Dépendances Arlo ne s'installe
j’utilise depuis de nombreuses années, c’est aujourd’hui mon premier message ici.
Je n’arrive pas à installer les dépendances du plugins Arlo.
voici le log et ma page santé:
merci pour votre aide
 [2024-01-26 09:10:05] *************************************
[2024-01-26 09:10:05] *   Launch install of dependencies  *
[2024-01-26 09:10:05] Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
[2024-01-26 09:10:05] Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
[2024-01-26 09:10:05] Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
[2024-01-26 09:10:11] Reading package lists...
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
[2024-01-26 09:10:11] *****************************
[2024-01-26 09:10:11] Install modules using apt-get
[2024-01-26 09:10:12] Building dependency tree...
[2024-01-26 09:10:12] Reading state information...
[2024-01-26 09:10:14] python3 is already the newest version (3.7.3-1).
[2024-01-26 09:10:14] python3-setuptools is already the newest version (40.8.0-1).
[2024-01-26 09:10:14] python3-setuptools set to manually installed.
[2024-01-26 09:10:14] python3-pip is already the newest version (18.1-5+rpt1).
[2024-01-26 09:10:14] The following additional packages will be installed:
[2024-01-26 09:10:14] libpython3.7 libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib
[2024-01-26 09:10:14] python3.7 python3.7-dev python3.7-minimal python3.7-venv
[2024-01-26 09:10:14] Suggested packages:
[2024-01-26 09:10:14] python3-openssl python3-socks python3.7-doc binfmt-support
[2024-01-26 09:10:14] The following NEW packages will be installed:
[2024-01-26 09:10:14] python3-venv python3.7-venv
[2024-01-26 09:10:14] The following packages will be upgraded:
[2024-01-26 09:10:14] python3-requests python3.7 python3.7-dev python3.7-minimal
[2024-01-26 09:10:14] 8 upgraded, 2 newly installed, 0 to remove and 278 not upgraded.
[2024-01-26 09:10:14] Need to get 53.1 MB of archives.
[2024-01-26 09:10:14] After this operation, 119 kB of additional disk space will be used.
[2024-01-26 09:10:14] Err:1 http://raspbian.raspberrypi.org/raspbian buster/main armhf python3.7-dev armhf 3.7.3-2+deb10u5
[2024-01-26 09:10:14] 404  Not Found [IP: 93.93.128.193 80]
[2024-01-26 09:10:14] Err:2 http://raspbian.raspberrypi.org/raspbian buster/main armhf libpython3.7-dev armhf 3.7.3-2+deb10u5
[2024-01-26 09:10:14] Err:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf libpython3.7 armhf 3.7.3-2+deb10u5
[2024-01-26 09:10:14] Err:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf python3.7 armhf 3.7.3-2+deb10u5
[2024-01-26 09:10:14] Err:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf libpython3.7-stdlib armhf 3.7.3-2+deb10u5
[2024-01-26 09:10:14] Err:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf python3.7-minimal armhf 3.7.3-2+deb10u5
[2024-01-26 09:10:15] Err:7 http://raspbian.raspberrypi.org/raspbian buster/main armhf libpython3.7-minimal armhf 3.7.3-2+deb10u5
[2024-01-26 09:10:15] 404  Not Found [IP: 93.93.128.193 80]
[2024-01-26 09:10:15] Err:9 http://raspbian.raspberrypi.org/raspbian buster/main armhf python3.7-venv armhf 3.7.3-2+deb10u5
[2024-01-26 09:10:15] Get:10 http://raspbian.raspberrypi.org/raspbian buster/main armhf python3-venv armhf 3.7.3-1 [1,180 B]
[2024-01-26 09:10:15] Get:8 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf python3-requests all 2.21.0-1+deb10u1 [67.4 kB]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/python3.7-dev_3.7.3-2+deb10u5_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/libpython3.7-dev_3.7.3-2+deb10u5_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/libpython3.7_3.7.3-2+deb10u5_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/python3.7_3.7.3-2+deb10u5_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/libpython3.7-stdlib_3.7.3-2+deb10u5_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/python3.7-minimal_3.7.3-2+deb10u5_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/libpython3.7-minimal_3.7.3-2+deb10u5_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/python3.7-venv_3.7.3-2+deb10u5_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
[2024-01-26 09:10:15] Fetched 68.5 kB in 1s (76.2 kB/s)
[2024-01-26 09:10:15] Reading package lists...
[2024-01-26 09:10:16] Building dependency tree...
[2024-01-26 09:10:16] Reading state information...
[2024-01-26 09:10:17] The following additional packages will be installed:
[2024-01-26 09:10:17] libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
[2024-01-26 09:10:17] libavutil56 libpostproc55 libswresample3 libswscale5 libwebpmux3
[2024-01-26 09:10:17] Suggested packages:
[2024-01-26 09:10:18] ffmpeg-doc
[2024-01-26 09:10:18] The following packages will be upgraded:
[2024-01-26 09:10:18] ffmpeg libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
[2024-01-26 09:10:18] libavutil56 libpostproc55 libswresample3 libswscale5 libwebpmux3
[2024-01-26 09:10:18] 11 upgraded, 0 newly installed, 0 to remove and 275 not upgraded.
[2024-01-26 09:10:18] Need to get 14.6 MB of archives.
[2024-01-26 09:10:18] After this operation, 43.0 kB of additional disk space will be used.
