Voilou…
{"actions":{"btn_on_url":[{"index":0,"urls":["http://192.168.1.240/plugins/shelly/core/api/jeeShelly.php?apikey=XXX&id=114&relay=0&value=btn_on_url"],"enabled":true}],"btn_off_url":[{"index":0,"urls":["http://192.168.1.240/plugins/shelly/core/api/jeeShelly.php?apikey=XXX&id=114&relay=0&value=btn_off_url"],"enabled":true}],"longpush_url":[{"index":0,"urls":["http://192.168.1.240/plugins/shelly/core/api/jeeShelly.php?apikey=XXX&id=114&relay=0&value=longpush_url"],"enabled":true}],"shortpush_url":[{"index":0,"urls":["http://192.168.1.240/plugins/shelly/core/api/jeeShelly.php?apikey=XXX&id=114&relay=0&value=shortpush_url"],"enabled":true}],"out_on_url":[{"index":0,"urls":["http://192.168.1.240/plugins/shelly/core/api/jeeShelly.php?apikey=XXX&id=114&relay=0&value=out_on_url"],"enabled":true}],"out_off_url":[{"index":0,"urls":["http://192.168.1.240/plugins/shelly/core/api/jeeShelly.php?apikey=XXX&id=114&relay=0&value=out_off_url"],"enabled":true}],"lp_on_url":[{"index":0,"urls":["http://192.168.1.240/plugins/shelly/core/api/jeeShelly.php?apikey=XXX&id=114&relay=0&value=btn_on_url"],"enabled":false}],"lp_off_url":[{"index":0,"urls":["http://192.168.1.240/plugins/shelly/core/api/jeeShelly.php?apikey=XXX&id=114&relay=0&value=btn_off_url"],"enabled":true}],"ext_temp_over_url":[{"index":0,"urls":[],"enabled":false,"ext_temp_over_value":0.000000,"ext_temp_over_onetime":true},{"index":1,"urls":[],"enabled":false,"ext_temp_over_value":0.000000,"ext_temp_over_onetime":true},{"index":2,"urls":[],"enabled":false,"ext_temp_over_value":0.000000,"ext_temp_over_onetime":true}],"ext_temp_under_url":[{"index":0,"urls":[],"enabled":false,"ext_temp_under_value":0.000000,"ext_temp_under_onetime":true},{"index":1,"urls":[],"enabled":false,"ext_temp_under_value":0.000000,"ext_temp_under_onetime":true},{"index":2,"urls":[],"enabled":false,"ext_temp_under_value":0.000000,"ext_temp_under_onetime":true}],"ext_hum_over_url":[{"index":0,"urls":[],"enabled":false,"ext_hum_over_value":0,"ext_hum_over_onetime":true}],"ext_hum_under_url":[{"index":0,"urls":[],"enabled":false,"ext_hum_under_value":0,"ext_hum_under_onetime":true}]}}
Je récupère l’info avec cette requête :
ext_switch > 0 > input
Et merci par avance pour le taf.
