Je voulais mettre ce post dans le salon des beta testeurs, mais malheureusement, je ne sais toujours pas poster dedans. Et pourtant j’avais envoyé un mail au support pour ça. Désolé donc si c’est pas exactement le bon salon.
Pour info, je viens de mettre a jour vers la dernière version beta de Philips Hue, et j’ai plus rien qui fonctionne ![]()
J’ai ceci dans les logs:
Et encore ceci dans les logs du démon :
0119|at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":"http","transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-T**OK**EN","xsrfHeaderName":"X-XSRF-T**OK**EN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/x-www-form-urlencoded","User-Agent":"axios/1.5.0","Content-Length":"624","Accept-Encoding":"gzip, compress, deflate, br"},"method":"post","url":"http://127.0.0.1:80/plugins/philipsHue/core/php/jeephilipsHue.php?apikey=AsxHyZmf82yNX0r19Nn4ltPtPXG1WSWv5FADcCHdXjWDr3qpbYRVDMOkh9W5fRbO","data":"{\"bridge\":{\"1\":\"[{\"creationtime\":\"2023-10-17T10:22:51Z\",\"data\":[{\"dimming\":{\"brightness\":100.0},\"id\":\"27cdaf3e-a84a-46f2-a328-9ccb711c800f\",\"id_v1\":\"/groups/2\",\"on\":{\"on\":true},\"owner\":{\"rid\":\"7743d8b5-46c6-4166-a1e2-8d7307279742\",\"rtype\":\"room\"},\"type\":\"grouped_light\"},{\"dimming\":{\"brightness\":100.0},\"id\":\"da31e965-3c67-4af2-aaa9-61ae4620b977\",\"id_v1\":\"/groups/0\",\"on\":{\"on\":true},\"owner\":{\"rid\":\"4e52ed78-0874-4706-ae60-b89387e03793\",\"rtype\":\"bridge_home\"},\"type\":\"grouped_light\"}],\"id\":\"1182aff3-e497-4e21-b2cd-1ea8d8bea5df\",\"type\":\"update\"}]\"}}"},"code":"ERR_BAD_RESPONSE","status":500}
0120|[2023-10-17 10:26:39]ERROR : Error on send to jeedom : {"message":"Request failed with status code 500","name":"AxiosError","stack":"AxiosError: Request failed with status code 500
0121|at settle (/var/www/html/plugins/philipsHue/resources/philipsHued/node_modules/axios/dist/node/axios.cjs:1913:12)
0122|at IncomingMessage.handleStreamEnd (/var/www/html/plugins/philipsHue/resources/philipsHued/node_modules/axios/dist/node/axios.cjs:2995:11)
0123|at IncomingMessage.emit (node:events:526:35)
0124|at endReadableNT (node:internal/streams/readable:1359:12)
0125|at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":"http","transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-T**OK**EN","xsrfHeaderName":"X-XSRF-T**OK**EN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/x-www-form-urlencoded","User-Agent":"axios/1.5.0","Content-Length":"475","Accept-Encoding":"gzip, compress, deflate, br"},"method":"post","url":"http://127.0.0.1:80/plugins/philipsHue/core/php/jeephilipsHue.php?apikey=AsxHyZmf82yNX0r19Nn4ltPtPXG1WSWv5FADcCHdXjWDr3qpbYRVDMOkh9W5fRbO","data":"{\"bridge\":{\"1\":\"[{\"creationtime\":\"2023-10-17T10:26:39Z\",\"data\":[{\"id\":\"10fb3108-2df5-429b-94d1-32b329f9b619\",\"id_v1\":\"/sensors/19\",\"light\":{\"light_level\":23428,\"light_level_report\":{\"changed\":\"2023-10-17T10:26:39.319Z\",\"light_level\":23428},\"light_level_valid\":true},\"owner\":{\"rid\":\"9296b377-0419-4b09-8a59-61bd2066b655\",\"rtype\":\"device\"},\"type\":\"light_level\"}],\"id\":\"3d412f00-1852-4d05-995a-d4950d1a9d1a\",\"type\":\"update\"}]\"}}"},"code":"ERR_BAD_RESPONSE","status":500}
Par avance, merci de votre aide ![]()
