Je suis sous Raspberry Pi 4 Model B rev 1.2
OS : Raspbian buster
Jeedom v4.0.61
J’essaye d’installer ESPEasy mais voilà que les dépendances ne veulent pas s’installer… Logs ci-dessous. Quelqu’un saurait identifier la source de mon problème ? :-/
Merci d’avance !
Dinoz
> Début de l'installation
> --2021-10-13 22:58:11-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
> Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.111.133, 185.199.110.133, 185.199.108.133, ...
> Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443... connected.
> HTTP request sent, awaiting response... 200 OK
> Length: 1552 (1.5K) [text/plain]
> Saving to: 'dependencies.sh'
> 0K . 100% 7.33M=0s
> 2021-10-13 22:58:11 (7.33 MB/s) - 'dependencies.sh' saved [1552/1552]
> dependencies.sh: 3: [: espeasy: unexpected operator
> Version actuelle : 10
> Hit:1 http://archive.raspberrypi.org/debian buster InRelease
> Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
> Reading package lists...
> E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
> Building dependency tree...
> Reading state information...
> lsb-release is already the newest version (10.2019051400+rpi1).
> 0 upgraded, 0 newly installed, 0 to remove and 191 not upgraded.
> dependencies.sh: 29: dependencies.sh: [[: not found
> KO, version obsolète à upgrader
> Suppression du Nodejs existant et installation du paquet recommandé
> Package 'npm' is not installed, so not removed
> The following packages will be REMOVED:
> libc-ares2* libnode64* libuv1* nodejs* nodejs-doc*
> 0 upgraded, 0 newly installed, 5 to remove and 191 not upgraded.
> After this operation, 27.7 MB disk space will be freed.
> (Reading database ...
> (Reading database ... 5%
> (Reading database ... 10%
> (Reading database ... 15%
> (Reading database ... 20%
> (Reading database ... 25%
> (Reading database ... 30%
> (Reading database ... 35%
> (Reading database ... 40%
> (Reading database ... 45%
> (Reading database ... 50%
> (Reading database ... 55%
> (Reading database ... 60%
> (Reading database ... 65%
> (Reading database ... 70%
> (Reading database ... 75%
> (Reading database ... 80%
> (Reading database ... 85%
> (Reading database ... 90%
> (Reading database ... 95%
> (Reading database ... 100%
> (Reading database ... 66105 files and directories currently installed.)
> Removing nodejs (10.24.0~dfsg-1~deb10u1) ...
> Removing libnode64:armhf (10.24.0~dfsg-1~deb10u1) ...
> Removing libc-ares2:armhf (1.14.0-1+deb10u1) ...
> Removing libuv1:armhf (1.24.1-1+deb10u1) ...
> Removing nodejs-doc (10.24.0~dfsg-1~deb10u1) ...
> Processing triggers for man-db (2.8.5-2) ...
> Processing triggers for libc-bin (2.28-10+rpi1) ...
> dependencies.sh: 38: [: armv7l: unexpected operator
> Utilisation du dépot officiel
> ## Installing the NodeSource Node.js 14.x repo...
> ## Populating apt-get cache...
> + apt-get update
> Error executing command, exiting
> The following additional packages will be installed:
> libc-ares2 libnode64 libuv1 nodejs-doc
> Suggested packages:
> npm
> The following NEW packages will be installed:
> libc-ares2 libnode64 libuv1 nodejs nodejs-doc
> debconf: unable to initialize frontend: Dialog
> debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
> debconf: falling back to frontend: Readline
> debconf: unable to initialize frontend: Readline
> debconf: (This frontend requires a controlling tty.)
> debconf: falling back to frontend: Teletype
> dpkg-preconfigure: unable to re-open stdin:
> 0 upgraded, 5 newly installed, 0 to remove and 191 not upgraded.
> Need to get 0 B/6099 kB of archives.
> After this operation, 27.7 MB of additional disk space will be used.
> Selecting previously unselected package libc-ares2:armhf.
> (Reading database ... 65960 files and directories currently installed.)
