peut être un indice, j’ai ce msg que je n’ai pas d’habitude …
le démon est nok, je relance et nok …
[2022-06-09 10:43:42][INFO] : Websocket connected
[2022-06-09 12:43:42][INFO] : Websocket connection close: (1001)-Going away
[2022-06-09 12:43:42][INFO] : Restarting websocket...
[2022-06-09 12:43:42][ERROR] : error from callback <bound method WSClient._on_close of <gardena.ws_client.WSClient object at 0x7fb87185f3c8>>: (invalid_request) Simultaneous logins detected for client[id=d1a036d3-c719-4188-a221-2a623b4c4bfb], user[id=e58c2e4c-7855-4e47-9032-3110d4e5e671, email=sbonichon@sfr.fr}]
[2022-06-09 12:43:42][ERROR] : Websocket error: (invalid_request) Simultaneous logins detected for client[id=d1a036d3-c719-4188-a221-2a623b4c4bfb], user[id=e58c2e4c-7855-4e47-9032-3110d4e5e671, email=sbonichon@sfr.fr}]
[2022-06-09 12:43:43][INFO] : Websocket connected
[2022-06-09 14:43:43][INFO] : Websocket connection close: (1001)-Going away
[2022-06-09 14:43:43][INFO] : Restarting websocket...
[2022-06-09 14:43:44][INFO] : Websocket connected
[2022-06-09 16:43:45][INFO] : Websocket connection close: (1001)-Going away
[2022-06-09 16:43:45][INFO] : Restarting websocket...
[2022-06-09 16:43:46][ERROR] : error from callback <bound method WSClient._on_close of <gardena.ws_client.WSClient object at 0x7fb87185f3c8>>: 403 Client Error: Forbidden for url: https://api.smart.gardena.dev/v1/websocket
[2022-06-09 16:43:46][ERROR] : Websocket error: 403 Client Error: Forbidden for url: https://api.smart.gardena.dev/v1/websocket
[2022-06-09 16:43:46][INFO] : Restarting websocket...
[2022-06-09 16:43:47][ERROR] : error from callback <bound method WSClient._on_error of <gardena.ws_client.WSClient object at 0x7fb87185f3c8>>: 403 Client Error: Forbidden for url: https://api.smart.gardena.dev/v1/websocket
[2022-06-09 16:43:47][ERROR] : Websocket error: 403 Client Error: Forbidden for url: https://api.smart.gardena.dev/v1/websocket
[2022-06-09 16:43:47][INFO] : Restarting websocket...
Exception in thread Thread-65:
File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 407, in _callback
callback(self, *args)
File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 57, in _on_close
self._set_connected(False)
File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 45, in _set_connected
self._on_connection_callback()
File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 286, in <lambda>
self.gardena_ws_client = WSClient(on_message_callback=self.on_message, on_connection_lost_callback=lambda: self.on_gardena_ws_connection_lost(location=location), level=self.level)
File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 338, in on_gardena_ws_connection_lost
self.start_gardena_ws(location)
File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 282, in start_gardena_ws
r.raise_for_status()
File "/usr/local/lib/python3.7/dist-packages/requests/models.py", line 960, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 403 Client Error: Forbidden for url: https://api.smart.gardena.dev/v1/websocket
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 369, in run_forever
dispatcher.read(self.sock.sock, read, check)
File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 70, in read
if not read_callback():
File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 337, in read
return teardown(frame)
File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 303, in teardown
self._callback(self.on_close, close_status_code, close_reason)
File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 412, in _callback
self.on_error(self, e)
File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 53, in _on_error
File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner
self.run()
File "/usr/lib/python3.7/threading.py", line 865, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 371, in run_forever
self._callback(self.on_error, e)
Exception in thread Thread-67:
self.run()
[2022-06-09 16:55:29][INFO] : Shuting down
[2022-06-09 16:55:32][INFO] : Starting daemon
[2022-06-09 16:55:32][INFO] : Log level: info
[2022-06-09 16:55:32][INFO] : Authentication done
[2022-06-09 16:55:32][INFO] : updating locations
[2022-06-09 16:55:33][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 16:55:33][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 16:55:33][INFO] : Shuting down
[2022-06-09 17:00:09][INFO] : Starting daemon
[2022-06-09 17:00:09][INFO] : Log level: info
[2022-06-09 17:00:11][INFO] : Authentication done
[2022-06-09 17:00:11][INFO] : updating locations
