voici les logs:
C’est toujours le même schémas: il y a des erreurs, je redémarre la box et il y a quelque info puis une petit série d’erreurs…
ERROR:BLEGateway:[org.bluez.Error.Failed] No discovery started
ERROR:BLEGateway:Connection error
File "/opt/TheengsGateway/lib/python3.9/site-packages/TheengsGateway/ble_gateway.py", line 208, in connect_mqtt
self.client.connect(
File "/opt/TheengsGateway/lib/python3.9/site-packages/paho/mqtt/client.py", line 1435, in connect
return self.reconnect()
File "/opt/TheengsGateway/lib/python3.9/site-packages/paho/mqtt/client.py", line 1598, in reconnect
self._sock = self._create_socket()
File "/opt/TheengsGateway/lib/python3.9/site-packages/paho/mqtt/client.py", line 4609, in _create_socket
sock = self._create_socket_connection()
File "/opt/TheengsGateway/lib/python3.9/site-packages/paho/mqtt/client.py", line 4640, in _create_socket_connection
return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
File "/usr/lib/python3.9/socket.py", line 843, in create_connection
raise err
File "/usr/lib/python3.9/socket.py", line 831, in create_connection
sock.connect(sa)
OSError: [Errno 101] Network is unreachable
raise err
sock.connect(sa)
ERROR:BLEGateway:[org.bluez.Error.NotReady] Resource Not Ready
raise err
sock.connect(sa)
ERROR:BLEGateway:[org.bluez.Error.InProgress] Operation already in progress
raise err
sock.connect(sa)