[2024-01-26 09:10:18] Err:1 http://raspbian.raspberrypi.org/raspbian buster/main armhf libwebpmux3 armhf 0.6.1-2+deb10u2
[2024-01-26 09:10:18] 404  Not Found [IP: 93.93.128.193 80]
[2024-01-26 09:10:18] Get:2 http://archive.raspberrypi.org/debian buster/main armhf ffmpeg armhf 7:4.1.11-0+deb10u1+rpt1 [1,441 kB]
[2024-01-26 09:10:18] Get:3 http://archive.raspberrypi.org/debian buster/main armhf libavdevice58 armhf 7:4.1.11-0+deb10u1+rpt1 [161 kB]
[2024-01-26 09:10:18] Get:4 http://archive.raspberrypi.org/debian buster/main armhf libavfilter7 armhf 7:4.1.11-0+deb10u1+rpt1 [1,455 kB]
[2024-01-26 09:10:19] Get:5 http://archive.raspberrypi.org/debian buster/main armhf libswscale5 armhf 7:4.1.11-0+deb10u1+rpt1 [263 kB]
[2024-01-26 09:10:19] Get:6 http://archive.raspberrypi.org/debian buster/main armhf libavformat58 armhf 7:4.1.11-0+deb10u1+rpt1 [1,530 kB]
[2024-01-26 09:10:19] Get:7 http://archive.raspberrypi.org/debian buster/main armhf libavcodec58 armhf 7:4.1.11-0+deb10u1+rpt1 [8,951 kB]
[2024-01-26 09:10:22] Get:8 http://archive.raspberrypi.org/debian buster/main armhf libswresample3 armhf 7:4.1.11-0+deb10u1+rpt1 [127 kB]
[2024-01-26 09:10:22] Get:9 http://archive.raspberrypi.org/debian buster/main armhf libpostproc55 armhf 7:4.1.11-0+deb10u1+rpt1 [104 kB]
[2024-01-26 09:10:22] Get:10 http://archive.raspberrypi.org/debian buster/main armhf libavresample4 armhf 7:4.1.11-0+deb10u1+rpt1 [113 kB]
[2024-01-26 09:10:22] Get:11 http://archive.raspberrypi.org/debian buster/main armhf libavutil56 armhf 7:4.1.11-0+deb10u1+rpt1 [365 kB]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/libw/libwebp/libwebpmux3_0.6.1-2+deb10u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
[2024-01-26 09:10:22] Fetched 14.5 MB in 4s (3,332 kB/s)
[2024-01-26 09:10:22] *************************************
[2024-01-26 09:10:22] Creating python 3 virtual environment
[2024-01-26 09:10:23] The virtual environment was not created successfully because ensurepip is not
[2024-01-26 09:10:23] available.  On Debian/Ubuntu systems, you need to install the python3-venv
[2024-01-26 09:10:23] package using the following command.
[2024-01-26 09:10:23] apt-get install python3-venv
[2024-01-26 09:10:23] You may need to use sudo with that command.  After installing the python3-venv
[2024-01-26 09:10:23] package, recreate your virtual environment.
[2024-01-26 09:10:23] Failing command: ['/var/www/html/plugins/arlo/resources/venv/bin/python3', '-Im', 'ensurepip', '--upgrade', '--default-pip']
[2024-01-26 09:10:23] Done
[2024-01-26 09:10:23] *************************************
[2024-01-26 09:10:23] Install the required python libraries
/var/www/html/plugins/arlo/resources/venv/bin/python3: No module named pip
[2024-01-26 09:10:23] Check version
[2024-01-26 09:10:23] Python 3.7.3
[2024-01-26 09:10:23] ffmpeg version 4.1.8-0+deb10u1+rpt1 Copyright (c) 2000-2021 the FFmpeg developers
[2024-01-26 09:10:23] built with gcc 8 (Raspbian 8.3.0-6+rpi1)
[2024-01-26 09:10:23] configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --libdir=/usr/lib/arm-linux-gnueabihf --cpu=arm1176jzf-s --arch=arm
[2024-01-26 09:10:23] libavutil      56. 22.100 / 56. 22.100
[2024-01-26 09:10:23] libavcodec     58. 35.100 / 58. 35.100
[2024-01-26 09:10:23] libavformat    58. 20.100 / 58. 20.100
[2024-01-26 09:10:23] libavdevice    58.  5.100 / 58.  5.100
[2024-01-26 09:10:23] libavfilter     7. 40.101 /  7. 40.101
[2024-01-26 09:10:23] libavresample   4.  0.  0 /  4.  0.  0
[2024-01-26 09:10:23] libswscale      5.  3.100 /  5.  3.100
[2024-01-26 09:10:23] libswresample   3.  3.100 /  3.  3.100
[2024-01-26 09:10:23] libpostproc    55.  3.100 / 55.  3.100
[2024-01-26 09:10:23] *      Install ended      *
Cette erreur est là car votre système est trop ancien et pas mis à jour.
Plusieurs sujets en parlent déjà dont celui-ci par exemple, avec la commande à taper pour le résoudre:
Merci beaucoup. ça fonctionne parfaitement. Quelques soucis avec des caractères spéciaux dans les mots de passe Arlo et mail qui semble ne pas fonctionner avec le plugin. Mais à présent tout est en ordre.
Est-ce que vous avez une nouvelle installation de caméra ou vous les avez depuis longtemps?
Je vous invite à lire ceci:
