ok et du coup les logs vous avez trouvé?
openzwave_package
Building Hail.o
Building SwitchToggleBinary.o
Building TimeParameters.o
Building DeviceResetLocally.o
Building UserCode.o
Building CentralScene.o
Building Color.o
Building ManufacturerSpecific.o
Building ThermostatFanState.o
Building SoundSwitch.o
Building ApplicationStatus.o
Building NodeNaming.o
Building DoorLockLogging.o
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp: In member function ‘virtual bool OpenZWave::DoorLockLogging::HandleMsg(const uint8*, uint32, uint32)’:
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp:312:15: warning: passing argument 1 to restrict-qualified parameter aliases with argument 4 [-Wrestrict]
snprintf(usercode, sizeof(usercode), "%s %d", usercode, (int)_data[12+i]);
Building ClimateControlSchedule.o
Building Protection.o
Building ManufacturerProprietary.o
Building WakeUp.o
Building ThermostatSetpoint.o
Building Association.o
Building MultiChannelAssociation.o
Building Clock.o
Building SceneActivation.o
Building Powerlevel.o
Building AssociationCommandConfiguration.o
Building SensorMultilevel.o
Building ThermostatOperatingState.o
Building SensorAlarm.o
Building CRC16Encap.o
Building Battery.o
Building Version.o
Building Alarm.o
Building CommandClasses.o
Building NoOperation.o
Building BasicWindowCovering.o
Building EnergyProduction.o
Building Basic.o
Building CommandClass.o
Building SwitchToggleMultilevel.o
Building Value.o
Building ValueList.o
Building ValueButton.o
Building ValueInt.o
Building ValueStore.o
Building ValueDecimal.o
Building ValueRaw.o
Building ValueString.o
Building ValueByte.o
Building ValueBool.o
Building ValueSchedule.o
Building ValueShort.o
Building Controller.o
Building Wait.o
Building Thread.o
Building Stream.o
Building Log.o
Building HidController.o
Building Mutex.o
Building SerialController.o
Building Event.o
Building FileOps.o
Building TimeStamp.o
Building FileOpsImpl.o
Building TimeStampImpl.o
Building WaitImpl.o
Building ThreadImpl.o
Building LogImpl.o
Building MutexImpl.o
make[2]: *** [/opt/python-openzwave/openzwave/cpp/build/support.mk:136: /opt/python-openzwave/openzwave/.lib/MutexImpl.o] Terminated
make: *** [Makefile:273: openzwave/.lib/] Terminated
make[1]: *** [Makefile:20: all] Terminated
A priori l’installation est pas finie
L’installation de quoi ?
Des dépendances (où alors le log est pas complet).
le log est complet j’ai fait téléchargé et ensuite copier/coller, comment relancer l’install de ces dépendances ?
En cliquant sur relancer
C’est un process qui est long habituellement, la il est bloqué sur 11% depuis plusieurs minutes. Ca me semble louche
Bon en regardant le log il fait des trucs
Oui ça mets beaucoup de temps
Ca vient de se finir, en relancant ensuite le démon ca a l’air de marcher
Merci pour tout
C’est quoi une nouvelle version révolutionnaire ?
exactement.
