Bonjour, je n’arrive pas à installer les dépendances Zigbee. Sachant que je viens d’une fresh install sur un rpi4
Voici les logs des dépendances:
Found existing installation: aiohttp 3.8.1
Uninstalling aiohttp-3.8.1:
Successfully uninstalled aiohttp-3.8.1
Attempting uninstall: zigpy
Found existing installation: zigpy 0.47.3
Uninstalling zigpy-0.47.3:
Successfully uninstalled zigpy-0.47.3
Attempting uninstall: zigpy-xbee
Found existing installation: zigpy-xbee 0.14.0
Uninstalling zigpy-xbee-0.14.0:
Successfully uninstalled zigpy-xbee-0.14.0
Successfully installed aiohttp-3.8.1 aiosignal-1.2.0 aiosqlite-0.17.0 async-timeout-4.0.2 attrs-21.4.0 cffi-1.15.1 charset-normalizer-2.1.0 crccheck-1.1 cryptography-37.0.4 frozenlist-1.3.0 idna-3.3 multidict-6.0.2 pycparser-2.21 pyserial-3.5 pyserial-asyncio-0.6 typing_extensions-4.3.0 voluptuous-0.13.1 yarl-1.7.2 zigpy-0.47.3 zigpy-xbee-0.14.0
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 20
+ sudo pip3 install --force-reinstall --upgrade zigpy-deconz==0.16.0
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting zigpy-deconz==0.16.0
Using cached https://www.piwheels.org/simple/zigpy-deconz/zigpy_deconz-0.16.0-py3-none-any.whl (30 kB)
Collecting pyserial-asyncio
Using cached https://www.piwheels.org/simple/pyserial-asyncio/pyserial_asyncio-0.6-py3-none-any.whl (7.5 kB)
Collecting zigpy>=0.40.0
Using cached https://www.piwheels.org/simple/zigpy/zigpy-0.47.3-py3-none-any.whl (136 kB)
Collecting cryptography
Using cached https://www.piwheels.org/simple/cryptography/cryptography-37.0.4-cp39-cp39-linux_armv7l.whl (2.5 MB)
Collecting voluptuous
Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.13.1-py3-none-any.whl (35 kB)
Collecting aiohttp
Using cached https://www.piwheels.org/simple/aiohttp/aiohttp-3.8.1-cp39-cp39-linux_armv7l.whl (1.1 MB)
Collecting crccheck
Using cached https://www.piwheels.org/simple/crccheck/crccheck-1.1-py3-none-any.whl (27 kB)
Collecting aiosqlite>=0.16.0
Using cached https://www.piwheels.org/simple/aiosqlite/aiosqlite-0.17.0-py3-none-any.whl (15 kB)
Collecting pyserial
Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
Collecting typing_extensions>=3.7.2
Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.3.0-py3-none-any.whl (25 kB)
Collecting aiosignal>=1.1.2
Using cached https://www.piwheels.org/simple/aiosignal/aiosignal-1.2.0-py3-none-any.whl (8.2 kB)
Collecting attrs>=17.3.0
Using cached https://www.piwheels.org/simple/attrs/attrs-21.4.0-py2.py3-none-any.whl (60 kB)
Collecting async-timeout<5.0,>=4.0.0a3
Using cached https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
Collecting charset-normalizer<3.0,>=2.0
Using cached https://www.piwheels.org/simple/charset-normalizer/charset_normalizer-2.1.0-py3-none-any.whl (39 kB)
Collecting yarl<2.0,>=1.0
Using cached https://www.piwheels.org/simple/yarl/yarl-1.7.2-cp39-cp39-linux_armv7l.whl (264 kB)
Collecting frozenlist>=1.1.1
Using cached https://www.piwheels.org/simple/frozenlist/frozenlist-1.3.0-cp39-cp39-linux_armv7l.whl (134 kB)
Collecting multidict<7.0,>=4.5
Using cached https://www.piwheels.org/simple/multidict/multidict-6.0.2-cp39-cp39-linux_armv7l.whl (109 kB)
