Hello @benoit5672 et @Mips
Ayant un peu de temps je veux bien essayé de faire la modif et faire le test, de toute façon ça peu pas être plus cassé que ça ne l’est
Je vous tien au courant.
Edit:
Avec la modif de @benoit5672 pas de changement et voici le log:
[2023-02-25 10:00:57][DEBUG] : http://127.0.0.1:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2023-02-25 10:00:57][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 12): Address type changed during scan, for address 73:b3:1c:f0:55:85
[2023-02-25 10:00:57][DEBUG] : No name in data but i know it is : miflora
[2023-02-25 10:00:57][DEBUG] : SCANNER------This is a miflora device c4:7c:8d:6a:10:e3
[2023-02-25 10:00:57][DEBUG] : Xiaomi Flower Care PARSE data: 95fe712098005de3106a8d7cc40d08100100
[2023-02-25 10:00:57][DEBUG] : XiaomiFlower------ Advertising Data=> Moist: 0
[2023-02-25 10:00:57][DEBUG] : {'present': 1, 'moisture': 0, 'id': 'C4:7C:8D:6A:10:E3', 'type': 'miflora', 'name': 'miflora', 'rssi': -78, 'source': 'local'}
[2023-02-25 10:00:57][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 13): Address type changed during scan, for address 73:b3:1c:f0:55:85
[2023-02-25 10:00:57][INFO] : Send to jeedom : {'devices': {'C4:7C:8D:6A:10:E3': {'present': 1, 'moisture': 0, 'id': 'C4:7C:8D:6A:10:E3', 'type': 'miflora', 'name': 'miflora', 'rssi': -78, 'source': 'local'}}}
[2023-02-25 10:00:57][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
Can't init device hci1: Connection timed out (110)
[2023-02-25 10:01:08][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 14): Failed to execute management command 'pasvend'
[2023-02-25 10:01:08][DEBUG] : No name in data but i know it is : miflora
[2023-02-25 10:01:08][DEBUG] : SCANNER------This is a miflora device 80:ea:ca:88:b4:62
[2023-02-25 10:01:08][DEBUG] : Xiaomi Flower Care PARSE data: 95fe712098008062b488caea800d0410021601
[2023-02-25 10:01:08][DEBUG] : XiaomiFlower------ Advertising Data=> Temp27.8
[2023-02-25 10:01:08][DEBUG] : {'present': 1, 'temperature': 27.8, 'id': '80:EA:CA:88:B4:62', 'type': 'miflora', 'name': 'miflora', 'rssi': -60, 'source': 'local'}
[2023-02-25 10:01:08][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 15): Address type changed during scan, for address 73:b3:1c:f0:55:85
[2023-02-25 10:01:08][INFO] : Send to jeedom : {'devices': {'80:EA:CA:88:B4:62': {'present': 1, 'temperature': 27.8, 'id': '80:EA:CA:88:B4:62', 'type': 'miflora', 'name': 'miflora', 'rssi': -60, 'source': 'local'}}}
[2023-02-25 10:01:08][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2023-02-25 10:01:08][DEBUG] : http://127.0.0.1:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2023-02-25 10:01:09][DEBUG] : No name in data but i know it is : xiaomiht
[2023-02-25 10:01:09][DEBUG] : SCANNER------This is a xiaomiht device 4c:65:a8:d8:eb:e1
[2023-02-25 10:01:09][DEBUG] : Xiaomi PARSE data: 95fe5020aa01c6e1ebd8a8654c0d1004f8004f01
[2023-02-25 10:01:09][DEBUG] : XiaomiHT------ Advertising Data=> Temp: 24.8 Moist: 33.5
[2023-02-25 10:01:09][DEBUG] : {'present': 1, 'temperature': 24.8, 'moisture': 33.5, 'id': '4C:65:A8:D8:EB:E1', 'type': 'xiaomiht', 'name': 'xiaomiht', 'rssi': -72, 'source': 'local'}
[2023-02-25 10:01:09][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 16): Address type changed during scan, for address 5e:77:2e:7a:da:79
[2023-02-25 10:01:09][INFO] : Send to jeedom : {'devices': {'4C:65:A8:D8:EB:E1': {'present': 1, 'temperature': 24.8, 'moisture': 33.5, 'id': '4C:65:A8:D8:EB:E1', 'type': 'xiaomiht', 'name': 'xiaomiht', 'rssi': -72, 'source': 'local'}}}
[2023-02-25 10:01:09][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2023-02-25 10:01:09][DEBUG] : http://127.0.0.1:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2023-02-25 10:01:09][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 17): Address type changed during scan, for address 73:b3:1c:f0:55:85
[2023-02-25 10:01:09][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 18): Address type changed during scan, for address 5e:77:2e:7a:da:79
[2023-02-25 10:01:10][DEBUG] : No name in data but i know it is : miflora
[2023-02-25 10:01:10][DEBUG] : SCANNER------This is a miflora device c4:7c:8d:6a:05:b4
[2023-02-25 10:01:10][DEBUG] : Xiaomi Flower Care PARSE data: 95fe712098009cb4056a8d7cc40d0710031b0000
