Et bien moi depuis la dernière mise à jour (il y a moins d’une heure), le deamon ne veut plus démarrer.
Log Gshd
> gsh-jeedom-local-discover@0.0.1 start /var/www/html/plugins/gsh/resources/gshd
> ts-node server.ts "--udp_discovery_port" "3311" "--udp_discovery_packet" "4A6565646F6D" "--pid" "/tmp/jeedom/gsh/deamon.pid" "--loglevel" "error"
Error: bind EADDRINUSE 0.0.0.0:3311
at dgram.js:338:20
at processTicksAndRejections (internal/process/task_queues.js:85:21)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! gsh-jeedom-local-discover@0.0.1 start: `ts-node server.ts "--udp_discovery_port" "3311" "--udp_discovery_packet" "4A6565646F6D" "--pid" "/tmp/jeedom/gsh/deamon.pid" "--loglevel" "error"`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the gsh-jeedom-local-discover@0.0.1 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2020-05-05T18_01_59_743Z-debug.log
Log installation des dépendances :
* Installation des dépendances *
Get:1 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Hit:2 http://deb.debian.org/debian buster InRelease
Get:3 http://deb.debian.org/debian buster-updates InRelease [49.3 kB]
Get:4 http://security.debian.org/debian-security buster/updates/main Sources [116 kB]
Get:5 http://security.debian.org/debian-security buster/updates/main amd64 Packages [194 kB]
Get:6 http://security.debian.org/debian-security buster/updates/main Translation-en [104 kB]
Hit:7 https://deb.nodesource.com/node_13.x buster InRelease
Fetched 528 kB in 6s (91.8 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
npm : Depends: nodejs (>= 6.11~) but it is not going to be installed
Depends: node-abbrev (>= 1.1.1~) but it is not going to be installed
Depends: node-ansi-regex (>= 3.0~) but it is not going to be installed
Depends: node-ansistyles (>= 0.1.3~) but it is not going to be installed
Depends: node-aproba (>= 1.2~) but it is not going to be installed
Depends: node-archy (>= 1.0~) but it is not going to be installed
Depends: node-cacache (>= 10.0.4~) but it is not going to be installed
Depends: node-bluebird (>= 3.5.1~) but it is not going to be installed
Depends: node-call-limit (>= 1.1~) but it is not going to be installed
Depends: node-chownr (>= 1.0.1~) but it is not going to be installed
Depends: node-config-chain (>= 1.1.11~) but it is not going to be installed
Depends: node-detect-indent (>= 5.0~) but it is not going to be installed
Depends: node-detect-newline (>= 2.1~) but it is not going to be installed
Depends: node-editor (>= 1.0~) but it is not going to be installed
Depends: node-fs-vacuum (>= 1.2.10~) but it is not going to be installed
Depends: node-fs-write-stream-atomic (>= 1.0.10~) but it is not going to be installed
Depends: node-glob (>= 7.1.2~) but it is not going to be installed
Depends: node-graceful-fs (>= 4.1.11~) but it is not going to be installed
Depends: node-has-unicode (>= 2.0.1~) but it is not going to be installed
Depends: node-hosted-git-info (>= 2.6~) but it is not going to be installed
Depends: node-iferr (>= 0.1.5~) but it is not going to be installed
Depends: node-inflight (>= 1.0.6~) but it is not going to be installed
Depends: node-inherits (>= 2.0.3~) but it is not going to be installed
Depends: node-ini (>= 1.3.5~) but it is not going to be installed
Depends: node-npm-package-arg but it is not going to be installed
Depends: node-promzard but it is not going to be installed
Depends: node-jsonstream (>= 1.3.2~) but it is not going to be installed
Depends: node-json-parse-better-errors (>= 1.0.1~) but it is not going to be installed
Depends: node-lazy-property (>= 1.0~) but it is not going to be installed
Depends: node-libnpx (>= 10.0.1~) but it is not going to be installed
Depends: node-lockfile (>= 1.0.3~) but it is not going to be installed
Depends: node-lru-cache (>= 4.1.1~) but it is not going to be installed
Depends: node-mississippi (>= 3.0~) but it is not going to be installed
Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed
Depends: node-move-concurrently (>= 1.0.1~) but it is not going to be installed
Depends: node-nopt but it is not going to be installed
Depends: node-normalize-package-data (>= 2.4~) but it is not going to be installed
Depends: node-gyp (>= 3.6.2~) but it is not going to be installed
