J’ai un problème de dépendance qui ce lance en boucle sur BLEA depuis ma mise à jour de 3.3.59 vers 4.2.7.
En regardant différent poste, j’ai fait plusieurs manip mais rien n’y fait, même après redémarrage.
Voici les log de l’installation des dépendances
* Installation des dépendances *
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Get:2 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Hit:4 http://www.deb-multimedia.org buster InRelease
Hit:5 http://ftp.uk.debian.org/debian buster-updates InRelease
Hit:6 https://oph.mdrjr.net/meveric all InRelease
Hit:7 https://oph.mdrjr.net/meveric buster InRelease
Err:3 https://repo.jeedom.com/odroid stable InRelease
502 Bad Gateway [IP: 51.210.253.116 443]
Fetched 122 kB in 15s (7,918 B/s)
Reading package lists...
W: Failed to fetch http://repo.jeedom.com/odroid/dists/stable/InRelease 502 Bad Gateway [IP: 51.210.253.116 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
Requirement already up-to-date: setuptools in /usr/local/lib/python3.7/dist-packages (60.6.0)
Requirement already satisfied: pyudev in /usr/local/lib/python3.7/dist-packages (0.23.1)
Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (from pyudev) (1.16.0)
Requirement already satisfied: pyserial in /usr/local/lib/python3.7/dist-packages (3.5)
Requirement already satisfied: requests in /usr/local/lib/python3.7/dist-packages (2.27.1)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests) (2021.10.8)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests) (1.26.8)
Requirement already satisfied: charset-normalizer~=2.0.0; python_version >= "3" in /usr/local/lib/python3.7/dist-packages (from requests) (2.0.10)
Requirement already satisfied: idna<4,>=2.5; python_version >= "3" in /usr/local/lib/python3.7/dist-packages (from requests) (3.3)
Collecting pybluez
Using cached https://files.pythonhosted.org/packages/08/9f/e9d93b266d2d1ea988780a52a696073ba0a65df65a532165fdf6ff90d0ed/PyBluez-0.23.tar.gz
Complete output from command python setup.py egg_info:
error in PyBluez setup command: use_2to3 is invalid.
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-fe1rezbu/pybluez/
Collecting pillow
Using cached https://files.pythonhosted.org/packages/b0/43/3e286c93b9fa20e233d53532cc419b5aad8a468d91065dbef4c846058834/Pillow-9.0.0.tar.gz
Building wheels for collected packages: pillow
Running setup.py bdist_wheel for pillow: started
Running setup.py bdist_wheel for pillow: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-a631l8el/pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-bpgs2t0e --python-tag cp37:
usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: -c --help [cmd1 cmd2 ...]
or: -c --help-commands
or: -c cmd --help
error: invalid command 'bdist_wheel'
Failed building wheel for pillow
Running setup.py clean for pillow
Failed to build pillow
Installing collected packages: pillow
Running setup.py install for pillow: started
Running setup.py install for pillow: still running...
Running setup.py install for pillow: finished with status 'done'
Successfully installed pillow
Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.21.5)
Collecting bluepy
Using cached https://files.pythonhosted.org/packages/27/91/6cfca10bee9862f93015413cf9e6a52c3081a71f1518963396a055128f8e/bluepy-1.3.0.tar.gz
Building wheels for collected packages: bluepy
Running setup.py bdist_wheel for bluepy: started
Running setup.py bdist_wheel for bluepy: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-uz1bwoth/bluepy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-9d_er6q2 --python-tag cp37:
/usr/local/lib/python3.7/dist-packages/setuptools/dist.py:734: UserWarning: Usage of dash-separated 'description-file' will not be supported in future versions. Please use the underscore name 'description_file' instead
% (opt, underscore_opt)
or: -c cmd --help
Failed building wheel for bluepy
Running setup.py clean for bluepy
Failed to build bluepy
Installing collected packages: bluepy
Running setup.py install for bluepy: started
Running setup.py install for bluepy: finished with status 'done'
Successfully installed bluepy
Cloning into 'bluepy'...
