Hci0 disparu
Ce matin, je vois que mon démon local blea est en erreur sur mon nuc, le soucis est que mon hci0 n’apparait plus.
Hcitool dev ne me remonte pas de device.
Dan dmesg j’ai ça qui semble être lié:
[   18.638709] usb 1-4: device descriptor read/64, error -110
[   19.965658] r8169 0000:03:00.0: firmware: direct-loading firmware rtl_nic/rtl8168g-2.fw
[   19.965891] Generic PHY r8169-300:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
[   20.096867] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[   23.003272] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
[   23.003289] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[   34.257867] usb 1-4: device descriptor read/64, error -110
[   34.493913] usb 1-4: new full-speed USB device number 5 using xhci_hcd
[   49.877838] usb 1-4: device descriptor read/64, error -110
[   65.501527] usb 1-4: device descriptor read/64, error -110
[   65.609597] usb usb1-port4: attempt power cycle
[   66.021621] usb 1-4: new full-speed USB device number 6 using xhci_hcd
[   71.258895] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
[   71.467048] usb 1-4: Device not responding to setup address.
[   71.674976] usb 1-4: device not accepting address 6, error -71
[   71.806986] usb 1-4: new full-speed USB device number 7 using xhci_hcd
[   76.896255] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
[   77.104409] usb 1-4: Device not responding to setup address.
[   77.312329] usb 1-4: device not accepting address 7, error -71
[   77.312424] usb usb1-port4: unable to enumerate USB device
[   77.528585] usbcore: registered new interface driver usbserial_generic
[   77.528603] usbserial: USB Serial support registered for generic
[   77.535192] cdc_acm 1-3:1.0: ttyACM0: USB ACM device
[   77.535447] usbcore: registered new interface driver cdc_acm
[   77.535449] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   77.558742] usbcore: registered new interface driver ch341
[   77.558928] usbserial: USB Serial support registered for ch341-uart
[   77.559054] ch341 1-2:1.0: ch341-uart converter detected
[   77.561673] usb 1-2: ch341-uart converter now attached to ttyUSB0
Quelqu’un aurait une idée?
bonjour,
comment est utilisé ton nuc
OS natif ou VM ?
le device usb est t’il bien présent commande ssh lsusb
bonne journée
j’ai l’OS installé directement sur le nuc (depuis l’image fournie)
non, il n’y est même pas…
La c’est moche
c’est une clef externe particulière genre sena ou autre ?
ou en integration dans le nuc.
c’est le bluetooth interne du nuc
quel que commandes ssh pour voir …
hcitool dev
hciconfig
J’ai ça aussi dans mes notes je ne sais pas si c’est encore bon …
https://www.raspberrypi.org/forums/viewtopic.php?t=242281
http://sigalou-domotique.fr/domotique/67-activer-port-bluetooth-au-demarrage-de-jeedom
hcitool dev me retourne une liste de devices vide
hciconfig ne me retourne rien…
les 2 liens concernent les rpi avec la desactivation du bluetooth interne pour libérer l’uart pour le gpio, donc pas applicable au nuc…
Désolé j’ai vidé tout mon stock :wink:
Il me reste juste une dernière idée
faire un tour de toutes les options du setup du bios de la machine.
après c’est faire une tentative avec une autre clef en externe pour au moins lever le doute de la partie logiciel.
bonne journée
ça je peux pas le faire a distance :smiley:
je testerai ce soir
bon, j’ai résolu mais je sais pas comment…
Pour résumer:
-j’ai débranché mon nuc pour l’ammener a coté d’un écran
-je l’ai démarré
-je me suis rendu compte que je n’avais qu’un clavier bluetooth :frowning:
-je l’ai éteind
-je l’ai remis en place
-je l’ai redémarré
et le hci0 est réapparu…
Effectivement ça c’est ballo …
Bon si tu peut fait une photo du cavalier et indique ton modèle de nuc
ajoute tout ça dans ton post de solution ci ça peut aider les suivants
bonne journée