Collecting cffi>=1.12
Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp39-cp39-linux_armv7l.whl (364 kB)
Collecting pycparser
Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
Collecting idna>=2.0
Using cached https://www.piwheels.org/simple/idna/idna-3.3-py3-none-any.whl (64 kB)
Installing collected packages: voluptuous, pyserial, crccheck, typing_extensions, pyserial-asyncio, pycparser, multidict, idna, frozenlist, charset-normalizer, attrs, async-timeout, yarl, cffi, aiosqlite, aiosignal, cryptography, aiohttp, zigpy, zigpy-deconz
Attempting uninstall: voluptuous
Found existing installation: voluptuous 0.13.1
Uninstalling voluptuous-0.13.1:
Successfully uninstalled voluptuous-0.13.1
Attempting uninstall: pyserial
Found existing installation: pyserial 3.5
Uninstalling pyserial-3.5:
Successfully uninstalled pyserial-3.5
Attempting uninstall: crccheck
Found existing installation: crccheck 1.1
Uninstalling crccheck-1.1:
Successfully uninstalled crccheck-1.1
Attempting uninstall: typing_extensions
Found existing installation: typing_extensions 4.3.0
Uninstalling typing_extensions-4.3.0:
Successfully uninstalled typing_extensions-4.3.0
Attempting uninstall: pyserial-asyncio
Found existing installation: pyserial-asyncio 0.6
Uninstalling pyserial-asyncio-0.6:
Successfully uninstalled pyserial-asyncio-0.6
Attempting uninstall: pycparser
Found existing installation: pycparser 2.21
Uninstalling pycparser-2.21:
Successfully uninstalled pycparser-2.21
Attempting uninstall: multidict
Found existing installation: multidict 6.0.2
Uninstalling multidict-6.0.2:
Successfully uninstalled multidict-6.0.2
Attempting uninstall: idna
Found existing installation: idna 3.3
Uninstalling idna-3.3:
Successfully uninstalled idna-3.3
Attempting uninstall: frozenlist
Found existing installation: frozenlist 1.3.0
Uninstalling frozenlist-1.3.0:
Successfully uninstalled frozenlist-1.3.0
Attempting uninstall: charset-normalizer
Found existing installation: charset-normalizer 2.1.0
Uninstalling charset-normalizer-2.1.0:
Successfully uninstalled charset-normalizer-2.1.0
Attempting uninstall: attrs
Found existing installation: attrs 21.4.0
Uninstalling attrs-21.4.0:
Successfully uninstalled attrs-21.4.0
Attempting uninstall: async-timeout
Found existing installation: async-timeout 4.0.2
Uninstalling async-timeout-4.0.2:
Successfully uninstalled async-timeout-4.0.2
Attempting uninstall: yarl
Found existing installation: yarl 1.7.2
Uninstalling yarl-1.7.2:
Successfully uninstalled yarl-1.7.2
Attempting uninstall: cffi
Found existing installation: cffi 1.15.1
Uninstalling cffi-1.15.1:
Successfully uninstalled cffi-1.15.1
Attempting uninstall: aiosqlite
Found existing installation: aiosqlite 0.17.0
Uninstalling aiosqlite-0.17.0:
Successfully uninstalled aiosqlite-0.17.0
Attempting uninstall: aiosignal
Found existing installation: aiosignal 1.2.0
Uninstalling aiosignal-1.2.0:
Successfully uninstalled aiosignal-1.2.0
Attempting uninstall: cryptography
Found existing installation: cryptography 37.0.4
Uninstalling cryptography-37.0.4:
