excuse moi peux tu m’expliquer comment on fait car quand je clique sur export cela me dit exporter et je ne trouve pas configget je suis nul la dessus
suffit de lire le tooltip : ?
donc voir la commande configGet
C’est cela qu’il te faut
{"level":1,"custom":0,"request":"configGet","dps":"","parameters":"{\"id\":\"dps_3_SLIDER\",\"dps\":3,\"par\":\"#slider#\"},\/n{\"id\":\"dps_3_VALUE\",\"dps\":3,\"par\":\"#value#\"},\/n{\"id\":\"dps_4_SLIDER\",\"dps\":4,\"par\":\"#slider#\"},\/n{\"id\":\"dps_4_VALUE\",\"dps\":4,\"par\":\"#value#\"},\/n{\"id\":\"dps_5_Color\",\"dps\":5,\"par\":\"\\\"#colorH4S4V4_1000#\\\"\"},\/n{\"id\":\"dps_5_ColorGet\",\"dps\":5,\"par\":\"\\\"#colorH4S4V4_1000#\\\"\"},\/n{\"id\":\"dps_5_Intensity\",\"dps\":5,\"par\":\"\\\"#slider_intH4S4V4_1000#\\\"\"},\/n{\"id\":\"dps_5_IntensityGet\",\"dps\":5,\"par\":\"\\\"#slider_intH4S4V4_1000#\\\"\"},\/n{\"id\":\"dps_5_Saturation\",\"dps\":5,\"par\":\"\\\"#slider_satH4S4V4_1000#\\\"\"},\/n{\"id\":\"dps_5_SaturationGet\",\"dps\":5,\"par\":\"\\\"#slider_satH4S4V4_1000#\\\"\"},\/n{\"id\":\"dps_6_MODE\",\"dps\":6,\"par\":\"\"},\/n{\"id\":\"dps_6_MODE_000d0d0000000000000000c80000\",\"dps\":6,\"par\":\"\\\"000d0d0000000000000000c80000\\\"\"},\/n{\"id\":\"dps_7_T_OFF\",\"dps\":7,\"par\":\"0\"},\/n{\"id\":\"dps_7_T_ON\",\"dps\":7,\"par\":\"1\"},\/n{\"id\":\"dps_7_T_STATE\",\"dps\":7,\"par\":\"\"},\/n{\"id\":\"dps_1_SLIDER\",\"dps\":1,\"par\":\"#slider#\"},\/n{\"id\":\"dps_1_VALUE\",\"dps\":1,\"par\":\"#value#\"},\/n{\"id\":\"stateGet\",\"dps\":,\"par\":\"312\"},\/n{\"id\":\"dps_2_MODE\",\"dps\":2,\"par\":\"\"},\/n{\"id\":\"dps_2_MODE_scene_1\",\"dps\":2,\"par\":\"\\\"scene_1\\\"\"},\/n{\"id\":\"dps_2_MODE_scene_2\",\"dps\":2,\"par\":\"\\\"scene_2\\\"\"},\/n{\"id\":\"dps_2_MODE_scene_3\",\"dps\":2,\"par\":\"\\\"scene_3\\\"\"},\/n{\"id\":\"dps_2_MODE_scene_4\",\"dps\":2,\"par\":\"\\\"scene_4\\\"\"}\/n","updateCmdId2":"undefined"}
c’est bien la contenu du champ configGet ?
je ne sais pas où tu as récupéré cela.
