Voilà 2 jours que j’écume le forum à la recherche d’une solution car mon démon blea c’est brutalement arrêté dans la nuit de lundi à mardi alors qu’il tournait sans problème depuis fort longtemps et je n’arrive pas a le faire repartir.
Je précise que ça ne correspond à aucune MAJ OS, Jeedom ou Blea
Ma configuration:
RPi 4 / 4 Go
Rabian Buster 64bits
Jeedom 4.3.15
Plugin version stable du 2021-04-06 16:26:29
Ma page santé:
La page configuration du plugin
Log en debug:
[2023-02-22 15:30:17.590]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 16): Address type changed during scan, for address 5e:77:2e:7a:da:79
[2023-02-22 15:30:17.719]DEBUG : Send to jeedom : {'devices': {'C4:7C:8D:6A:05:B4': {'present': 1, 'fertility': 0, 'id': 'C4:7C:8D:6A:05:B4', 'type': 'miflora', 'name': 'miflora', 'rssi': -68, 'source': 'local'}}}
[2023-02-22 15:30:17.726]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2023-02-22 15:30:17.746]DEBUG : http://127.0.0.1:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2023-02-22 15:30:17.836]DEBUG : No name in data but i know it is : miflora
[2023-02-22 15:30:17.837]DEBUG : SCANNER------This is a miflora device 80:ea:ca:88:b4:62
[2023-02-22 15:30:17.837]DEBUG : Xiaomi Flower Care PARSE data: 95fe71209800f762b488caea800d0910020700
[2023-02-22 15:30:17.838]DEBUG : XiaomiFlower------ Advertising Data=> Fertility: 7
[2023-02-22 15:30:17.838]DEBUG : {'present': 1, 'fertility': 7, 'id': '80:EA:CA:88:B4:62', 'type': 'miflora', 'name': 'miflora', 'rssi': -67, 'source': 'local'}
[2023-02-22 15:30:17.851]DEBUG : Send to jeedom : {'devices': {'80:EA:CA:88:B4:62': {'present': 1, 'fertility': 7, 'id': '80:EA:CA:88:B4:62', 'type': 'miflora', 'name': 'miflora', 'rssi': -67, 'source': 'local'}}}
[2023-02-22 15:30:17.856]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2023-02-22 15:30:17.871]DEBUG : http://127.0.0.1:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2023-02-22 15:30:18.073]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 17): Address type changed during scan, for address 5e:77:2e:7a:da:79
[2023-02-22 15:30:18.362]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 18): Address type changed during scan, for address 5e:77:2e:7a:da:79
[2023-02-22 15:30:18.632]DEBUG : No name in data but i know it is : miflora
[2023-02-22 15:30:18.633]DEBUG : SCANNER------This is a miflora device c4:7c:8d:6b:01:09
[2023-02-22 15:30:18.634]DEBUG : Xiaomi Flower Care PARSE data: 95fe712098008909016b8d7cc40d091002ef08
[2023-02-22 15:30:18.634]DEBUG : XiaomiFlower------ Advertising Data=> Fertility: 2287
[2023-02-22 15:30:18.634]DEBUG : {'present': 1, 'fertility': 2287, 'id': 'C4:7C:8D:6B:01:09', 'type': 'miflora', 'name': 'miflora', 'rssi': -77, 'source': 'local'}
[2023-02-22 15:30:18.736]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 19): Address type changed during scan, for address 73:b3:1c:f0:55:85
[2023-02-22 15:30:18.876]DEBUG : Send to jeedom : {'devices': {'C4:7C:8D:6B:01:09': {'present': 1, 'fertility': 2287, 'id': 'C4:7C:8D:6B:01:09', 'type': 'miflora', 'name': 'miflora', 'rssi': -77, 'source': 'local'}}}
[2023-02-22 15:30:18.884]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2023-02-22 15:30:18.944]DEBUG : http://127.0.0.1:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2023-02-22 15:30:19.143]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 20): Address type changed during scan, for address 5e:77:2e:7a:da:79
[2023-02-22 15:30:19.523]ERROR : GLOBAL------Exception on scanner (didn't resolve there is an issue with bluetooth) : Address type changed during scan, for address 73:b3:1c:f0:55:85
[2023-02-22 15:30:19.524]INFO : GLOBAL------Shutting down due to errors
[2023-02-22 15:30:19.524]DEBUG : Send to jeedom : {'learn_mode': 0, 'source': 'local'}
[2023-02-22 15:30:19.529]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2023-02-22 15:30:19.546]DEBUG : http://127.0.0.1:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2023-02-22 15:30:21.526]DEBUG : GLOBAL------Shutdown
[2023-02-22 15:30:21.526]DEBUG : GLOBAL------Removing PID file /tmp/jeedom/blea/deamon.pid
[2023-02-22 15:30:21.527]DEBUG : GLOBAL------Closing all potential bluetooth connection
[2023-02-22 15:30:21.862]DEBUG : LoopNetServer Thread stopped
[2023-02-22 15:30:21.863]DEBUG : Exit 0
Je n’ai a ce jour rien fait de plus que redémarrer mon Jeedom, je n’ai qu’une antenne local et pas le plugin Détection de téléphone (Bluetooth) et je n’ai pas non plus relancer l’installation des dépendances comme le préconise assez souvent @Mips
Si vous avez besoin de d’autres informations dites le moi et merci d’avance pour votre aide.
