Je ne sais pas ou poser ma question, à déplacer si ce n’est pas le bon endroit
Je constate depuis des mois et je ne sais plus apres quelle maj ce type d"erreur dans la log HTTP (avant peut être que cela n’était pas capté ou personne n’essayait de joindre mon jeedom)
[Sat Nov 12 17:06:42.099741 2022] [access_compat:error] [pid 2428] [client 192.168.1.27:54849] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.21/index.php?v=d&p=dashboard
[Sat Nov 12 17:06:42.103518 2022] [access_compat:error] [pid 2428] [client 192.168.1.27:54849] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.21/index.php?v=d&p=dashboard
[Sat Nov 12 17:06:42.103525 2022] [access_compat:error] [pid 2477] [client 192.168.1.27:54848] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.21/index.php?v=d&p=dashboard
[Sat Nov 12 17:25:36.595974 2022] [access_compat:error] [pid 27887] [client 93.177.103.215:58759] AH01797: client denied by server configuration: /var/www/html/.env
[Sat Nov 12 17:54:22.380667 2022] [access_compat:error] [pid 5198] [client 39.104.128.161:43704] AH01797: client denied by server configuration: /var/www/html/api
[Sat Nov 12 17:56:07.947501 2022] [access_compat:error] [pid 5198] [client 194.180.48.125:45462] AH01797: client denied by server configuration: /var/www/html/explore
[Sat Nov 12 18:35:42.915460 2022] [access_compat:error] [pid 2368] [client 194.110.203.60:47216] AH01797: client denied by server configuration: /var/www/html/service
[Sat Nov 12 18:45:50.399622 2022] [access_compat:error] [pid 27887] [client 61.82.109.92:51228] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sat Nov 12 19:13:27.580939 2022] [access_compat:error] [pid 2368] [client 97.103.197.223:49515] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sat Nov 12 19:47:19.334899 2022] [php7:error] [pid 21879] [client 35.198.25.12:47026] script '/var/www/html/wp-login.php' not found or unable to stat
[Sat Nov 12 20:02:29.128627 2022] [access_compat:error] [pid 4670] [client 218.145.61.20:45582] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sat Nov 12 20:13:39.411964 2022] [access_compat:error] [pid 11588] [client 194.180.48.125:38554] AH01797: client denied by server configuration: /var/www/html/explore
[Sat Nov 12 20:16:45.051827 2022] [access_compat:error] [pid 19567] [client 20.106.218.104:49286] AH01797: client denied by server configuration: /var/www/html/.env
[Sat Nov 12 20:16:45.581446 2022] [access_compat:error] [pid 2368] [client 20.106.218.104:49370] AH01797: client denied by server configuration: /var/www/html/.env
[Sat Nov 12 20:38:50.110407 2022] [access_compat:error] [pid 28065] [client 152.89.196.211:49788] AH01797: client denied by server configuration: /var/www/html/actuator
[Sat Nov 12 20:53:42.132221 2022] [access_compat:error] [pid 21879] [client 192.241.196.112:51148] AH01797: client denied by server configuration: /var/www/html/portal
[Sat Nov 12 21:10:53.279660 2022] [access_compat:error] [pid 5198] [client 198.199.94.242:37010] AH01797: client denied by server configuration: /var/www/html/actuator
[Sat Nov 12 21:14:47.937686 2022] [access_compat:error] [pid 21879] [client 222.121.4.4:53038] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sat Nov 12 22:03:23.369159 2022] [access_compat:error] [pid 11588] [client 45.134.144.48:38348] AH01797: client denied by server configuration: /var/www/html/remote
[Sat Nov 12 22:47:19.695380 2022] [access_compat:error] [pid 4670] [client 151.84.25.113:47640] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sat Nov 12 23:16:20.955853 2022] [access_compat:error] [pid 2428] [client 161.35.37.74:47032] AH01797: client denied by server configuration: /var/www/html/ab2g
[Sat Nov 12 23:16:21.101680 2022] [access_compat:error] [pid 5198] [client 161.35.37.74:47048] AH01797: client denied by server configuration: /var/www/html/ab2h
[Sat Nov 12 23:55:49.886481 2022] [access_compat:error] [pid 19567] [client 151.84.25.113:36840] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sun Nov 13 00:42:04.163932 2022] [php7:error] [pid 20720] [client 23.27.104.82:60766] script '/var/www/html/wp-login.php' not found or unable to stat
[Sun Nov 13 00:46:25.294399 2022] [access_compat:error] [pid 20716] [client 86.98.83.3:61552] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sun Nov 13 00:46:28.827955 2022] [access_compat:error] [pid 20719] [client 86.98.83.3:19495] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sun Nov 13 01:29:24.116766 2022] [access_compat:error] [pid 20720] [client 61.52.39.193:42461] AH01797: client denied by server configuration: /var/www/html/boaform
[Sun Nov 13 02:33:18.543217 2022] [access_compat:error] [pid 3102] [client 217.109.159.226:47361] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sun Nov 13 03:48:11.871948 2022] [access_compat:error] [pid 4499] [client 109.237.98.226:60980] AH01797: client denied by server configuration: /var/www/html/.env
[Sun Nov 13 04:18:05.709886 2022] [access_compat:error] [pid 4450] [client 192.241.200.194:45216] AH01797: client denied by server configuration: /var/www/html/owa
[Sun Nov 13 04:58:35.904015 2022] [php7:error] [pid 4396] [client 173.236.137.153:32838] script '/var/www/html/wp-login.php' not found or unable to stat
[Sun Nov 13 06:19:50.505546 2022] [access_compat:error] [pid 12923] [client 111.118.40.97:37183] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sun Nov 13 07:11:04.226526 2022] [access_compat:error] [pid 12923] [client 198.199.95.36:39118] AH01797: client denied by server configuration: /var/www/html/actuator
[Sun Nov 13 07:23:11.370302 2022] [access_compat:error] [pid 12923] [client 59.60.122.179:20481] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sun Nov 13 08:23:34.336866 2022] [access_compat:error] [pid 12869] [client 104.248.200.102:35280] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sun Nov 13 08:54:24.718734 2022] [access_compat:error] [pid 13617] [client 103.60.60.186:58770] AH01797: client denied by server configuration: /var/www/html/.env
[Sun Nov 13 08:56:32.576675 2022] [access_compat:error] [pid 12923] [client 113.118.53.109:46372] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sun Nov 13 09:19:36.866652 2022] [access_compat:error] [pid 13617] [client 222.121.4.4:42227] AH01797: client denied by server configuration: /var/www/html/cgi-bin
[Sun Nov 13 10:04:33.835799 2022] [access_compat:error] [pid 4395] [client 192.168.1.27:59708] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.21/index.php?v=d&p=dashboard
[Sun Nov 13 10:04:33.839541 2022] [access_compat:error] [pid 4395] [client 192.168.1.27:59708] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.21/index.php?v=d&p=dashboard
[Sun Nov 13 10:04:33.841263 2022] [access_compat:error] [pid 12865] [client 192.168.1.27:59715] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.21/index.php?v=d&p=dashboard
Après autant les Ips internes « pourquoi pas » mais les IPs externes là je ne comprends pas trop car je n’accède pas au dashboard depuis internet je ne passe que par Jeedom Connect
Savez vous comment je pourrais répondre cela ?
j’ai lu que cela pourrait être des attaques sur mon jeedom, du moins des robots qui scannent les failles (les trouvent ils ?), comment se prémunir de cela et comment etre sur que ces attaques ne vont au but ? Est ce que ces logs ne sont au final pas « inquiètantes » ?
