j’ai une erreur durant l’installation de la vers 4.4.2, cela a planter à 55% et depuis error 500
[05-Apr-2024 14:58:27 Europe/Brussels] PHP Deprecated: The behavior of unparenthesized expressions containing both '.' and '+'/'-' will change in PHP 8: '+'/'-' will take a higher precedence in /var/www/html/plugins/wifilightV2/3rdparty/meross.php on line 251
[Fri Apr 05 14:49:39.617760 2024] [php7:notice] [pid 1142] [client 192.168.1.83:57006] PHP Notice: Trying to access array offset on value of type null in /var/www/html/plugins/airquality/core/class/airquality.class.php on line 363, referer: http://192.168.1.97/index.php?v=d&p=dashboard
[Fri Apr 05 14:49:39.617791 2024] [php7:notice] [pid 1142] [client 192.168.1.83:57006] PHP Notice: Trying to access array offset on value of type null in /var/www/html/plugins/airquality/core/class/airquality.class.php on line 364, referer: http://192.168.1.97/index.php?v=d&p=dashboard
[05-Apr-2024 14:49:57 Europe/Brussels] PHP Warning: gmdate() expects parameter 2 to be int, string given in /var/www/html/core/class/jeedom.class.php on line 219
[05-Apr-2024 15:10:04 Europe/Brussels] PHP Fatal error: Access level to naEnergie::$_templateArray must be protected (as in class eqLogic) or weaker in /var/www/html/plugins/naEnergie/core/class/naEnergie.class.php on line 14
[05-Apr-2024 16:10:38 Europe/Brussels] PHP Fatal error: Access level to naEnergie::$_templateArray must be protected (as in class eqLogic) or weaker in /var/www/html/plugins/naEnergie/core/class/naEnergie.class.php on line 14
[05-Apr-2024 16:10:39 Europe/Brussels] PHP Fatal error: Access level to naEnergie::$_templateArray must be protected (as in class eqLogic) or weaker in /var/www/html/plugins/naEnergie/core/class/naEnergie.class.php on line 14
[05-Apr-2024 16:19:02 Europe/Brussels] PHP Fatal error: Access level to naEnergie::$_templateArray must be protected (as in class eqLogic) or weaker in /var/www/html/plugins/naEnergie/core/class/naEnergie.class.php on line 14
[05-Apr-2024 16:20:06 Europe/Brussels] PHP Fatal error: Access level to naEnergie::$_templateArray must be protected (as in class eqLogic) or weaker in /var/www/html/plugins/naEnergie/core/class/naEnergie.class.php on line 14
[05-Apr-2024 16:20:10 Europe/Brussels] PHP Fatal error: Access level to naEnergie::$_templateArray must be protected (as in class eqLogic) or weaker in /var/www/html/plugins/naEnergie/core/class/naEnergie.class.php on line 14
[05-Apr-2024 16:23:00 Europe/Brussels] PHP Fatal error: Access level to naEnergie::$_templateArray must be protected (as in class eqLogic) or weaker in /var/www/html/plugins/naEnergie/core/class/naEnergie.class.php on line 14
