Erreur de mise a jour 4.3.1 vers 4.3.2
Qui aurait un avis ?
Bien Cordialement
Log joint ci dessous
START UPDATE]
****Update from 4.3.1 (2022-10-19 09:34:45)****
Parameters : {"preUpdate":"0","backup::before":"1","plugins":"1","core":"1","force":"0","update::reapply":""}
Send begin of update event | OK
Check updateError during update : Fichier introuvable : /var/www/html/core/php///core/repo/marché.repo.phpDetails : Array
[0] => Array
[file] => /var/www/html/core/php/core.inc.php
[line] => 65
[function] => include_file
[args] => Array
[0] => core/repo
[1] => marché.repo.php
[2] => repo
[1] => Array
[function] => jeedomAutoload
[args] => Array
[0] => repo_marché
[2] => Array
[function] => spl_autoload_call
[args] => Array
[0] => repo_marché
[3] => Array
[file] => /var/www/html/core/class/update.class.php
[line] => 82
[function] => class_exists
[args] => Array
[0] => repo_marché
[4] => Array
[file] => /var/www/html/install/update.php
[line] => 65
[function] => checkAllUpdate
[class] => update
[type] => ::
[args] => Array
[0] =>
[1] =>
[END UPDATE ERROR]
PHP Fatal error: Uncaught Exception: Fichier introuvable : /var/www/html/core/php///core/repo/marché.repo.php in /var/www/html/core/php/utils.inc.php:74
Stack trace:
#0 /var/www/html/core/php/core.inc.php(65): include_file('core/repo', 'march\xC3\xA9.repo.ph', 'repo')
#1 [internal function]: jeedomAutoload('repo_march\xC3\xA9')
#2 [internal function]: spl_autoload_call('repo_march\xC3\xA9')
#3 /var/www/html/core/class/update.class.php(82): class_exists('repo_march\xC3\xA9')
#4 /var/www/html/install/update.php(65): update::checkAllUpdate('', false)
#5 {main}
thrown in /var/www/html/core/php/utils.inc.php on line 74
C’est quoi comme langue votre log?
Effectivement il vaut toujours mieux désactiver les extensions de navigateur sur les pages Jeedom
Un membre avait déjà eu le cas avec le traducteur sur le plugin JC
Sur Chrom je [quote=« Patrice1251, post:1, topic:92869, full:true »]
Bien Cordialement
START UPDATE]
[0] => Array
[line] => 65
[args] => Array
[0] => core/repo
[2] => repo
[1] => Array
[args] => Array
[0] => repo_marché
[2] => Array
[args] => Array
[0] => repo_marché
[3] => Array
[line] => 82
[args] => Array
[0] => repo_marché
[4] => Array
[line] => 65
[class] => update
[type] => ::
[args] => Array
[0] =>
[1] =>
[END UPDATE ERROR]
Stack trace:
#5 {main}
[/quote]
Merci pour votre reponse.
Jutilise Chrom utilise la traduction auto n est pas installé et seul l anglais est installé…
Que conseillez vous ?.
Crodialement
Patrice1251:
Que conseillez-vous ?
Essayer avec un autre navigateur ?
Desolé je ne comprend pas
Bison
Octobre 19, 2022, 10:36
8
Ce qui a été dit c’est que :
Le fichier s’appelle en vérité market.repo.php
Ton navigateur à l’évidence parle de marché.repo.php il fait donc une traduction qui est fortement nuisible au processus d’update de Jeedom
Il faut donc désactiver la traduction automatique dans les paramètres du navigateur. En principe on le trouve vite en tapant « langue » dans les paramètres du navigateur et il faut désactiver la traduction.
Patrice1251:
core/repo
Desolé mais avec FireFoxe sans traduction l erreur est identique
Bonjour.
Tout a été dit depuis la réponse de Furaxworld . Vous avez une traduction automatique qui créer cette situation.
Vous devrez avoir un plugin ou une extension dans vos navigateurs qui cause cette erreur.
Désactivez-les ou forcez Jeedom en UK sans traduire en FR.
Vous devez pouvoir tester avec un navigateur en mode privé.
La langue de jeedom est paramétré en Anglais, les menus sont en Anglais, donc pas de traduction faite par FireFox qui est lui même en Anglais.
Pourtant l’erreur subsiste !
si besoin je peux faire une copie d’ecran…
Le fait qu’il y a dans les logs, le mot : marché
Signifie qu’il y a une traduction logiciel.
Testez avec Edge et en mode sans échec.
La vérité est peut-être ailleurs, ce qui est certain c’est qu’il ne devrait en aucun cas apparaitre marché.repo.php où que ce soit. Peut-être la mise à jour qui a fait ressortir un problème sous-jacent ? @Fabrice a raison, pour le moment il faut continuer de creuser pour exclure définitivement une erreur due au navigateur
Dans ubuntu FireFox en Anglais …Idem
Dans Windows 10moode sans echec avec reseau ( 5 ) et Edge en anglais Idem…
Réglages/éditeur de fichier fait un screen du répertoire core/repo ?
JeeBox:repo:% ls -l
total 108
-rwxrwxr-x 1 www-data www-data 1910 Oct 17 15:25 file.repo.php
-rwxrwxr-x 1 www-data www-data 7685 Oct 17 15:25 github.repo.php
-rwxrwxr-x 1 www-data www-data 15363 Oct 17 15:25 market.display.repo.php
-rwxrwxr-x 1 www-data www-data 16652 Oct 17 15:25 market.list.repo.php
-rwxrwxr-x 1 www-data www-data 43279 Oct 17 15:25 market.repo.php
-rwxrwxr-x 1 www-data www-data 8261 Oct 17 15:25 samba.repo.php
-rwxrwxr-x 1 www-data www-data 3699 Oct 17 15:25 url.repo.php
JeeBox:repo:%
Merci…
Tu peux partager une copie d’écran de la page de configuration Mises à jour/Market , principalement la Source de mise à jour ?
Dans la même idée une copie d’écran du retour de l’extraction de la table update via la configuration Jeedom, onglet OS/DB, Administration base de donnée :
Pas mal avec le traducteur en français sur community.
Voila
Market.pdf (96,6 Ko)
Table-update.pdf (134,1 Ko)
Pouvez-vous vérifier ceci afin d’être certain que vous n’avez pas d’extensions sur chrome
chrome://extensions/
Ainsi que ceci :
Edit:
Avez-vous essayé de faire la mise à jour par l’URL locale et non pas par OVH?