[2023-02-25 10:01:10][DEBUG] : XiaomiFlower------ Advertising Data=> Illuminance: 27
[2023-02-25 10:01:10][DEBUG] : {'present': 1, 'sunlight': 27, 'id': 'C4:7C:8D:6A:05:B4', 'type': 'miflora', 'name': 'miflora', 'rssi': -78, 'source': 'local'}
[2023-02-25 10:01:10][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 19): Address type changed during scan, for address 5e:77:2e:7a:da:79
[2023-02-25 10:01:10][INFO] : Send to jeedom : {'devices': {'C4:7C:8D:6A:05:B4': {'present': 1, 'sunlight': 27, 'id': 'C4:7C:8D:6A:05:B4', 'type': 'miflora', 'name': 'miflora', 'rssi': -78, 'source': 'local'}}}
[2023-02-25 10:01:10][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2023-02-25 10:01:10][DEBUG] : http://127.0.0.1:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2023-02-25 10:01:10][WARNING] : GLOBAL------Exception on scanner (trying to resolve by myself 20): Address type changed during scan, for address 5e:77:2e:7a:da:79
[2023-02-25 10:01:11][ERROR] : GLOBAL------Exception on scanner (didn't resolve there is an issue with bluetooth) : Address type changed during scan, for address 73:b3:1c:f0:55:85
[2023-02-25 10:01:11][INFO] : GLOBAL------Shutting down due to errors
[2023-02-25 10:01:11][INFO] : Send to jeedom : {'learn_mode': 0, 'source': 'local'}
[2023-02-25 10:01:11][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2023-02-25 10:01:11][DEBUG] : http://127.0.0.1:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2023-02-25 10:01:13][DEBUG] : GLOBAL------Shutdown
[2023-02-25 10:01:13][DEBUG] : GLOBAL------Removing PID file /tmp/jeedom/blea/deamon.pid
[2023-02-25 10:01:13][DEBUG] : GLOBAL------Closing all potential bluetooth connection
[2023-02-25 10:01:13][INFO] : LoopNetServer Thread stopped
[2023-02-25 10:01:13][DEBUG] : Exit 0
Log complet
blea_local.txt (42,0 Ko)
Avec la modif de @Mips
[2023-02-25 10:17:39][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2023-02-25 10:17:39][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2023-02-25 10:17:39][DEBUG] : SOCKET-READ------Add device : {'id': 'FF:FF:94:03:C1:D3', 'delay': 0, 'needsrefresh': 0, 'name': 'nut', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'nut/nut'}
[2023-02-25 10:17:39][DEBUG] : SOCKET-READ------Add device : {'id': 'CB:F3:45:77:36:8F', 'delay': 0, 'needsrefresh': 0, 'name': 'nut', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'nut/nut'}
[2023-02-25 10:17:39][DEBUG] : SOCKET-READ------Add device : {'id': 'F6:E9:FC:F6:D7:88', 'delay': 0, 'needsrefresh': 0, 'name': 'nut', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'nut/nut'}
[2023-02-25 10:17:39][DEBUG] : SOCKET-READ------Add device : {'id': 'C4:7C:8D:6B:01:09', 'delay': 18000, 'needsrefresh': 1, 'name': 'miflora', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'miflora/miflora'}
[2023-02-25 10:17:40][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2023-02-25 10:17:40][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2023-02-25 10:17:40][DEBUG] : SOCKET-READ------Add device : {'id': '80:EA:CA:88:B4:62', 'delay': 18000, 'needsrefresh': 1, 'name': 'miflora', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'miflora/miflora'}
[2023-02-25 10:17:40][DEBUG] : SOCKET-READ------Add device : {'id': 'C4:7C:8D:6A:05:B4', 'delay': 18000, 'needsrefresh': 1, 'name': 'miflora', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'miflora/miflora'}
[2023-02-25 10:17:40][DEBUG] : SOCKET-READ------Add device : {'id': 'C4:7C:8D:6A:10:E3', 'delay': 18000, 'needsrefresh': 1, 'name': 'miflora', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'miflora/miflora'}
[2023-02-25 10:17:41][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2023-02-25 10:17:41][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2023-02-25 10:17:41][DEBUG] : SOCKET-READ------Add device : {'id': '4C:65:A8:D8:EB:E1', 'delay': 1800, 'needsrefresh': 0, 'name': 'xiaomiht', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'xiaomiht/xiaomiht'}
[2023-02-25 10:17:41][DEBUG] : SOCKET-READ------Add device : {'id': '4C:65:A8:D1:20:C4', 'delay': 1800, 'needsrefresh': 0, 'name': 'xiaomiht', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'xiaomiht/xiaomiht'}
[2023-02-25 10:17:41][DEBUG] : SOCKET-READ------Add device : {'id': '58:2D:34:32:A4:AF', 'delay': 1800, 'needsrefresh': 0, 'name': 'xiaomiht', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'xiaomiht/xiaomiht'}