[2022-06-09 17:00:12][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:00:12][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:00:12][INFO] : Shuting down
[2022-06-09 17:05:06][INFO] : Starting daemon
[2022-06-09 17:05:06][INFO] : Log level: info
[2022-06-09 17:05:13][INFO] : Authentication done
[2022-06-09 17:05:13][INFO] : updating locations
[2022-06-09 17:05:14][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:05:14][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:05:14][INFO] : Shuting down
[2022-06-09 17:10:06][INFO] : Starting daemon
[2022-06-09 17:10:06][INFO] : Log level: info
[2022-06-09 17:10:11][INFO] : Authentication done
[2022-06-09 17:10:11][INFO] : updating locations
[2022-06-09 17:10:11][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:10:11][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:10:11][INFO] : Shuting down
[2022-06-09 17:15:06][INFO] : Starting daemon
[2022-06-09 17:15:06][INFO] : Log level: info
[2022-06-09 17:15:12][INFO] : Authentication done
[2022-06-09 17:15:12][INFO] : updating locations
[2022-06-09 17:15:12][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:15:12][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:15:12][INFO] : Shuting down
[2022-06-09 17:20:07][INFO] : Starting daemon
[2022-06-09 17:20:07][INFO] : Log level: info
[2022-06-09 17:20:13][INFO] : Authentication done
[2022-06-09 17:20:13][INFO] : updating locations
[2022-06-09 17:20:13][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:20:13][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:20:13][INFO] : Shuting down
[2022-06-09 17:25:06][INFO] : Starting daemon
[2022-06-09 17:25:06][INFO] : Log level: info
[2022-06-09 17:25:12][INFO] : Authentication done
[2022-06-09 17:25:12][INFO] : updating locations
[2022-06-09 17:25:12][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:25:12][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:25:12][INFO] : Shuting down
[2022-06-09 17:30:08][INFO] : Starting daemon
[2022-06-09 17:30:08][INFO] : Log level: info
[2022-06-09 17:30:13][INFO] : Authentication done
[2022-06-09 17:30:13][INFO] : updating locations
[2022-06-09 17:30:14][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:30:14][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:30:14][INFO] : Shuting down
[2022-06-09 17:35:06][INFO] : Starting daemon
[2022-06-09 17:35:06][INFO] : Log level: info
[2022-06-09 17:35:10][INFO] : Authentication done
[2022-06-09 17:35:10][INFO] : updating locations
[2022-06-09 17:35:10][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:35:10][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:35:10][INFO] : Shuting down
[2022-06-09 17:40:07][INFO] : Starting daemon
[2022-06-09 17:40:07][INFO] : Log level: info
[2022-06-09 17:40:14][INFO] : Authentication done
[2022-06-09 17:40:14][INFO] : updating locations
[2022-06-09 17:40:14][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:40:14][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:40:14][INFO] : Shuting down
[2022-06-09 17:45:07][INFO] : Starting daemon
[2022-06-09 17:45:07][INFO] : Log level: info
[2022-06-09 17:45:15][INFO] : Authentication done
[2022-06-09 17:45:15][INFO] : updating locations
[2022-06-09 17:45:16][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:45:16][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:45:16][INFO] : Shuting down
[2022-06-09 17:50:06][INFO] : Starting daemon
[2022-06-09 17:50:06][INFO] : Log level: info
[2022-06-09 17:50:15][INFO] : Authentication done
[2022-06-09 17:50:15][INFO] : updating locations
[2022-06-09 17:50:15][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:50:15][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:50:15][INFO] : Shuting down
[2022-06-09 17:55:05][INFO] : Starting daemon
[2022-06-09 17:55:05][INFO] : Log level: info
[2022-06-09 17:55:12][INFO] : Authentication done
[2022-06-09 17:55:12][INFO] : updating locations
[2022-06-09 17:55:13][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:55:13][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:55:13][INFO] : Shuting down
[2022-06-09 17:58:57][INFO] : Starting daemon
[2022-06-09 17:58:57][INFO] : Log level: info
[2022-06-09 17:58:57][INFO] : Authentication done
[2022-06-09 17:58:57][INFO] : updating locations
[2022-06-09 17:58:57][ERROR] : 403:{'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:58:57][ERROR] : Fatal error: {'Message': 'User is not authorized to access this resource with an explicit deny'}
[2022-06-09 17:58:57][INFO] : Shuting down
le site de l’api gardena spécifié dans la fenêtre de paramétrage du plugin semble inaccessible …
