Grace aux liens postés par @tomtom j’ai pu modifier le fichier PHP original de ECO2WAT (plugin/ecowatt/core/class/ecowatt.class.php).
Je n’ai modifié et pu tester que la partie TEMPO. Je n’ai pas touché à la partie EJP
Voici le fichier modifié:
<?php
/* This file is part of Jeedom.
* Jeedom is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* Jeedom is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with Jeedom. If not, see <http://www.gnu.org/licenses/>.
/* * ***************************Includes********************************* */
require_once dirname(__FILE__) . '/../../../../core/php/core.inc.php';
require_once dirname(__FILE__) . '/../../vendor/autoload.php';
class ecowatt extends eqLogic {
/* * *************************Attributs****************************** */
public static $_widgetPossibility = array('custom' => true, 'custom::layout' => false);
/* * ***********************Methode static*************************** */
public static function cronHourly() {
$hour = array(
'ejp' => array(1, 6, 12, 16, 19, 23),
'ecowatt' => array(6, 10, 13, 16, 19, 23),
'tempo' => array(6, 10, 13, 16, 19, 23),
foreach (self::byType('ecowatt',true) as $ecowatt) {
if (isset($hour[$ecowatt->getConfiguration('datasource')]) && !in_array(date('H'), $hour[$ecowatt->getConfiguration('datasource')])) {
continue;
$ecowatt->updateInfo();
public static function valueFromUrl($_url) {
$InitPage = curl_init();
curl_setopt($InitPage, CURLOPT_URL, $_url);
curl_setopt($InitPage, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($InitPage, CURLOPT_USERAGENT, 'Le site de Jeedom (www.jeedom.com)');
$dataUrl = curl_exec ($InitPage);
curl_close($InitPage);
return json_decode($dataUrl, true);
/* * *********************Méthodes d'instance************************* */
public function preSave() {
$this->setCategory('energy', 1);
public function postSave() {
$cmd_list = array();
if ($this->getConfiguration('datasource') == 'ejp') {
$cmd_list = array(
'today' => array(
'name' => __('Aujourd\'hui', __FILE__),
'subtype' => 'string',
'order' => 1,
'tomorrow' => array(
'name' => __('Demain', __FILE__),
'order' => 2,
'remainingDays' => array(
'name' => __('EJP restants', __FILE__),
'subtype' => 'numeric',
'order' => 3,
'totalDays' => array(
'name' => __('EJP écoulés', __FILE__),
'order' => 4,
if ($this->getConfiguration('datasource') == 'tempo') {
$cmd_list = array(
'today' => array(
'order' => 1,
'order' => 2,
'blue-remainingDays' => array(
'name' => __('Jours Bleus restants', __FILE__),
'order' => 3,
'blue-totalDays' => array(
'name' => __('Total jours Bleus', __FILE__),
'order' => 4,
'white-remainingDays' => array(
'name' => __('Jours Blancs restants', __FILE__),
'order' => 5,
'white-totalDays' => array(
'name' => __('Total jours Blancs', __FILE__),
'order' => 6,
'red-remainingDays' => array(
'name' => __('Jours Rouges restants', __FILE__),
'order' => 7,
'red-totalDays' => array(
'name' => __('Total jours Rouges', __FILE__),
'order' => 8,
foreach ($this->getCmd() as $cmd) {
if (!isset($cmd_list[$cmd->getLogicalId()]) && $cmd->getLogicalId() != 'refresh') {
$cmd->remove();
foreach ($cmd_list as $key => $cmd_info) {
$cmd = $this->getCmd(null, $key);
if (!is_object($cmd)) {
$cmd = new ecowattCmd();
$cmd->setLogicalId($key);
$cmd->setIsVisible(1);
$cmd->setName($cmd_info['name']);
$cmd->setOrder($cmd_info['order']);
$cmd->setType('info');
$cmd->setSubType($cmd_info['subtype']);
$cmd->setEqLogic_id($this->getId());
$cmd->setEventOnly(1);
$cmd->save();
$refresh = $this->getCmd(null, 'refresh');
if (!is_object($refresh)) {
$refresh = new ecowattCmd();
$refresh->setName(__('Rafraichir', __FILE__));
$refresh->setEqLogic_id($this->getId());
$refresh->setLogicalId('refresh');
$refresh->setType('action');
$refresh->setSubType('other');
$refresh->setOrder(99);
$refresh->save();
$this->updateInfo();
public function updateInfo() {
switch ($this->getConfiguration('datasource')) {
case 'ejp':
$ejpdays = self::valueFromUrl('https://particulier.edf.fr/services/rest/referentiel/searchTempoStore?dateRelevant=' . date('Y-m-d') . '&TypeAlerte=EJP');
$region = 'Ejp' . ucfirst(strtolower(str_replace(array('_', 'EJP'), '', $this->getConfiguration('region-ejp'))));
