Je n’arrive plus à connecter le plugin au compte Daikin.
Pouvez vous m’aider?
Starting DaikinToMQTT
info: => Load configuration
info: => Connect to MQTT
info: => Connect to Daikin
info: DaikinToMQTT Started !!
OPError: invalid_grant (The provided authorization code or refresh token is invalid.)
at processResponse (/var/www/html/plugins/daikinRCCloud/resources/daikintomqtt/node_modules/openid-client/lib/helpers/process_response.js:38:13)
at Client.grant (/var/www/html/plugins/daikinRCCloud/resources/daikintomqtt/node_modules/openid-client/lib/client.js:1354:22)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async #refresh (/var/www/html/plugins/daikinRCCloud/resources/daikintomqtt/node_modules/daikin-controller-cloud/dist/onecta/oidc-client.js:52:16)
at async #getTokenSet (/var/www/html/plugins/daikinRCCloud/resources/daikintomqtt/node_modules/daikin-controller-cloud/dist/onecta/oidc-client.js:94:24) {
error: 'invalid_grant',
error_description: 'The provided authorization code or refresh token is invalid.'