Depends: node-resolve-from (>= 4.0~) but it is not going to be installed
Depends: node-encoding but it is not going to be installed
Depends: node-errno but it is not going to be installed
Depends: node-npmlog (>= 4.1.2~) but it is not going to be installed
Depends: node-once (>= 1.4~) but it is not going to be installed
Depends: node-opener (>= 1.4.3~) but it is not going to be installed
Depends: node-osenv (>= 0.1.5~) but it is not going to be installed
Depends: node-path-is-inside (>= 1.0.2~) but it is not going to be installed
Depends: node-promise-inflight (>= 1.0.1~) but it is not going to be installed
Depends: node-ansi but it is not going to be installed
Depends: node-qw (>= 1.0.1~) but it is not going to be installed
Depends: node-read (>= 1.0.7~) but it is not going to be installed
Depends: node-read-package-json (>= 2.0.13~) but it is not going to be installed
Depends: node-request (>= 2.83~) but it is not going to be installed
Depends: node-retry (>= 0.10.1~) but it is not going to be installed
Depends: node-rimraf (>= 2.6.2~) but it is not going to be installed
Depends: node-safe-buffer (>= 5.1.1~) but it is not going to be installed
Depends: node-semver (>= 5.5~) but it is not going to be installed
Depends: node-sha (>= 2.0.1~) but it is not going to be installed
Depends: node-slide (>= 1.1.6~) but it is not going to be installed
Depends: node-sorted-object (>= 2.0.1~) but it is not going to be installed
Depends: node-from2 but it is not going to be installed
Depends: node-stream-iterate but it is not going to be installed
Depends: node-ssri (>= 5.2.4~) but it is not going to be installed
Depends: node-strip-ansi (>= 4.0~) but it is not going to be installed
Depends: node-tar (>= 4.4~) but it is not going to be installed
Depends: node-text-table (>= 0.2~) but it is not going to be installed
Depends: node-uid-number (>= 0.0.6~) but it is not going to be installed
Depends: node-unique-filename (>= 1.1~) but it is not going to be installed
Depends: node-unpipe (>= 1.0~) but it is not going to be installed
Depends: node-boxen (>= 1.2.1~) but it is not going to be installed
Depends: node-import-lazy but it is not going to be installed
Depends: node-is-npm (>= 1.0~) but it is not going to be installed
Depends: node-latest-version (>= 3.0~) but it is not going to be installed
Depends: node-semver-diff (>= 2.0~) but it is not going to be installed
Depends: node-xdg-basedir (>= 3.0~) but it is not going to be installed
Depends: node-validate-npm-package-name (>= 3.0~) but it is not going to be installed
Depends: node-which (>= 1.3~) but it is not going to be installed
Depends: node-wrappy (>= 1.0.2~) but it is not going to be installed
Depends: node-write-file-atomic (>= 2.3~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
npm WARN eslint-config-standard@12.0.0 requires a peer of eslint@>=5.0.0 but none is installed. You must install peer dependencies yourself.
npm WARN eslint-config-standard-jsx@6.0.2 requires a peer of eslint@>=5.0.0 but none is installed. You must install peer dependencies yourself.
npm WARN eslint-plugin-es@1.4.0 requires a peer of eslint@>=4.19.1 but none is installed. You must install peer dependencies yourself.
npm WARN eslint-plugin-import@2.14.0 requires a peer of eslint@2.x - 5.x but none is installed. You must install peer dependencies yourself.
npm WARN eslint-plugin-node@7.0.1 requires a peer of eslint@>=4.19.1 but none is installed. You must install peer dependencies yourself.
npm WARN eslint-plugin-react@7.11.1 requires a peer of eslint@^3.0.0 || ^4.0.0 || ^5.0.0 but none is installed. You must install peer dependencies yourself.
npm WARN eslint-plugin-standard@4.0.0 requires a peer of eslint@>=5.0.0 but none is installed. You must install peer dependencies yourself.
audited 499 packages in 5.973s
found 13 vulnerabilities (5 low, 1 moderate, 4 high, 3 critical)
run `npm audit fix` to fix them, or `npm audit` for details
* Installation terminée *
résultat commande « npm audit fix » en SSH
jeedom@JeedomMaison:~$ sudo npm audit fix
[sudo] Mot de passe de jeedom :
npm ERR! code EAUDITNOPJSON
npm ERR! audit No package.json found: Cannot audit a project without a package.json
npm ERR! /root/.npm/_logs/2020-05-05T18_07_02_997Z-debug.log
