217: $json_in = shell_exec(system::getCmdSudo() . self::EXEC_LG .' '. $lgcommand . ' 2>&1');
250: $json_in = shell_exec(system::getCmdSudo() . self::EXEC_LG .' '. $lgcommand . ' 2>&1');
283: $json_in = shell_exec(system::getCmdSudo() . self::EXEC_LG .' '. $lgcommand . ' 2>&1');
377: $lgtvscan = shell_exec(system::getCmdSudo().' '.$execpython .' scan');
406: //$lgtvauth = shell_exec(system::getCmdSudo().' '.$execpython .' --ssl auth '. $tv_info['address'] .' "' . $tv_info['tv_name'] . '"');
441: $lgtvinfo = shell_exec(system::getCmdSudo().' '.$execpython .' --name "' . $tv_info['tv_name'] . '" --ssl swInfo 2>&1');
855: $json_in = shell_exec(system::getCmdSudo() . self::EXEC_LG .' '. $lgcommand );
956: $json_in = shell_exec(system::getCmdSudo() . self::EXEC_LG .' '. $lgcommand );
1571: $sourceRaw = shell_exec(system::getCmdSudo() . ' ' . self::EXEC_LG . ' ' . $cmdSource . ' 2>&1');
1619: $cmd = system::getCmdSudo() . ' ' . self::EXEC_LG . ' --name "' . $tv_info["tv_name"] . '" --ssl getPowerState';
1651: $sourceRaw = shell_exec(system::getCmdSudo() . ' ' . self::EXEC_LG . ' ' . $cmdSource . ' 2>&1');
1868: $ret = shell_exec(system::getCmdSudo().' '.__DIR__ . '/../../resources/venv/bin/python3 '. __DIR__ . '/../../resources/venv/bin/lgtv ' .$command .' '.$mess age.' '.$icon_url);
1878: $ret = shell_exec(system::getCmdSudo().' '.__DIR__ . '/../../resources/venv/bin/python3 '. __DIR__ . '/../../resources/venv/bin/lgtv ' .$command .' '.$mess age.' '.$button_text);
1884: $ret = shell_exec(system::getCmdSudo().' '.__DIR__ . '/../../resources/venv/bin/python3 '. __DIR__ . '/../../resources/venv/bin/lgtv ' .$command .' '.$mess age);
1890: $ret = shell_exec(system::getCmdSudo().' '.__DIR__ . '/../../resources/venv/bin/wakeonlan ' .$command);
1894: $ret = shell_exec(system::getCmdSudo().' '.__DIR__ . '/../../resources/venv/bin/python3 '. __DIR__ . '/../../resources/venv/bin/lgtv ' .$command);
Étant entre deux avions pour les vacances je regarde cela après le 15 juillet
pas de soucis.
Peux tu tester la nouvelle beta ?
Yeees!
TV enregistrée, commande créées!
Je pourrais tester un peu plus demain mais déjà, ça cause!!
merci!
Cordialement
Logfile:
webOS.txt (78,4 Ko)
@Didier3L
Petite chose dans les logs ce matin …mais pas sûr que cela soit directement dû au plugin:
Erreur l'archivage des historiques : {"cmd_id":142204,"archivePackage":3600,"archiveTime":"2026-07-16 03:00:02"} => [MySQL] Error code : 22007 (1292). Truncated incorrect DECIMAL value: 'HDMI 2' : REPLACE INTO historyArch(cmd_id,`datetime`,value) SELECT cmd_id,MIN(`datetime`),avg(CAST(value AS DECIMAL(12,2))) as value
FROM history
WHERE `datetime`
..pour 2 ids: la commande principale « Etat » en Info numérique et « Source active » en info numérique également
Une devrait peu-être être mise en string vs le nom de la source? et état ?
Oui, j’ai cela a corriger.
Je t’invite à clôturer ce sujet si ta TV est découverte
Voir ici ![]()
