Bonjour matinal
J’étais en version 2.4.0 et ce matin je suis passé en 2.5.0
J’avais juste l’état d’une prise qui ne fonctionnait pas alors avant de faire n’importe quoi, j’ai juste redémarré mon atlas et depuis plus rien ne fonctionne. J’ai remis un backup, idem
Le démon reste pourtant vert…C’est un peu la panique. Merci pour votre aide
[2025-07-02 07:28:45] e[31merrore[39m: z2m: Publish 'set' 'state' to 'Grille Pain' failed: 'Error: ZCL command 0xa4c1389bca366d26/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (failed to send ZCL request (3) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7))'
[2025-07-02 07:29:51] e[31merrore[39m: zh:controller:device: Read response to 0xa4c1380329b8c546 failed (ZCL command 0xa4c1380329b8c546/1 genTime.readRsp({"localTime":804756592}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":186,"writeUndiv":false}) failed (failed to send ZCL request (186) Error: Command ApsDataRequest failed with status: Busy))
[2025-07-02 07:29:52] e[31merrore[39m: zh:controller:device: Read response to 0xa4c1380329b8c546 failed (ZCL command 0xa4c1380329b8c546/1 genTime.readRsp({"localTime":804756592}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":186,"writeUndiv":false}) failed (failed to send ZCL request (186) Error: Command ApsDataRequest failed with status: Busy))
[2025-07-02 07:29:52] e[31merrore[39m: zh:controller:device: Read response to 0xa4c1380329b8c546 failed (ZCL command 0xa4c1380329b8c546/1 genTime.readRsp({"localTime":804756593}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":186,"writeUndiv":false}) failed (failed to send ZCL request (186) Error: Command ApsDataRequest failed with status: Busy))
[2025-07-02 07:29:53] e[31merrore[39m: zh:controller:device: Read response to 0xa4c1380329b8c546 failed (ZCL command 0xa4c1380329b8c546/1 genTime.readRsp({"localTime":804756593}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":186,"writeUndiv":false}) failed (failed to send ZCL request (186) Error: Command ApsDataRequest failed with status: Busy))
[2025-07-02 07:29:59] e[31merrore[39m: zh:controller:device: Read response to 0xa4c1380329b8c546 failed (ZCL command 0xa4c1380329b8c546/1 genTime.readRsp({"localTime":804756591}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":186,"writeUndiv":false}) failed (failed to send ZCL request (186) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:30:00] e[31merrore[39m: zh:controller:device: Read response to 0xa4c1380329b8c546 failed (ZCL command 0xa4c1380329b8c546/1 genTime.readRsp({"localTime":804756590}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":186,"writeUndiv":false}) failed (failed to send ZCL request (186) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:30:03] e[31merrore[39m: zh:controller:device: Read response to 0xa4c1380329b8c546 failed (ZCL command 0xa4c1380329b8c546/1 genTime.readRsp({"localTime":804756591}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":186,"writeUndiv":false}) failed (failed to send ZCL request (186) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:30:04] e[31merrore[39m: zh:controller:device: Read response to 0xa4c1380329b8c546 failed (ZCL command 0xa4c1380329b8c546/1 genTime.readRsp({"localTime":804756591}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":186,"writeUndiv":false}) failed (failed to send ZCL request (186) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:30:09] e[31merrore[39m: zh:controller:device: Read response to 0xa4c1380329b8c546 failed (ZCL command 0xa4c1380329b8c546/1 genTime.readRsp({"localTime":804756592}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":186,"writeUndiv":false}) failed (failed to send ZCL request (186) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:32:19] e[31merrore[39m: z2m: Failed to read state of 'Robot' after reconnect (ZCL command 0xa4c1389caeece495/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (failed to send ZCL request (41) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:32:54] e[31merrore[39m: z2m: Failed to read state of 'Home Cinéma' after reconnect (ZCL command 0x7cb03eaa0a08b0a6/3 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (failed to send ZCL request (51) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:32:57] e[31merrore[39m: z2m: EventBus error 'OTAUpdate/deviceMessage': CommandResponse 0x7cb03eaa0a08b0a6/3 genOta.queryNextImageResponse({"status":152}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"reservedBits":0,"writeUndiv":false}) failed (failed to send ZCL request (53) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7))
[2025-07-02 07:36:55] e[31merrore[39m: z2m: Publish 'set' 'state' to 'Grille Pain' failed: 'Error: ZCL command 0xa4c1389bca366d26/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (failed to send ZCL request (91) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7))'
[2025-07-02 07:37:49] e[31merrore[39m: zh:controller:device: Read response to 0xa4c138ad934cb4eb failed (ZCL command 0xa4c138ad934cb4eb/1 genTime.readRsp({"localTime":804757070}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":67,"writeUndiv":false}) failed (failed to send ZCL request (67) Error: Command ApsDataRequest failed with status: Busy))
