La migration s’est relativement bien passé hormis quelques bricoles sur les widgets. Par contre, gros soucis avec OpenVPN dont le statut du plugin demeure NOK ! Il y a ceci dans le logfile Openvpn_update :
Launch install of openvpn
Get:1 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Get:2 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Get:4 http://ftp.uk.debian.org/debian buster-updates InRelease [51.9 kB]
Err:3 https://repo.jeedom.com/odroid stable InRelease
502 Bad Gateway [IP: 51.178.69.128 443]
Hit:5 https://oph.mdrjr.net/meveric all InRelease
Hit:6 https://oph.mdrjr.net/meveric buster InRelease
Get:7 http://www.deb-multimedia.org buster InRelease [15.8 kB]
Reading package lists...
E: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'stable-updates' to 'oldstable-updates'
E: Repository 'http://www.deb-multimedia.org buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
Building dependency tree...
Reading state information...
The following additional packages will be installed:
libpkcs11-helper1
Suggested packages:
resolvconf openvpn-systemd-resolved
Recommended packages:
easy-rsa
libpkcs11-helper1 openvpn
0 upgraded, 2 newly installed, 0 to remove and 62 not upgraded.
Need to get 464 kB/509 kB of archives.
After this operation, 1,299 kB of additional disk space will be used.
Err:1 http://ftp.uk.debian.org/debian buster/main arm64 openvpn arm64 2.4.7-1
404 Not Found [IP: 78.129.164.123 80]
E: Failed to fetch http://ftp.uk.debian.org/debian/pool/main/o/openvpn/openvpn_2.4.7-1_arm64.deb 404 Not Found [IP: 78.129.164.123 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Everything is successfully installed!saisissez ou collez du code ici
Je constate que chaque 5 minutes une nouvelle tentative du calcul des dépendances a lieu.
Une piste ? Coïncidence avec la migration sous Buster ? Une chance que cela aboutisse automatiquement dans quelques heures ?
D’avance merci car je ne suis pas un expert !