[2023-02-25 10:17:42][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2023-02-25 10:17:42][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2023-02-25 10:17:42][DEBUG] : SOCKET-READ------Add device : {'id': '4C:65:A8:DC:90:A3', 'delay': 1800, 'needsrefresh': 0, 'name': 'xiaomiht', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'xiaomiht/xiaomiht'}
[2023-02-25 10:17:42][DEBUG] : SOCKET-READ------Add device : {'id': '4C:65:A8:DC:B2:71', 'delay': 1800, 'needsrefresh': 0, 'name': 'xiaomiht', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'xiaomiht/xiaomiht'}
[2023-02-25 10:17:42][DEBUG] : SOCKET-READ------Received command from jeedom : ready
[2023-02-25 10:17:42][DEBUG] : Daemon is ready
[2023-02-25 10:17:42][DEBUG] : SCANNER------[(255, 'Manufacturer', '4c0002151ca92e23f0874df7b9a2fd4b716a4bf600a8000003')] True random 5d:14:3d:a8:31:01
[2023-02-25 10:17:42][DEBUG] : SCANNER------It's an unknown packet but not sent because this device is not Included and I'am not in learn mode 5d:14:3d:a8:31:01
[2023-02-25 10:17:42][DEBUG] : SCANNER------[(1, 'Flags', '1a'), (10, 'Tx Power', '07'), (255, 'Manufacturer', '4c001007341f28c9d3a728')] True random 49:5d:e1:f5:f2:91
[2023-02-25 10:17:42][DEBUG] : SCANNER------It's an unknown packet but not sent because this device is not Included and I'am not in learn mode 49:5d:e1:f5:f2:91
[2023-02-25 10:17:42][DEBUG] : SCANNER------[(1, 'Flags', '02'), (3, 'Complete 16b Services', '0000fea0-0000-1000-8000-00805f9b34fb'), (22, '16b Service Data', 'a0fe03fa8fca895a5f612020201eff')] True random 7e:8c:d5:f3:b6:bf
[2023-02-25 10:17:42][DEBUG] : SCANNER------It's an unknown packet but not sent because this device is not Included and I'am not in learn mode 7e:8c:d5:f3:b6:bf
[2023-02-25 10:17:42][DEBUG] : SCANNER------[(255, 'Manufacturer', '4c0002151ca92e23f0874df7b9a2fd4b716a4bf600ab000003')] True random 5a:99:81:91:48:ba
[2023-02-25 10:17:42][DEBUG] : SCANNER------It's an unknown packet but not sent because this device is not Included and I'am not in learn mode 5a:99:81:91:48:ba
[2023-02-25 10:17:42][DEBUG] : SCANNER------[(255, 'Manufacturer', '4c0002151ca92e23f0874df7b9a2fd4b716a4bf600a7000003')] True random 60:a0:71:20:06:ac
[2023-02-25 10:17:42][DEBUG] : SCANNER------It's an unknown packet but not sent because this device is not Included and I'am not in learn mode 60:a0:71:20:06:ac
[2023-02-25 10:17:42][DEBUG] : SCANNER------[(255, 'Manufacturer', '4c0002151ca92e23f0874df7b9a2fd4b716a4bf600a4000003')] True random 73:b3:1c:f0:55:85
[2023-02-25 10:17:42][DEBUG] : SCANNER------It's an unknown packet but not sent because this device is not Included and I'am not in learn mode 73:b3:1c:f0:55:85
[2023-02-25 10:17:42][ERROR] : GLOBAL------Fatal error : name 'BtInternalError' is not defined
[2023-02-25 10:17:42][DEBUG] : Traceback (most recent call last):
File "/var/www/html/plugins/blea/resources/blead/blead.py", line 211, in listen
globals.SCANNER.process(0.3)
File "/usr/local/lib/python3.7/dist-packages/bluepy/btle.py", line 851, in process
isNewData = dev._update(resp)
File "/usr/local/lib/python3.7/dist-packages/bluepy/btle.py", line 707, in _update
raise BTLEInternalError("Address type changed during scan, for address %s" % self.addr)
bluepy.btle.BTLEInternalError: Address type changed during scan, for address 73:b3:1c:f0:55:85
During handling of the above exception, another exception occurred:
File "/var/www/html/plugins/blea/resources/blead/blead.py", line 590, in <module>
listen()
File "/var/www/html/plugins/blea/resources/blead/blead.py", line 216, in listen
except BtInternalError as e:
NameError: name 'BtInternalError' is not defined
[2023-02-25 10:17:42][DEBUG] : GLOBAL------Shutdown
[2023-02-25 10:17:42][DEBUG] : GLOBAL------Removing PID file /tmp/jeedom/blea/deamon.pid
[2023-02-25 10:17:42][DEBUG] : GLOBAL------Closing all potential bluetooth connection
[2023-02-25 10:17:43][INFO] : LoopNetServer Thread stopped
[2023-02-25 10:17:43][DEBUG] : Exit 0
Log complet
blea_local1.txt (23,4 Ko)
Je me posais aussi une question, est ce que cela n’aurait il pas un lien avec divoom comme j’ai pu le voir dans un autre sujet?
En tout cas merci pour vos propositions si cela n’a pas abouti