Successfully uninstalled cryptography-37.0.4
Attempting uninstall: aiohttp
Attempting uninstall: zigpy-deconz
Found existing installation: zigpy-deconz 0.16.0
Uninstalling zigpy-deconz-0.16.0:
Successfully uninstalled zigpy-deconz-0.16.0
Successfully installed aiohttp-3.8.1 aiosignal-1.2.0 aiosqlite-0.17.0 async-timeout-4.0.2 attrs-21.4.0 cffi-1.15.1 charset-normalizer-2.1.0 crccheck-1.1 cryptography-37.0.4 frozenlist-1.3.0 idna-3.3 multidict-6.0.2 pycparser-2.21 pyserial-3.5 pyserial-asyncio-0.6 typing_extensions-4.3.0 voluptuous-0.13.1 yarl-1.7.2 zigpy-0.47.3 zigpy-deconz-0.16.0
+ echo 21
+ sudo pip3 install --force-reinstall --upgrade zigpy-zigate==0.7.4
Collecting zigpy-zigate==0.7.4
Using cached https://www.piwheels.org/simple/zigpy-zigate/zigpy_zigate-0.7.4-py3-none-any.whl (27 kB)
Collecting zigpy>=0.22.2
Collecting pyusb
Using cached https://www.piwheels.org/simple/pyusb/pyusb-1.2.1-py3-none-any.whl (58 kB)
Collecting RPi.GPIO
Using cached https://www.piwheels.org/simple/rpi-gpio/RPi.GPIO-0.7.1-cp39-cp39-linux_armv7l.whl (66 kB)
Collecting aiohttp
Collecting crccheck
Collecting pyserial
Installing collected packages: voluptuous, RPi.GPIO, pyserial, crccheck, typing_extensions, pyusb, pyserial-asyncio, pycparser, multidict, idna, frozenlist, charset-normalizer, attrs, async-timeout, yarl, cffi, aiosqlite, aiosignal, cryptography, aiohttp, zigpy, zigpy-zigate
Attempting uninstall: RPi.GPIO
Found existing installation: RPi.GPIO 0.7.0
ERROR: Cannot uninstall 'RPi.GPIO'. It is a distutils installed project and thus we cannot accurately determine which files belong to it which would lead to only a partial uninstall.
+ echo 22
+ sudo pip3 install --force-reinstall --upgrade bellows==0.30.0
Collecting bellows==0.30.0
Using cached https://www.piwheels.org/simple/bellows/bellows-0.30.0-py3-none-any.whl (158 kB)
Collecting pure-pcapy3==1.0.1
Using cached https://www.piwheels.org/simple/pure-pcapy3/pure_pcapy3-1.0.1-py3-none-any.whl (6.1 kB)
Collecting click-log>=0.2.1
Using cached https://www.piwheels.org/simple/click-log/click_log-0.4.0-py2.py3-none-any.whl (4.5 kB)
Collecting pyserial
Collecting click
Using cached https://www.piwheels.org/simple/click/click-8.1.3-py3-none-any.whl (96 kB)
Collecting zigpy>=0.37.0
Collecting setuptools
Using cached https://www.piwheels.org/simple/setuptools/setuptools-63.2.0-py3-none-any.whl (1.2 MB)
Collecting crccheck
Collecting aiohttp
Installing collected packages: voluptuous, pyserial, crccheck, typing_extensions, setuptools, pyserial-asyncio, pycparser, multidict, idna, frozenlist, click, charset-normalizer, attrs, async-timeout, yarl, pure-pcapy3, click-log, cffi, aiosqlite, aiosignal, cryptography, aiohttp, zigpy, bellows
Attempting uninstall: setuptools
Found existing installation: setuptools 63.2.0
Uninstalling setuptools-63.2.0:
Successfully uninstalled setuptools-63.2.0
Attempting uninstall: click
Found existing installation: click 8.1.3
Uninstalling click-8.1.3:
Successfully uninstalled click-8.1.3
Attempting uninstall: pure-pcapy3
Found existing installation: pure-pcapy3 1.0.1
Uninstalling pure-pcapy3-1.0.1:
Successfully uninstalled pure-pcapy3-1.0.1