[2025-07-02 07:37:50] e[31merrore[39m: zh:controller:device: Read response to 0xa4c138ad934cb4eb failed (ZCL command 0xa4c138ad934cb4eb/1 genTime.readRsp({"localTime":804757070}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":67,"writeUndiv":false}) failed (failed to send ZCL request (67) Error: Command ApsDataRequest failed with status: Busy))
[2025-07-02 07:37:50] e[31merrore[39m: zh:controller:device: Read response to 0xa4c138ad934cb4eb failed (ZCL command 0xa4c138ad934cb4eb/1 genTime.readRsp({"localTime":804757071}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":67,"writeUndiv":false}) failed (failed to send ZCL request (67) Error: Command ApsDataRequest failed with status: Busy))
[2025-07-02 07:37:51] e[31merrore[39m: zh:controller:device: Read response to 0xa4c138ad934cb4eb failed (ZCL command 0xa4c138ad934cb4eb/1 genTime.readRsp({"localTime":804757071}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":67,"writeUndiv":false}) failed (failed to send ZCL request (67) Error: Command ApsDataRequest failed with status: Busy))
[2025-07-02 07:37:59] e[31merrore[39m: zh:controller:device: Read response to 0xa4c138ad934cb4eb failed (ZCL command 0xa4c138ad934cb4eb/1 genTime.readRsp({"localTime":804757069}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":67,"writeUndiv":false}) failed (failed to send ZCL request (67) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:38:03] e[31merrore[39m: zh:controller:device: Read response to 0xa4c138ad934cb4eb failed (ZCL command 0xa4c138ad934cb4eb/1 genTime.readRsp({"localTime":804757069}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":67,"writeUndiv":false}) failed (failed to send ZCL request (67) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:38:10] e[31merrore[39m: zh:controller:device: Read response to 0xa4c138ad934cb4eb failed (ZCL command 0xa4c138ad934cb4eb/1 genTime.readRsp({"localTime":804757069}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":67,"writeUndiv":false}) failed (failed to send ZCL request (67) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:38:10] e[31merrore[39m: zh:controller:device: Read response to 0xa4c138ad934cb4eb failed (ZCL command 0xa4c138ad934cb4eb/1 genTime.readRsp({"localTime":804757070}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":67,"writeUndiv":false}) failed (failed to send ZCL request (67) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:39:08] e[31merrore[39m: zh:controller:device: Read response to 0xa4c13872e9cfb872 failed (ZCL command 0xa4c13872e9cfb872/1 genTime.readRsp({"localTime":804757149}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":14,"writeUndiv":false}) failed (failed to send ZCL request (14) Error: Command ApsDataRequest failed with status: Busy))
[2025-07-02 07:39:19] e[31merrore[39m: zh:controller:device: Read response to 0xa4c13872e9cfb872 failed (ZCL command 0xa4c13872e9cfb872/1 genTime.readRsp({"localTime":804757147}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":14,"writeUndiv":false}) failed (failed to send ZCL request (14) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:39:19] e[31merrore[39m: zh:controller:device: Read response to 0xa4c13872e9cfb872 failed (ZCL command 0xa4c13872e9cfb872/1 genTime.readRsp({"localTime":804757146}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":14,"writeUndiv":false}) failed (failed to send ZCL request (14) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:39:20] e[31merrore[39m: zh:controller:device: Read response to 0xa4c13872e9cfb872 failed (ZCL command 0xa4c13872e9cfb872/1 genTime.readRsp({"localTime":804757147}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":14,"writeUndiv":false}) failed (failed to send ZCL request (14) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:39:32] e[31merrore[39m: zh:controller:device: Read response to 0xa4c13872e9cfb872 failed (ZCL command 0xa4c13872e9cfb872/1 genTime.readRsp({"localTime":804757148}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":14,"writeUndiv":false}) failed (failed to send ZCL request (14) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:39:32] e[31merrore[39m: z2m: Publish 'set' 'state' to 'Grille Pain' failed: 'Error: ZCL command 0xa4c1389bca366d26/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (failed to send ZCL request (123) Error: Command ApsDataRequest failed with status: Busy)'
[2025-07-02 07:39:33] e[31merrore[39m: zh:controller:device: Read response to 0xa4c13872e9cfb872 failed (ZCL command 0xa4c13872e9cfb872/1 genTime.readRsp({"localTime":804757148}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":14,"writeUndiv":false}) failed (failed to send ZCL request (14) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7)))
[2025-07-02 07:39:45] e[31merrore[39m: z2m: Publish 'set' 'state' to 'Prise PDT' failed: 'Error: ZCL command 0xa4c13819794df4ff/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (failed to send ZCL request (124) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7))'
[2025-07-02 07:41:48] e[31merrore[39m: z2m: Publish 'set' 'state' to 'Télé Salon' failed: 'Error: ZCL command 0xa4c1383157cffb46/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (failed to send ZCL request (143) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7))'