Cela doit ressembler à :
{"id":"dps_12_T_OFF","dps":12,"par":"0"},/n{"id":"dps_12_T_ON","dps":12,"par":"1"},/n{"id":"stateGet","dps":,"par":"312"},/n{"id":"dps_12_T_STATE","dps":12,"par":""},/n{"id":"dps_1_OFF","dps":1,"par":"false"},/n{"id":"dps_1_ON","dps":1,"par":"true"},/n{"id":"dps_1_STATE","dps":1,"par":""},/n{"id":"dps_2_SLIDER","dps":2,"par":"#slider#"},/n{"id":"dps_2_VALUE","dps":2,"par":"#value#"},/n{"id":"dps_3_SLIDER","dps":3,"par":"#slider#"},/n{"id":"dps_3_VALUE","dps":3,"par":"#value#"},/n{"id":"dps_6_T_OFF","dps":6,"par":"0"},/n{"id":"dps_6_T_ON","dps":6,"par":"1"},/n{"id":"dps_6_T_STATE","dps":6,"par":""},/n{"id":"dps_7_OFF","dps":7,"par":"false"},/n{"id":"dps_7_ON","dps":7,"par":"true"},/n{"id":"dps_7_STATE","dps":7,"par":""},/n{"id":"dps_8_SLIDER","dps":8,"par":"#slider#"},/n{"id":"dps_8_VALUE","dps":8,"par":"#value#"},/n{"id":"dps_9_SLIDER","dps":9,"par":"#slider#"},/n{"id":"dps_9_VALUE","dps":9,"par":"#value#"}/n
Je vais t’expliquer
Je vais dans l’équipement de ma télécommande, je clic sur Exporter et la la page s’actualise
Alors rien de plus, je suis aller après dans le configuration avancé, puis la roue cranté du configGet puis information
C’est tout ce que j’ai trouvé
Voila
{"id":"dps_3_SLIDER","dps":3,"par":"#slider#"},/n{"id":"dps_3_VALUE","dps":3,"par":"#value#"},/n{"id":"dps_4_SLIDER","dps":4,"par":"#slider#"},/n{"id":"dps_4_VALUE","dps":4,"par":"#value#"},/n{"id":"dps_5_Color","dps":5,"par":"\"#colorH4S4V4_1000#\""},/n{"id":"dps_5_ColorGet","dps":5,"par":"\"#colorH4S4V4_1000#\""},/n{"id":"dps_5_Intensity","dps":5,"par":"\"#slider_intH4S4V4_1000#\""},/n{"id":"dps_5_IntensityGet","dps":5,"par":"\"#slider_intH4S4V4_1000#\""},/n{"id":"dps_5_Saturation","dps":5,"par":"\"#slider_satH4S4V4_1000#\""},/n{"id":"dps_5_SaturationGet","dps":5,"par":"\"#slider_satH4S4V4_1000#\""},/n{"id":"dps_6_MODE","dps":6,"par":""},/n{"id":"dps_6_MODE_000d0d0000000000000000c80000","dps":6,"par":"\"000d0d0000000000000000c80000\""},/n{"id":"dps_7_T_OFF","dps":7,"par":"0"},/n{"id":"dps_7_T_ON","dps":7,"par":"1"},/n{"id":"dps_7_T_STATE","dps":7,"par":""},/n{"id":"dps_1_SLIDER","dps":1,"par":"#slider#"},/n{"id":"dps_1_VALUE","dps":1,"par":"#value#"},/n{"id":"stateGet","dps":,"par":"312"},/n{"id":"dps_2_MODE","dps":2,"par":""},/n{"id":"dps_2_MODE_scene_1","dps":2,"par":"\"scene_1\""},/n{"id":"dps_2_MODE_scene_2","dps":2,"par":"\"scene_2\""},/n{"id":"dps_2_MODE_scene_3","dps":2,"par":"\"scene_3\""},/n{"id":"dps_2_MODE_scene_4","dps":2,"par":"\"scene_4\""}/n
super
peux tu me donner une explication de ce que font chacun des dps ?
il y a un slider : min / max
Les dps slidd ne font rien
Pour allumer clic dps_7_T_ON
Pour éteindre dps_7_T_OFF ne fonctionne pas mais j’ai celui la dps_6_MODE_000d0d0000000000000000c80000 qui fonctionne pour le moement
{"id":"dps_2_MODE_scene_4","dps":2,"par":"\"scene_4\""},
donc la télécommande permet de modifier une couleur ?
de modifier des scenes ?
il faut que tu me dises ce que font chacun des dps 1 à 7
tu peux me donner une image de la telco ?
J’ai juste deux dsp qui fonctionnent
dps_7_T_ON et le dps_6_MODE_000d0d0000000000000000c80000
Allumer et éteindre
dps_2_MODE_scene_4
Lumiere rouge
Les autre ne fonctionne pas
au vu de la telco
on voit bien les boutons ON/OFF et intensité + et -
comment peux-tu généré avec la telco des scènes et des couleurs ?
c’est ça que je ne comprends pas.
Les scène de couleur ce règle dans l’application tuya su téléphone
donc ce n’est pas ce que fait la télécommande !
j’ai besoin des dps envoyés par la télécommande et uniquement par elle.
et concernant l’ampoule
c’est une ampoule couleur avec des scènes
donc quand tu joues avec l’appli Tuya pour modifier la lampe, le plugin, en mode inclusion récupère les dps.
Ce qui est étonnant c’est que peu de choses fonctionnent.
Le on mais pas le off
tu as récupéré le slider de l’intensité de l’ampoule, la couleur (Hue) et la saturation. Aucune commande ne fonctionne ?
