Suite à mise à jour d’une version 3.x à la version. J’ai un soucis avec tous mes modules zwave qui ne fonctionne plus.
A priori une histoire de démon zwave qui ne démarre plus:
L’installation des dépendances se bloque à 15% en ensuite j’obtiens NOK
+ touch /tmp/jeedom_install_in_progress_openzwave
+ echo 1
+ echo 2
+ sudo apt update
Ign:1 http://security.debian.org stretch/updates InRelease
Ign:2 http://ftp.debian.org/debian stretch InRelease
Ign:4 http://ftp.debian.org/debian stretch-updates InRelease
Ign:5 http://ftp.debian.org/debian stretch-backports InRelease
Err:6 http://security.debian.org stretch/updates Release
404 Not Found [IP: 199.232.170.132 80]
Ign:7 http://ftp.debian.org/debian stretch-proposed-updates InRelease
Err:8 http://ftp.debian.org/debian stretch Release
Err:9 http://ftp.debian.org/debian stretch-updates Release
Err:10 http://ftp.debian.org/debian stretch-backports Release
Err:11 http://ftp.debian.org/debian stretch-proposed-updates Release
Get:3 https://repo.jeedom.com/odroid stable InRelease [1,640 B]
Err:3 https://repo.jeedom.com/odroid stable InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F9EB92D05446446C
Hit:12 https://oph.mdrjr.net/meveric all InRelease
Hit:13 https://oph.mdrjr.net/meveric stretch InRelease
Ign:14 http://www.deb-multimedia.org stretch InRelease
Err:15 http://www.deb-multimedia.org stretch Release
404 Not Found [IP: 91.121.146.196 80]
Reading package lists...
E: The repository 'http://security.debian.org stretch/updates Release' does no longer have a Release file.
E: The repository 'http://ftp.debian.org/debian stretch Release' does no longer have a Release file.
E: The repository 'http://ftp.debian.org/debian stretch-updates Release' does no longer have a Release file.
E: The repository 'http://ftp.debian.org/debian stretch-backports Release' does no longer have a Release file.
E: The repository 'http://ftp.debian.org/debian stretch-proposed-updates Release' does no longer have a Release file.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repo.jeedom.com/odroid stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F9EB92D05446446C
E: The repository 'http://www.deb-multimedia.org stretch Release' does no longer have a Release file.
+ echo 3
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pyudev
Building dependency tree...
Reading state information...
The following packages were automatically installed and are no longer required:
libmemcached11 libmemcachedutil2 libmysqlclient18 libonig2 libpng12-0
libqdbm14 libvpx1 linux-image-3.14.29+ linux-image-arm64-odroid-c2
u-boot-tools
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
python3-six
python3-pyudev python3-six
0 upgraded, 2 newly installed, 0 to remove and 190 not upgraded.
Need to get 14.4 kB/54.6 kB of archives.
After this operation, 279 kB of additional disk space will be used.
Err:1 http://ftp.debian.org/debian stretch/main arm64 python3-six all 1.10.0-3
E: Failed to fetch http://ftp.debian.org/debian/pool/main/s/six/python3-six_1.10.0-3_all.deb 404 Not Found [IP: 199.232.170.132 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
+ echo 4
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-requests
u-boot-tools
python3-chardet python3-pkg-resources python3-six python3-urllib3
Suggested packages:
python3-setuptools python3-cryptography python3-idna python3-openssl
python3-socks
python3-chardet python3-pkg-resources python3-requests python3-six
python3-urllib3
0 upgraded, 5 newly installed, 0 to remove and 190 not upgraded.
Need to get 426 kB of archives.
After this operation, 1,917 kB of additional disk space will be used.
Err:1 http://ftp.debian.org/debian stretch/main arm64 python3-pkg-resources all 33.1.1-1
Err:2 http://ftp.debian.org/debian stretch/main arm64 python3-chardet all 2.3.0-2
Err:3 http://ftp.debian.org/debian stretch/main arm64 python3-six all 1.10.0-3
Err:4 http://ftp.debian.org/debian stretch/main arm64 python3-urllib3 all 1.19.1-1
Err:5 http://ftp.debian.org/debian stretch/main arm64 python3-requests all 2.12.4-1
E: Failed to fetch http://ftp.debian.org/debian/pool/main/p/python-setuptools/python3-pkg-resources_33.1.1-1_all.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/c/chardet/python3-chardet_2.3.0-2_all.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/p/python-urllib3/python3-urllib3_1.19.1-1_all.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/r/requests/python3-requests_2.12.4-1_all.deb 404 Not Found [IP: 199.232.170.132 80]
+ echo 5
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-setuptools
u-boot-tools
Suggested packages:
python-setuptools-doc
python3-pkg-resources python3-setuptools
Need to get 352 kB of archives.
After this operation, 1,467 kB of additional disk space will be used.
Err:2 http://ftp.debian.org/debian stretch/main arm64 python3-setuptools all 33.1.1-1
E: Failed to fetch http://ftp.debian.org/debian/pool/main/p/python-setuptools/python3-setuptools_33.1.1-1_all.deb 404 Not Found [IP: 199.232.170.132 80]
+ echo 6
+ sudo pip2 install --force-reinstall --upgrade pyudev
Collecting pyudev
Collecting six (from pyudev)
Using cached https://files.pythonhosted.org/packages/d9/5a/e7c31adbe875f2abbb91bd84cf2dc52d792b5a01506781dbcf25c91daf11/six-1.16.0-py2.py3-none-any.whl
Installing collected packages: six, pyudev
Found existing installation: six 1.16.0
Uninstalling six-1.16.0:
Successfully uninstalled six-1.16.0
Found existing installation: pyudev 0.23.2
Uninstalling pyudev-0.23.2:
Successfully uninstalled pyudev-0.23.2
Successfully installed pyudev-0.23.2 six-1.16.0
+ echo 7
+ sudo pip2 install --force-reinstall --upgrade wheel
Par contre pour ce qui est de la charge c’est la première fois que je regarde ces paramètres et c’est une box jeedom smart, je ne me suis jamais intéressé à la version de l’OS qui était dessus
Met les log entre balise pour plus de lisibilité. C’est bien ce que je craignais. Ton debian est trop vieux, il ne trouve plus les depots pour installer les dépendances.
Tu es sur une smart ?
Je crois que les sources strech sont maintenant sous archive.debian
Ouvre un ticket support jeedom ça sera plus sûr. Mais je pense qu’il va falloir penser a changer de machine dans un futur proche.
[2023-06-15 07:48:31][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
File "/var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/openzwaved.py", line 18, in <module>
from ozwave import globals,server_utils,rest_server
File "/var/www/html/plugins/openzwave/resources/openzwaved/ozwave/globals.py", line 1, in <module>
import utils,network_utils,controller_utils,node_utils
File "/var/www/html/plugins/openzwave/resources/openzwaved/ozwave/utils.py", line 6, in <module>
import network_utils
File "/var/www/html/plugins/openzwave/resources/openzwaved/ozwave/network_utils.py", line 7, in <module>
from openzwave.network import ZWaveNetwork,ZWaveController
ImportError: No module named openzwave.network
[2023-06-15 07:49:03][ERROR] : Impossible de lancer le démon openzwave, relancer le démon en debug et vérifiez la log
[2023-06-15 07:50:02][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2023-06-15 07:50:34][ERROR] : Impossible de lancer le démon openzwave, relancer le démon en debug et vérifiez la log
