Après quelques mois sans soucis, je rencontre des soucis avec le plugin (ou le klf je ne sais pas).
Le demon reste bloqué en NOK même après avoir réinstallé le plugin (une précédente réinstallation avait fonctionné il y a 3 semaines)
Si quelqu’un a une piste que je peux explorer je suis preneur
Les logs ci-dessous :
File "/var/www/html/plugins/klf200/resources/klf200d.py", line 269, in <module>
LOOP.run_until_complete(init_pyvlx_connection(LOOP))
File "/usr/lib/python3.7/asyncio/base_events.py", line 584, in run_until_complete
return future.result()
File "/var/www/html/plugins/klf200/resources/klf200d.py", line 22, in init_pyvlx_connection
await pyvlx.load_nodes()
File "/var/www/html/plugins/klf200/resources/venv/lib/python3.7/site-packages/pyvlx/pyvlx.py", line 78, in load_nodes
await self.nodes.load(node_id)
File "/var/www/html/plugins/klf200/resources/venv/lib/python3.7/site-packages/pyvlx/nodes.py", line 69, in load
await self._load_all_nodes()
File "/var/www/html/plugins/klf200/resources/venv/lib/python3.7/site-packages/pyvlx/nodes.py", line 85, in _load_all_nodes
await get_all_nodes_information.do_api_call()
File "/var/www/html/plugins/klf200/resources/venv/lib/python3.7/site-packages/pyvlx/api/api_event.py", line 21, in do_api_call
await self.send_frame()
File "/var/www/html/plugins/klf200/resources/venv/lib/python3.7/site-packages/pyvlx/api/api_event.py", line 33, in send_frame
await self.pyvlx.send_frame(self.request_frame())
File "/var/www/html/plugins/klf200/resources/venv/lib/python3.7/site-packages/pyvlx/pyvlx.py", line 66, in send_frame
await self.connect()
File "/var/www/html/plugins/klf200/resources/venv/lib/python3.7/site-packages/pyvlx/pyvlx.py", line 43, in connect
await self.connection.connect()
File "/var/www/html/plugins/klf200/resources/venv/lib/python3.7/site-packages/pyvlx/connection.py", line 90, in connect
ssl=self.create_ssl_context(),
File "/usr/lib/python3.7/asyncio/base_events.py", line 959, in create_connection
raise exceptions[0]
File "/usr/lib/python3.7/asyncio/base_events.py", line 946, in create_connection
await self.sock_connect(sock, address)
File "/usr/lib/python3.7/asyncio/selector_events.py", line 464, in sock_connect
return await fut
File "/usr/lib/python3.7/asyncio/selector_events.py", line 494, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
ConnectionRefusedError: [Errno 111] Connect call failed ('192.168.1.24', 51200)
