2021, 11:23:45 AM] [Broadlink RM] ** buy me a drink using Paypal e[4mhttps://paypal.me/kiwicamRMe[0m.
[3/16/2021, 11:23:45 AM] [Broadlink RM] ** You can disable this message by adding "hideWelcomeMessage": true to the config (see config-sample.json).
[3/16/2021, 11:23:47 AM] [Jeedom] ┌────RAMASSE-MIETTES─────
[3/16/2021, 11:23:47 AM] [Jeedom] │ (Suppression des accessoires qui sont dans le cache mais plus dans jeedom (peut provenir de renommage ou changement de pièce))
[3/16/2021, 11:23:47 AM] [Jeedom] │ Rien à supprimer
[3/16/2021, 11:23:47 AM] [Jeedom] └────────────────────────
[3/16/2021, 11:23:47 AM] [Jeedom] --== Homebridge est démarré et a intégré 21 accessoires ! (Si vous avez un Warning Avahi, ne pas en tenir compte) ==--
