Voici le log que j ai recuperer dans zigbee2mqtt avec l adresse en 8080
Error No converter available for 'mode' ()
Error No converter available for 'level' ()
Error No converter available for 'strobe' ()
Error No converter available for 'battery' ()
Error No converter available for 'duration' ()
Debug Received Zigbee message from 'Prise Zigbee', type 'readResponse', cluster 'genOnOff', data '{"onOff":1}' from endpoint 3 with groupID null
Info MQTT publish: topic 'zigbee2mqtt/Prise Zigbee', payload '{"device":{"applicationVersion":9,"dateCode":"20140331DEOS****","friendlyName":"Prise Zigbee","hardwareVersion":1,"ieeeAddr":"0x7cb03eaa0a07a829","manufacturerID":48042,"manufacturerName":"OSRAM","model":"AB3257001NJ","networkAddress":35999,"powerSource":"Mains (single phase)","softwareBuildID":"V1.05.09","stackVersion":2,"type":"Router","zclVersion":1},"linkquality":191,"state":"ON","update":{"state":"idle"},"update_available":false}'
Debug Received Zigbee message from 'Prise Biblioteque', type 'read', cluster 'genTime', data '["time"]' from endpoint 1 with groupID null
Debug Received Zigbee message from 'Bouton Chauffage salle de bains', type 'attributeReport', cluster 'genBasic', data '{"65282":[{"elmType":16,"elmVal":1},{"elmType":33,"elmVal":3032},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":554},{"elmType":32,"elmVal":92}]}' from endpoint 1 with groupID null
Info MQTT publish: topic 'zigbee2mqtt/Bouton Chauffage salle de bains', payload '{"battery":100,"device":{"applicationVersion":10,"friendlyName":"Bouton Chauffage salle de bains","ieeeAddr":"0x00158d00015635d2","manufacturerID":4151,"manufacturerName":"LUMI","model":"WXKG01LM","networkAddress":46924,"powerSource":"Battery","type":"EndDevice"},"linkquality":239,"voltage":3032}'
Debug Received MQTT message on 'zigbee2mqtt/Alarme 1/get' with data '{"mode":"","level":"","strobe":"","battery":"","duration":""}'
Debug Received Zigbee message from 'Bouton portail', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":3045,"10":0,"3":28,"4":5032,"5":12,"6":[0,1]}}' from endpoint 1 with groupID null
Info MQTT publish: topic 'zigbee2mqtt/Bouton portail', payload '{"battery":100,"device":{"applicationVersion":3,"dateCode":"20161128","friendlyName":"Bouton portail","hardwareVersion":2,"ieeeAddr":"0x00158d0002131540","manufacturerID":4151,"manufacturerName":"LUMI","model":"WXKG11LM","networkAddress":41492,"powerSource":"Battery","softwareBuildID":"3000-0001","stackVersion":2,"type":"EndDevice","zclVersion":1},"linkquality":231,"voltage":3045}'
Debug Received Zigbee message from 'Prise Biblioteque', type 'attributeReport', cluster 'genBasic', data '{"65281":{"100":0,"149":167.278076171875,"152":0,"154":0,"3":31,"5":92,"8":4954,"9":3596}}' from endpoint 1 with groupID null
Info MQTT publish: topic 'zigbee2mqtt/Prise Biblioteque', payload '{"consumption":167.28,"device":{"applicationVersion":1,"dateCode":"12-20-2019","friendlyName":"Prise Biblioteque","ieeeAddr":"0x00158d0001deb2d3","manufacturerID":4151,"manufacturerName":"LUMI","model":"ZNCZ02LM","networkAddress":38099,"powerSource":"Battery","type":"EndDevice"},"energy":167.28,"linkquality":87,"power":0,"state":"OFF","temperature":31}'
Debug Received Zigbee message from 'Capteur fenêtre Hadriel', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":3015,"10":0,"100":0,"3":25,"4":5032,"5":51,"6":[0,1]}}' from endpoint 1 with groupID null
Info MQTT publish: topic 'zigbee2mqtt/Capteur fenêtre Hadriel', payload '{"battery":100,"contact":true,"device":{"applicationVersion":3,"dateCode":"20161128","friendlyName":"Capteur fenêtre Hadriel","hardwareVersion":2,"ieeeAddr":"0x00158d000315faeb","manufacturerID":4151,"manufacturerName":"LUMI","model":"MCCGQ11LM","networkAddress":3243,"powerSource":"Battery","softwareBuildID":"3000-0001","stackVersion":2,"type":"EndDevice","zclVersion":1},"linkquality":255,"temperature":25,"voltage":3015}'
Debug Saving state to file /var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/state.json
Debug Received Zigbee message from 'Temp Fenêtre Sud', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":3005,"10":0,"100":1803,"101":7938,"102":98445,"4":17320,"5":7,"6":[0,1]}}' from endpoint 1 with groupID null
Info MQTT publish: topic 'zigbee2mqtt/Temp Fenêtre Sud', payload '{"battery":100,"device":{"applicationVersion":3,"dateCode":"20161129","friendlyName":"Temp Fenêtre Sud","hardwareVersion":30,"ieeeAddr":"0x00158d0004657b40","manufacturerID":4151,"manufacturerName":"LUMI","model":"WSDCGQ11LM","networkAddress":20771,"powerSource":"Battery","softwareBuildID":"3000-0001","stackVersion":2,"type":"EndDevice","zclVersion":1},"humidity":79.38,"linkquality":231,"pressure":984.5,"temperature":18.03,"voltage":3005}'
Debug Received Zigbee message from 'Bouton lit hadriel', type 'attributeReport', cluster 'genBasic', data '{"65282":[{"elmType":16,"elmVal":1},{"elmType":33,"elmVal":3032},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":259},{"elmType":32,"elmVal":89}]}' from endpoint 1 with groupID null
Info MQTT publish: topic 'zigbee2mqtt/Bouton lit hadriel', payload '{"battery":100,"device":{"applicationVersion":10,"friendlyName":"Bouton lit hadriel","ieeeAddr":"0x00158d0001563716","manufacturerID":4151,"manufacturerName":"LUMI","model":"WXKG01LM","networkAddress":7761,"powerSource":"Battery","type":"EndDevice"},"linkquality":255,"voltage":3032}'
Debug Received MQTT message on 'zigbee2mqtt/Prise Zigbee/get' with data '{"state":""}'
Debug Publishing get 'get' 'state' to 'Prise Zigbee'
Debug Received MQTT message on 'zigbee2mqtt/bridge/request/permit_join' with data '{"value":false}'
Info Zigbee: disabling joining new devices.