Attempting uninstall: click-log
Found existing installation: click-log 0.4.0
Uninstalling click-log-0.4.0:
Successfully uninstalled click-log-0.4.0
Attempting uninstall: bellows
Found existing installation: bellows 0.30.0
Uninstalling bellows-0.30.0:
Successfully uninstalled bellows-0.30.0
Successfully installed aiohttp-3.8.1 aiosignal-1.2.0 aiosqlite-0.17.0 async-timeout-4.0.2 attrs-21.4.0 bellows-0.30.0 cffi-1.15.1 charset-normalizer-2.1.0 click-8.1.3 click-log-0.4.0 crccheck-1.1 cryptography-37.0.4 frozenlist-1.3.0 idna-3.3 multidict-6.0.2 pure-pcapy3-1.0.1 pycparser-2.21 pyserial-3.5 pyserial-asyncio-0.6 setuptools-63.2.0 typing_extensions-4.3.0 voluptuous-0.13.1 yarl-1.7.2 zigpy-0.47.3
+ echo 23
+ sudo pip3 install --force-reinstall --upgrade zigpy==0.46.0
Collecting zigpy==0.46.0
Using cached https://www.piwheels.org/simple/zigpy/zigpy-0.46.0-py3-none-any.whl (133 kB)
Collecting crccheck
Collecting aiohttp
Installing collected packages: voluptuous, crccheck, typing_extensions, pycparser, multidict, idna, frozenlist, charset-normalizer, attrs, async-timeout, yarl, cffi, aiosqlite, aiosignal, cryptography, aiohttp, zigpy
Successfully installed aiohttp-3.8.1 aiosignal-1.2.0 aiosqlite-0.17.0 async-timeout-4.0.2 attrs-21.4.0 cffi-1.15.1 charset-normalizer-2.1.0 crccheck-1.1 cryptography-37.0.4 frozenlist-1.3.0 idna-3.3 multidict-6.0.2 pycparser-2.21 typing_extensions-4.3.0 voluptuous-0.13.1 yarl-1.7.2 zigpy-0.46.0
+ echo 24
+ sudo pip3 install --force-reinstall --upgrade xmodem
Collecting xmodem
Using cached https://www.piwheels.org/simple/xmodem/xmodem-0.4.6-py3-none-any.whl (34 kB)
Installing collected packages: xmodem
Attempting uninstall: xmodem
Found existing installation: xmodem 0.4.6
Uninstalling xmodem-0.4.6:
Successfully uninstalled xmodem-0.4.6
Successfully installed xmodem-0.4.6
+ echo 25
+ sudo pip3 install --force-reinstall --upgrade pycrypto
Collecting pycrypto
Using cached https://www.piwheels.org/simple/pycrypto/pycrypto-2.6.1-cp39-cp39-linux_armv7l.whl (526 kB)
Installing collected packages: pycrypto
Attempting uninstall: pycrypto
Found existing installation: pycrypto 2.6.1
Uninstalling pycrypto-2.6.1:
Successfully uninstalled pycrypto-2.6.1
Successfully installed pycrypto-2.6.1
+ echo 26
+ sudo pip3 install --force-reinstall --upgrade charset-normalizer==2.0.12
Collecting charset-normalizer==2.0.12
Using cached https://www.piwheels.org/simple/charset-normalizer/charset_normalizer-2.0.12-py3-none-any.whl (44 kB)
Installing collected packages: charset-normalizer
Successfully installed charset-normalizer-2.0.12
+ echo 27
+ sudo chmod +x /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
Launch post-install of zigbee dependancy
grep: /usr/local/lib/python3.7/dist-packages/bellows/zigbee/application.py: No such file or directory
/var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh: line 24: [: -eq: unary operator expected
Everything is successfully installed!
+ echo 28
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end zigbee
+ rm /tmp/jeedom_install_in_progress_zigbee
Savez vous comment je dois faire? merci
