Je viens de recevoir un dongle Zigbee SONOFF version E préflashé par Domotique Store (Firmware installé : EZNet 6.10.3 en mode coordinateur).
Le l’ai branché et j’ai configuré le bon port dans le plugin z2m, et j’ai mis le type EZSP.
Le plugin fonctionnait bien avec ma Conbee II, mais quand je veux utiliser ma SONOFF, le plugin reste KO.
Auriez vous une suggestion ?
Le log en mode debug :
> zigbee2mqtt@1.32.2 start
> node index.js
Zigbee2MQTT:debug 2023-08-23 11:08:35: Loaded state from file /var/www/html/plugins/z2m/data/state.json
Zigbee2MQTT:info 2023-08-23 11:08:35: Logging to console and directory: '/var/www/html/plugins/z2m/data/log/2023-08-23.11-08-35' filename: log.txt
Zigbee2MQTT:debug 2023-08-23 11:08:35: Removing old log directory '/var/www/html/plugins/z2m/data/log/2023-08-23.07-20-08'
Zigbee2MQTT:info 2023-08-23 11:08:35: Starting Zigbee2MQTT version 1.32.2 (commit #unknown)
Zigbee2MQTT:info 2023-08-23 11:08:35: Starting zigbee-herdsman (0.17.2)
Zigbee2MQTT:debug 2023-08-23 11:08:35: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/var/www/html/plugins/z2m/data/coordinator_backup.json","databaseBackupPath":"/var/www/html/plugins/z2m/data/database.db.backup","databasePath":"/var/www/html/plugins/z2m/data/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"adapter":"ezsp","path":"/dev/ttyACM2"}}'
Zigbee2MQTT:info 2023-08-23 11:08:38: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2023-08-23 11:08:38: Coordinator firmware version: '{"meta":{"maintrel":"3 ","majorrel":"6","minorrel":"10","product":8,"revision":"6.10.3.0 build 297"},"type":"EZSP v8"}'
Zigbee2MQTT:debug 2023-08-23 11:08:38: Zigbee network parameters: {"channel":11,"extendedPanID":221,"panID":6754}
Zigbee2MQTT:info 2023-08-23 11:08:38: Currently 0 devices are joined:
Zigbee2MQTT:info 2023-08-23 11:08:38: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2023-08-23 11:08:38: Connecting to MQTT server at mqtt://127.0.0.1:1883
Zigbee2MQTT:debug 2023-08-23 11:08:38: Using MQTT login with username: jeedom
Zigbee2MQTT:info 2023-08-23 11:08:38: Connected to MQTT server
Zigbee2MQTT:info 2023-08-23 11:08:38: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2023-08-23 11:08:38: Started frontend on port 0.0.0.0:8080
Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
at Server.setupListenHandle [as _listen2] (node:net:1463:16)
at listenInCluster (node:net:1511:12)
at doListen (node:net:1660:7)
at processTicksAndRejections (node:internal/process/task_queues:84:21)
Après un redémarrage de Jeedom et une nouvelle tentative, toujours KO et le log :
> node index.js
Zigbee2MQTT:debug 2023-08-23 11:16:57: Loaded state from file /var/www/html/plugins/z2m/data/state.json
Zigbee2MQTT:info 2023-08-23 11:16:57: Logging to console and directory: '/var/www/html/plugins/z2m/data/log/2023-08-23.11-16-57' filename: log.txt
Zigbee2MQTT:debug 2023-08-23 11:16:57: Removing old log directory '/var/www/html/plugins/z2m/data/log/2023-08-23.07-39-51'
Zigbee2MQTT:info 2023-08-23 11:16:57: Starting Zigbee2MQTT version 1.32.2 (commit #unknown)
Zigbee2MQTT:info 2023-08-23 11:16:57: Starting zigbee-herdsman (0.17.2)
Zigbee2MQTT:debug 2023-08-23 11:16:57: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/var/www/html/plugins/z2m/data/coordinator_backup.json","databaseBackupPath":"/var/www/html/plugins/z2m/data/database.db.backup","databasePath":"/var/www/html/plugins/z2m/data/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"adapter":"ezsp","path":"/dev/ttyACM2"}}'
Error: Reset error: Error: {"sequence":-1} after 10000ms
at /var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
at Queue.executeNext (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
Ce dongle semble être en expérimental (version E) :
La version P elle semble bien en stable par contre.
Après quand on va sur la fiche du dongle ils donnent quelques notes concernant la clé, peut etre que cela peut aider…
Bon courage en tout cas, pas mal de gens se plaignent de la compatibilité sonoff sur z2m. Pour le coup j’ai également la conbee et pas de soucis aussi.
j’ai tenté de changer type pour mette ZNP/TI, redémarrage et relance des dépendances mais rien n’y fait
> node index.js
Zigbee2MQTT:debug 2023-08-23 11:43:09: Loaded state from file /var/www/html/plugins/z2m/data/state.json
Zigbee2MQTT:info 2023-08-23 11:43:09: Logging to console and directory: '/var/www/html/plugins/z2m/data/log/2023-08-23.11-43-09' filename: log.txt
Zigbee2MQTT:debug 2023-08-23 11:43:09: Removing old log directory '/var/www/html/plugins/z2m/data/log/2023-08-23.11-15-09'
Zigbee2MQTT:info 2023-08-23 11:43:09: Starting Zigbee2MQTT version 1.32.2 (commit #unknown)
Zigbee2MQTT:info 2023-08-23 11:43:09: Starting zigbee-herdsman (0.17.2)
Zigbee2MQTT:debug 2023-08-23 11:43:09: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/var/www/html/plugins/z2m/data/coordinator_backup.json","databaseBackupPath":"/var/www/html/plugins/z2m/data/database.db.backup","databasePath":"/var/www/html/plugins/z2m/data/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"adapter":"ezsp","path":"/dev/ttyACM2"}}'
j’ai pris ce dongle pour la puissance d’émission et il me semble que d’autres ont réussi à le faire tourner sur Jeedom/z2m
Loic
Août 23, 2023, 10:02
5
Ya un soucis entre zigbee2mqtt et les dongle sonoff en cours, le soucis semble etre au niveau du firmware sonoff d’après les 1er retour (une recherche google pourra vous donner les issues pour le suivi). Malheureusement rien a faire pour corriger pour le moment il faut soit attendre un nouveau firmware soit une correction coté zigbee2mqtt.
Surprenant car cette version ( EZNet 6.10.3 coordinator) est censée fonctionner avec Zigbee2MQTT.
C’est bien pour cette raison que je l’ai prise.
Loic
Août 23, 2023, 10:26
7
Je sais pas quoi te dire je ne fais ni les clefs sonoff (qui au passage on vraiment beaucoup de soucis je trouve) ni zigbee2mqtt. Tout ce que je peux te dire c’est une recherche sur google m’a donné des issues sur leur github et que vous n’etes pas les seuls et que c’est pas un soucis du plugin jeedom.
J’ai trouvé la solution pour mon problème
après avoir branché la clé SONOFF version E, j’ai relancé les dépendances puis vérifier les droits
Réglages > Système > Configuration > OS/DB > rétablissement des droits des dossiers et fichiers > Vérifier
Il semble que cela ait corrigé des problèmes car c’est ensuite tombé en marche !
system
A fermé ce sujet ()
Août 26, 2023, 4:39
11