running build
running build_py
running install
Working dir is /tmp/bluepy
execute make -C ./bluepy clean
execute make -C bluepy -j1
running build
running build_py
running install_lib
copying build/lib/bluepy/scan_fuzz.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/thingy52.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/get_services.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/btle.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/sensortag.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluepy-helper -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/__init__.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/uuids.json -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/blescan.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluepy-helper.c -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/Makefile -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluez-src.tgz -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/scanner.py -> /usr/lib/python3.7/site-packages/bluepy
running install_egg_info
running egg_info
writing bluepy.egg-info/PKG-INFO
writing dependency_links to bluepy.egg-info/dependency_links.txt
writing entry points to bluepy.egg-info/entry_points.txt
writing top-level names to bluepy.egg-info/top_level.txt
reading manifest file 'bluepy.egg-info/SOURCES.txt'
adding license file 'LICENSE.txt'
running install_scripts
Installing blescan script to /usr/bin
Installing sensortag script to /usr/bin
Installing thingy52 script to /usr/bin
/usr/local/lib/python3.7/dist-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
setuptools.SetuptoolsDeprecationWarning,
Collecting cryptography
Using cached https://files.pythonhosted.org/packages/f9/4b/1cf8e281f7ae4046a59e5e39dd7471d46db9f61bb564fddbff9084c4334f/cryptography-36.0.1.tar.gz
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Collecting cffi>=1.12 (from cryptography)
Using cached https://files.pythonhosted.org/packages/00/9e/92de7e1217ccc3d5f352ba21e52398372525765b2e0c4530e6eb2ba9282a/cffi-1.15.0.tar.gz
Requirement already satisfied: pycparser in /usr/local/lib/python3.7/dist-packages (from cffi>=1.12->cryptography) (2.21)
Building wheels for collected packages: cryptography, cffi
Running setup.py bdist_wheel for cryptography: started
Running setup.py bdist_wheel for cryptography: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-pfo7ny3c/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-6lkwohuc --python-tag cp37:
running bdist_wheel
running build
running build_py
running egg_info
writing src/cryptography.egg-info/PKG-INFO
writing dependency_links to src/cryptography.egg-info/dependency_links.txt
writing requirements to src/cryptography.egg-info/requires.txt
writing top-level names to src/cryptography.egg-info/top_level.txt
reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
no previously-included directories found matching 'docs/_build'
warning: no previously-included files found matching 'vectors'
warning: no previously-included files matching '*' found under directory 'vectors'
warning: no previously-included files matching '*' found under directory '.github'
warning: no previously-included files found matching 'release.py'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching 'codecov.yml'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'dev-requirements.txt'
warning: no previously-included files found matching 'tox.ini'
warning: no previously-included files found matching 'mypy.ini'
warning: no previously-included files matching '*' found under directory '.zuul.d'
warning: no previously-included files matching '*' found under directory '.zuul.playbooks'
adding license file 'LICENSE'
adding license file 'LICENSE.APACHE'
adding license file 'LICENSE.BSD'
adding license file 'LICENSE.PSF'
running build_ext
running build_rust
=============================DEBUG ASSISTANCE=============================
If you are seeing a compilation error please try the following steps to
successfully install cryptography:
1) Upgrade to the latest pip and try again. This will fix errors for most
users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
2) Read https://cryptography.io/en/latest/installation/ for specific
instructions for your platform.
3) Check our frequently asked questions for more information:
https://cryptography.io/en/latest/faq/
4) Ensure you have a recent Rust toolchain installed:
https://cryptography.io/en/latest/installation/#rust
Python: 3.7.3
platform: Linux-3.16.85+-aarch64-with-debian-10.4
pip: 18.1
setuptools: 60.6.0
setuptools_rust: 1.1.2
error: can't find Rust compiler
If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
To update pip, run:
pip install --upgrade pip
and then retry package installation.
If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
This package requires Rust >=1.41.0.
Failed building wheel for cryptography
Running setup.py clean for cryptography
');f.close();exec(compile(code, __file__, 'exec'))" clean --all:
running clean
'build/bdist.linux-aarch64' does not exist -- can't clean it
'build/scripts-3.7' does not exist -- can't clean it
removing 'build'
running clean_rust
Python: 3.7.3
pip: 18.1
setuptools: 60.6.0
To update pip, run:
Failed cleaning build dir for cryptography
Running setup.py bdist_wheel for cffi: started
Running setup.py bdist_wheel for cffi: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-pfo7ny3c/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-42ze8frj --python-tag cp37:
or: -c cmd --help
Failed building wheel for cffi
Running setup.py clean for cffi
Failed to build cryptography cffi
Installing collected packages: cffi, cryptography
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'done'
Running setup.py install for cryptography: started
Running setup.py install for cryptography: finished with status 'error'
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-x339phh7/install-record.txt --single-version-externally-managed --compile:
running install
/tmp/pip-build-env-g_oktsn6/lib/python3.7/site-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
running build
running build_py
running egg_info
running build_ext
running build_rust
Python: 3.7.3
pip: 18.1
setuptools: 60.6.0
To update pip, run:
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-pfo7ny3c/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-x339phh7/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-pfo7ny3c/cryptography/
Collecting pycrypto
Using cached https://files.pythonhosted.org/packages/60/db/645aa9af249f059cc3a368b118de33889219e0362141e75d4eaf6f80f163/pycrypto-2.6.1.tar.gz
Building wheels for collected packages: pycrypto
Running setup.py bdist_wheel for pycrypto: started
Running setup.py bdist_wheel for pycrypto: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-68axdon0/pycrypto/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-c4jprinm --python-tag cp37:
or: -c cmd --help
Failed building wheel for pycrypto
Running setup.py clean for pycrypto
Failed to build pycrypto
Installing collected packages: pycrypto
Running setup.py install for pycrypto: started
Running setup.py install for pycrypto: finished with status 'done'
Successfully installed pycrypto
* Installation terminée *
Auriez-vous une solution afin de régler ce problème? Car les solutions que j’ai vu jusqu’à maintenant ne semble pas fonctionner.