> Preparing to unpack .../libc-ares2_1.14.0-1+deb10u1_armhf.deb ...
> Unpacking libc-ares2:armhf (1.14.0-1+deb10u1) ...
> Selecting previously unselected package libuv1:armhf.
> Preparing to unpack .../libuv1_1.24.1-1+deb10u1_armhf.deb ...
> Unpacking libuv1:armhf (1.24.1-1+deb10u1) ...
> Selecting previously unselected package libnode64:armhf.
> Preparing to unpack .../libnode64_10.24.0~dfsg-1~deb10u1_armhf.deb ...
> Unpacking libnode64:armhf (10.24.0~dfsg-1~deb10u1) ...
> Selecting previously unselected package nodejs.
> Preparing to unpack .../nodejs_10.24.0~dfsg-1~deb10u1_armhf.deb ...
> Unpacking nodejs (10.24.0~dfsg-1~deb10u1) ...
> Selecting previously unselected package nodejs-doc.
> Preparing to unpack .../nodejs-doc_10.24.0~dfsg-1~deb10u1_all.deb ...
> Unpacking nodejs-doc (10.24.0~dfsg-1~deb10u1) ...
> Setting up libc-ares2:armhf (1.14.0-1+deb10u1) ...
> Setting up libuv1:armhf (1.24.1-1+deb10u1) ...
> Setting up libnode64:armhf (10.24.0~dfsg-1~deb10u1) ...
> Setting up nodejs-doc (10.24.0~dfsg-1~deb10u1) ...
> Setting up nodejs (10.24.0~dfsg-1~deb10u1) ...
> update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
> ln: failed to create symbolic link '/usr/bin/nodejs': File exists
> Version actuelle : v10.24.0
> dependencies.sh: 61: dependencies.sh: npm: not found
> chown: cannot access 'node_modules': No such file or directory
> Fin de l'installation
J’ai retenté une installation. Voici les logs :
--2021-10-15 02:05:02-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.110.133, 185.199.111.133, 185.199.108.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.110.133|:443... connected.
Saving to: ‘dependencies.sh’
0K . 100% 2.21M=0.001s
2021-10-15 02:05:02 (2.21 MB/s) - ‘dependencies.sh’ saved [1552/1552]
Err:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) Could not connect to raspbian.raspberrypi.org:80 (93.93.128.193), connection timed out
W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/buster/InRelease Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) Could not connect to raspbian.raspberrypi.org:80 (93.93.128.193), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.
+ apt-get update
Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) Could not connect to raspbian.raspberrypi.org:80 (93.93.128.193), connection timed out [IP: 93.93.128.193 80]
W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/buster/InRelease Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) Could not connect to raspbian.raspberrypi.org:80 (93.93.128.193), connection timed out [IP: 93.93.128.193 80]
## Confirming "buster" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/buster/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
## Creating apt sources list file for the NodeSource Node.js 14.x repo...
+ echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
Get:2 https://deb.nodesource.com/node_14.x buster InRelease [4,584 B]
Get:3 https://deb.nodesource.com/node_14.x buster/main armhf Packages [781 B]
Err:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
Fetched 5,365 B in 30s (177 B/s)
## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
nodejs
0 upgraded, 1 newly installed, 0 to remove and 191 not upgraded.
Need to get 22.9 MB of archives.
After this operation, 116 MB of additional disk space will be used.
Get:1 https://deb.nodesource.com/node_14.x buster/main armhf nodejs armhf 14.18.1-deb-1nodesource1 [22.9 MB]
Fetched 22.9 MB in 2s (10.1 MB/s)
Preparing to unpack .../nodejs_14.18.1-deb-1nodesource1_armhf.deb ...
Unpacking nodejs (14.18.1-deb-1nodesource1) ...
Setting up nodejs (14.18.1-deb-1nodesource1) ...
Version actuelle : v14.18.1
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm notice created a lockfile as package-lock.json. You should commit this file.
added 48 packages from 58 contributors and audited 48 packages in 4.93s
2 packages are looking for funding
run `npm fund` for details
found 0 vulnerabilities