Donc il faudrait que tu fasses l’apprentissage de la télécommande seule et uniquement elle
Puis pareil mais pour un autre périphérique qui est la lampe avec l’appli tuya
Je les ai passer 1 par 1
wifilightV2.txt (19,5 Ko)
tu as passé quoi 1/1 et sur quel périphérique ? la telco ou la lampe ?
donc tu effaces tous tes périphériques puis tu passes en mode inclusion, tu manipules la télécommande, puis tu arrêtes l’inclusion puis sauvegarde
ensuite tu te remets en inclusion, tu manipules la lampe avec l’appli tuya avec tout ce que tu peux faire, puis tu arrêtes l’inclusion puis sauvegarde
normalement les commandes actions devraient toutes fonctionner
M’envoyer les configGet pour la telco et pour l’ampoule.
m’envoyer les logs de wifilightV2_Ap
Si les commandes actions sont KO, là et seulement là m’envoyer les logs :
attendre le passage du demaon ente >>> <<<<< et >>>>> end <<<<<
effacer les logs
là, appuyer sur les commandes côté Tuya avant que le demon ne repasse.
M’envoyer les logs
faire d emême avec les commandes actions du plugin.
Les détails sont dans la doc
Voici les
configGet de la Telco
{"id":"dps_1_OFF","dps":1,"par":"false"},/n{"id":"dps_1_ON","dps":1,"par":"true"},/n{"id":"dps_2_MODE_colour","dps":2,"par":"\"colour\""},/n{"id":"Etat","dps":1,"par":""},/n{"id":"stateGet","dps":,"par":"312"},/n{"id":"dps_2_MODE","dps":2,"par":""},/n{"id":"dps_2_MODE_white","dps":2,"par":"\"white\""},/n{"id":"dps_3_SLIDER","dps":3,"par":"#slider#","max":1000,"min":0},/n{"id":"dps_3_VALUE","dps":3,"par":"#value#"},/n{"id":"dps_4_SLIDER","dps":4,"par":"#slider#","max":1000,"min":0},/n{"id":"dps_4_T_OFF","dps":4,"par":"0"},/n{"id":"dps_4_T_ON","dps":4,"par":"1"},/n{"id":"dps_4_T_STATE","dps":4,"par":""},/n{"id":"dps_4_VALUE","dps":4,"par":"#value#"},/n{"id":"dps_5_Color","dps":5,"par":"\"#colorH4S4V4_1000#\""},/n{"id":"dps_5_ColorGet","dps":5,"par":"\"#colorH4S4V4_1000#\""},/n{"id":"dps_5_Intensity","dps":5,"par":"\"#slider_intH4S4V4_1000#\""},/n{"id":"dps_5_IntensityGet","dps":5,"par":"\"#slider_intH4S4V4_1000#\""},/n{"id":"dps_5_Saturation","dps":5,"par":"\"#slider_satH4S4V4_1000#\""},/n{"id":"dps_5_SaturationGet","dps":5,"par":"\"#slider_satH4S4V4_1000#\""},/n{"id":"dps_6_MODE","dps":6,"par":""},/n{"id":"dps_6_MODE_010e0d0000000000000003e801f4","dps":6,"par":"\"010e0d0000000000000003e801f4\""},/n{"id":"dps_7_T_OFF","dps":7,"par":"0"},/n{"id":"dps_7_T_ON","dps":7,"par":"1"},/n{"id":"dps_7_T_STATE","dps":7,"par":""}/n
configGet de l’ampoule
Pour l’intensité de la lumière avec le slide impossible de monté plus de 10 %
Alors j’ai du dans la config mettre 1000 pour faire 100%
Bonne soirée à toi et merci
Je suis très étonné de la telco car elle a exactement les mêmes dps que l’ampoule, on dirait soit un copier/coller soit l’apprentissage a pris aussi les infos de l’ampoule en même temps.
Il faudrait que tu réessayes avec l’ampoule non alimentée et ne modifier que la telco pendant l’apprentissage.
donc :
- supprimer la telco du plugin
- débrancher tous les autres périphériques Lidl ou Tuya Zigbee
- refaire l’inclusion de la telco et ne toucher que la telco.
L’ampoule RGBW est ajoutée en beta
Bonjour @bernardfr.caron
Juste la telco sans l’ampoule
voici le configGet
Si je fait inclure la telco avec l’ampoule il me met tout se que j’ai comme l’ampoule plus haut.
Par contre dans le plugin SmartLife/Tuya de Jeedom il me remonte bien les 4 Scène de la télécommande
scene1_Doux; scene2_Lecture; scene3_Concentrer; scene4_Travail
Ses scènes sont celle que tu paramètre dans l’appli du tel Tuya
Bonne journée
