j’ai fait la mise à jour Jeedom 4.2 il y a quelque jour, et comme j’ai remis en place mon UDM Pro et tout le reste, j’ai remis le plugin en marche (version beta).
Tout fonctionne… sauf que dans les logs j’ai « api » qui gonfle à 200-300 Mo. Toutes les secondes j’ai une écriture. J’ai bien essayé de mettre 60 secondes dans la config mais après ?
Un tout tout petit extrait :
[2022-02-16 23:00:36][INFO] : {";jsonrpc";:";2.0";,";id";:";353";,";method";:";event";,";params";:{";plugin";:";unifi";,";apikey";:";xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";,";session";:true,";sess_id";:";";,";data";:{";eventType";:";sta:sync.generic";,";result";:{";site_id";:";6209414xxxxx927586d";,";assoc_time";:1644958450,";latest_assoc_time";:null,";oui";:";PhilipsL";,";user_id";:";620953be4xxxxx06992759a2";,";_id";:";620953bexxxxx6992759a2";,";mac";:";00:17:88:23:1f:42";,";is_guest";:false,";first_seen";:1644778430,";last_seen";:1645048836,";is_wired";:true,";usergroup_id";:";";,";name";:";Domo-Hue";,";noted";:true,";_uptime_by_ugw";:null,";_last_seen_by_ugw";:null,";_is_guest_by_ugw";:false,";gw_mac";:";e0:63:da:5a:ee:79";,";network";:";Default";,";network_id";:";620941474xxxx275880";,";uptime";:90386,";wired-tx_bytes";:null,";wired-rx_bytes";:null,";wired-tx_packets";:null,";wired-rx_packets";:null,";wired-tx_bytes-r";:null,";wired-rx_bytes-r";:null,";tx_retries";:null,";wifi_tx_attempts";:null,";authorized";:true,";qos_policy_applied";:true,";_uptime_by_usw";:null,";_last_seen_by_usw";:null,";_is_guest_by_usw";:false,";sw_mac";:";18:e8:29:44:58:8c";,";sw_depth";:1,";sw_port";:2,";wired_rate_mbps";:100,";hostname";:";";,";hostname_source";:null,";ip";:";192.168.1.31";,";anomalies";:null,";satisfaction";:100,";eagerly_discovered";:null,";rx_bytes-r";:null,";tx_bytes-r";:null,";_last_seen_by_uap";:null,";_uptime_by_uap";:null,";ccq";:null,";idletime";:null,";noise";:null,";satisfaction_now";:null,";satisfaction_real";:null,";satisfaction_reason";:null,";rssi";:null,";rx_bytes";:null,";rx_packets";:null,";rx_rate";:null,";signal";:null,";tx_bytes";:null,";tx_mcs";:null,";tx_packets";:null,";tx_rate";:null,";bytes-r";:null},";type";:";unifi";,";apikey";:";xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";}}} - IP :192.168.1.30
Que puis-je faire ? Merci
