Erreur notification
depuis quelque jours j’ai cette erreur nouveau sur jeedom
Field « Volume (0-100) » has to contain integer between 0 to 100
voici le log
[2022-05-10 11:46:53][INFO] : Stopping daemon
[2022-05-10 11:49:16][INFO] : Stopping daemon
[2022-05-10 11:49:17][INFO] : Starting daemon
[2022-05-10 11:49:17][INFO] : Listenning on port 8090
[2022-05-10 11:59:29][INFO] : Send notification with data {"type":"DISPLAY_NOTIF","payload":{"cmdId":"3698","title":"[Jeedom] Message de test","message":"Ceci est un test de message pour la commande Notification","answer":null,"timeout":null,"notificationId":16521767695426,"otherAskCmdId":null,"options":[],"files":[],"time":1652176769,"id":"defaultNotif","channel":"default","index":0}}
[2022-05-10 11:59:41][INFO] : Send notification with data {"type":"DISPLAY_NOTIF","payload":{"cmdId":"3705","title":"[Jeedom] Message de test","message":"Ceci est un test de message pour la commande Notifier les appareils JC","answer":null,"timeout":null,"notificationId":16521767811480,"otherAskCmdId":["3698"],"options":[],"files":[],"time":1652176781,"id":"defaultNotif","channel":"default","index":0}}
[2022-05-10 11:59:41][INFO] : Send notification with data {"type":"DISPLAY_NOTIF","payload":{"cmdId":"3705","title":"[Jeedom] Message de test","message":"Ceci est un test de message pour la commande Notifier les appareils JC","answer":null,"timeout":null,"notificationId":16521767811480,"otherAskCmdId":["3914"],"options":[],"files":[],"time":1652176781,"id":"defaultNotif","channel":"default","index":0}}
[2022-05-10 11:59:46][ERROR] : Field "Volume (0-100)" has to contain integer between 0 to 100
[2022-05-10 12:01:03][ERROR] : Field "Volume (0-100)" has to contain integer between 0 to 100
[2022-05-10 12:07:10][ERROR] : Field "Volume (0-100)" has to contain integer between 0 to 100
[2022-05-10 12:07:31][ERROR] : Field "Volume (0-100)" has to contain integer between 0 to 100
[2022-05-10 12:08:41][ERROR] : Field "Volume (0-100)" has to contain integer between 0 to 100
[2022-05-10 12:08:50][ERROR] : Field "Volume (0-100)" has to contain integer between 0 to 100
[2022-05-10 12:08:57][ERROR] : Field "Volume (0-100)" has to contain integer between 0 to 100
[2022-05-10 12:18:52][DEBUG] : saveNotifAll - info received : ["3914","3698"]
[2022-05-10 12:19:09][DEBUG] : saveNotifAll - info received : ["3914","3698"]
[2022-05-10 12:19:20][DEBUG] : ¤¤¤¤¤ only send the config file without enrichment for apikey c756b74e64cad6be72f20bd4a3e31ea6
[2022-05-10 12:19:20][DEBUG] : ¤¤¤¤¤ only send the config file without enrichment for apikey 0cd99b8f05a658a4b8e562aba27ed60d
[2022-05-10 12:21:25][DEBUG] : getWidgets for all widgets with full config
on a plutôt l’habitude de voir un post commencer par un « bonjour » à minimum … visiblement certaines choses « basic » se perdent ici !.. :confused:
Edit : ah non, visiblement rien de basic, la remarque avait déjà été faite sur un précédent message, sans être réellement comprise/prise en compte…
il manque les infos qu’on demande systématiquement ici
les logs partagés ne sont pas formattées pour être plus lisibles → en utilisant le bouton </>
Edit : tu es bien trop gentil @Mips :slight_smile:
Bonjour @tomitomas !
Je voulais lire le log moi :wink:
@castille38 Qu’avez-vous configuré comme volume du coup ?
Je pense que le message est assez explicite et très clair une fois correctement formaté.
@castille38
Je vous invite à lire ce post sur les règles d’usage sur le forum https://community.jeedom.com/FAQ que vous avez accepté de respecter en vous inscrivant.
Et celui-ci expliquant Comment nous aider à vous aider - ou Comment poser une bonne question?
désolé pour maladresse je suis tellement focalisé sur le problème que j’en oubli les bonnes manières
Jeedom Core : 4.2.15
Version JC : 1.2.0
Equipements :
  francois iphone : v1.2.0 sur ios
  patrick iphone : v1.2.0 sur ios
JeedomConnect.log (149,4 Ko)
je ne sais pas où configurer le volume
En fait, en relisant le log, je ne suis pas convaincu que l’erreur est en rapport avec la notif…
pour répondre, le volume d’une notification se configure … dans l’écran de configuration des notifications
L’erreur est plus en rapport avec le tts, est-ce que vous n’auriez pas un scénario qui utilise cette commande?
A priori vous avez entré une valeur incorrecte:
merci pour les infos.
Lorsque l’erreur apparait, n’es tu pas simplement en train d’appuyer sur le bouton tester d’une commande nommé tts sur tes équipements JC ??
on voit dans les précédents logs les titres "title":"[Jeedom] Message de test" d’où mon interrogation !
Si c’est le cas, alors le message d’erreur est « normal ».
Si ce n’est pas le cas, alors il doit y avoir un scénario mal renseigné, comme l’indique @Mips précédemment
Merci pour votre retour
ça fonctionne correctement là c’étais un problème dans le scenario