$value = 'Non déterminé';
if (isset($ejpdays['JourJ'][$region])) {
if ($ejpdays['JourJ'][$region] == 'NON_EJP') {
$value = 'Pas d\'EJP';
} elseif ($ejpdays['JourJ'][$region] == 'EST_EJP') {
$value = 'EJP';
$today = $this->getCmd(null, 'today');
if (is_object($today) && $today->execCmd(null, 2) != $today->formatValue($value)) {
$today->event($value);
if (isset($ejpdays['JourJ1'][$region])) {
if ($ejpdays['JourJ1'][$region] == 'NON_EJP') {
} elseif ($ejpdays['JourJ1'][$region] == 'EST_EJP') {
$value = 'EJP';
$this->checkAndUpdateCmd('tomorrow', $value);
$ejptotaldays = self::valueFromUrl('https://particulier.edf.fr/services/rest/referentiel/historicEJPStore?searchType=ejp');
$region = str_replace(array('_', 'EJP'), '', $this->getConfiguration('region-ejp'));
$this->fillValue('totalDays', $region . '::Total', $ejptotaldays, -1);
$totalDays = $this->getCmd(null, 'totalDays');
$remainingDays = $this->getCmd(null, 'remainingDays')->event(22 - $totalDays->execCmd(null, 2));
break;
case 'tempo':
$tempodays = self::valueFromUrl('https://particulier.edf.fr/services/rest/referentiel/searchTempoStore?dateRelevant=' . date('Y-m-d') . '&TypeAlerte=TEMPO');
$this->fillValue('today', 'couleurJourJ', $tempodays);
$this->fillValue('tomorrow', 'couleurJourJ1', $tempodays);
$tempodays = self::valueFromUrl('https://particulier.edf.fr/services/rest/referentiel/getNbTempoDays?TypeAlerte=TEMPO');
$this->fillValue('white-remainingDays', 'PARAM_NB_J_BLANC', $tempodays);
$this->fillValue('blue-remainingDays', 'PARAM_NB_J_BLEU', $tempodays);
$this->fillValue('red-remainingDays', 'PARAM_NB_J_ROUGE', $tempodays);
$tempodays = self::valueFromUrl('https://particulier.edf.fr/services/rest/referentiel/getConfigProperty?PARAM_CONFIG_PROPERTY=param.nb.bleu.periode');
$this->fillValue('blue-totalDays', 'param.nb.bleu.periode', $tempodays);
$tempodays = self::valueFromUrl('https://particulier.edf.fr/services/rest/referentiel/getConfigProperty?PARAM_CONFIG_PROPERTY=param.nb.blanc.periode');
$this->fillValue('white-totalDays', 'param.nb.blanc.periode', $tempodays);
$tempodays = self::valueFromUrl('https://particulier.edf.fr/services/rest/referentiel/getConfigProperty?PARAM_CONFIG_PROPERTY=param.nb.rouge.periode');
$this->fillValue('red-totalDays', 'param.nb.rouge.periode', $tempodays);
break;
$this->refreshWidget();
public function fillValue($_logicalId, $_value, $_data, $_default = 'N/A') {
$result = $_default;
foreach (explode('::', $_value) as $key) {
if (isset($_data[$key])) {
$_data = $_data[$key];
} else {
$_data = null;
break;
if (!is_array($_data) && $_data !== null) {
$result = $_data;
$this->checkAndUpdateCmd($_logicalId, $result);
public function toHtml($_version = 'dashboard') {
$replace = $this->preToHtml($_version, array('#background-color#' => '#bdc3c7'));
if (!is_array($replace)) {
return $replace;
$version = jeedom::versionAlias($_version);
foreach ($this->getCmd('info') as $cmd) {
$replace['#' . $cmd->getLogicalId() . '_history#'] = '';
$replace['#' . $cmd->getLogicalId() . '_id#'] = $cmd->getId();
$replace['#' . $cmd->getLogicalId() . '#'] = $cmd->execCmd(null, 2);
$replace['#' . $cmd->getLogicalId() . '_collect#'] = $cmd->getCollectDate();
if ($cmd->getIsHistorized() == 1) {
$replace['#' . $cmd->getLogicalId() . '_history#'] = 'history cursor';
if (is_object($refresh)) {
$replace['#refresh_id#'] = $refresh->getId();
if ($this->getConfiguration('datasource') == 'ecowatt') {
return $this->postToHtml($_version, template_replace($replace, getTemplate('core', $version, 'ecowatt_ecowatt', 'ecowatt')));
return $this->postToHtml($_version, template_replace($replace, getTemplate('core', $version, 'ecowatt_ejp', 'ecowatt')));
return $this->postToHtml($_version, template_replace($replace, getTemplate('core', $version, 'ecowatt_tempo', 'ecowatt')));
/* * **********************Getteur Setteur*************************** */
class ecowattCmd extends cmd {
/* * *********************Methode d'instance************************* */
public function execute($_options = array()) {
if ($this->getLogicalId() == 'refresh') {
$eqLogic = $this->getEqLogic();
$eqLogic->updateInfo();
A priori ça fonctionne en l’état