Info MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"value":false},"status":"ok"}'
Debug Received Zigbee message from 'Capteur porte garage', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":2985,"10":0,"100":1,"3":25,"4":5032,"5":32,"6":[0,1]}}' from endpoint 1 with groupID null
Info MQTT publish: topic 'zigbee2mqtt/Capteur porte garage', payload '{"battery":91,"contact":false,"device":{"applicationVersion":3,"dateCode":"20161128","friendlyName":"Capteur porte garage","hardwareVersion":2,"ieeeAddr":"0x00158d00031e2d91","manufacturerID":4151,"manufacturerName":"LUMI","model":"MCCGQ11LM","networkAddress":64375,"powerSource":"Battery","softwareBuildID":"3000-0001","stackVersion":2,"type":"EndDevice","zclVersion":1},"linkquality":255,"temperature":25,"voltage":2985}'
Debug Received Zigbee message from 'Bouton Biblioteque', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":3035,"10":38099,"3":25,"4":5032,"5":35,"6":[0,2]}}' from endpoint 1 with groupID null
Info MQTT publish: topic 'zigbee2mqtt/Bouton Biblioteque', payload '{"battery":100,"device":{"applicationVersion":3,"friendlyName":"Bouton Biblioteque","ieeeAddr":"0x00158d0002133cdd","manufacturerID":4151,"manufacturerName":"LUMI","model":"WXKG11LM","networkAddress":28722,"powerSource":"Battery","type":"EndDevice"},"linkquality":87,"voltage":3035}'
Debug Received Zigbee message from 'Temp parents', type 'attributeReport', cluster 'msTemperatureMeasurement', data '{"measuredValue":2259}' from endpoint 1 with groupID null
Info MQTT publish: topic 'zigbee2mqtt/Temp parents', payload '{"battery":100,"device":{"applicationVersion":3,"dateCode":"20161129","friendlyName":"Temp parents","hardwareVersion":30,"ieeeAddr":"0x00158d00022736c1","manufacturerID":4151,"manufacturerName":"LUMI","model":"WSDCGQ11LM","networkAddress":60747,"powerSource":"Battery","softwareBuildID":"3000-0001","stackVersion":2,"type":"EndDevice","zclVersion":1},"humidity":62.1,"linkquality":239,"pressure":983,"temperature":22.59,"voltage":3005}'
Debug Received Zigbee message from 'Temp parents', type 'attributeReport', cluster 'msRelativeHumidity', data '{"measuredValue":6422}' from endpoint 1 with groupID null
Info MQTT publish: topic 'zigbee2mqtt/Temp parents', payload '{"battery":100,"device":{"applicationVersion":3,"dateCode":"20161129","friendlyName":"Temp parents","hardwareVersion":30,"ieeeAddr":"0x00158d00022736c1","manufacturerID":4151,"manufacturerName":"LUMI","model":"WSDCGQ11LM","networkAddress":60747,"powerSource":"Battery","softwareBuildID":"3000-0001","stackVersion":2,"type":"EndDevice","zclVersion":1},"humidity":64.22,"linkquality":247,"pressure":983,"temperature":22.59,"voltage":3005}'
Debug Received Zigbee message from 'Temp parents', type 'attributeReport', cluster 'msPressureMeasurement', data '{"measuredValue":983,"scale":-1,"scaledValue":9838}' from endpoint 1 with groupID null
Info MQTT publish: topic 'zigbee2mqtt/Temp parents', payload '{"battery":100,"device":{"applicationVersion":3,"dateCode":"20161129","friendlyName":"Temp parents","hardwareVersion":30,"ieeeAddr":"0x00158d00022736c1","manufacturerID":4151,"manufacturerName":"LUMI","model":"WSDCGQ11LM","networkAddress":60747,"powerSource":"Battery","softwareBuildID":"3000-0001","stackVersion":2,"type":"EndDevice","zclVersion":1},"humidity":64.22,"linkquality":239,"pressure":983,"temperature":22.59,"voltage":3005}'
