Suite à mon message ici, je fais comme me l’a dit Olive, une demande d’intégration.
En résumé le retour d’état On Off ne fonctionne pas correctement, même allumée l’icone reste sous forme de croix (ou reste a l’état de prise quand c’est éteint et allumé). La remontée de puissance et de conso ne fonctionne pas.
Modèle ; Prise Tuya Lien vers la boutique (Désolé pas de numéro de modèle sur l’emballage
Information brutes
"ieee": "54:0f:57:ff:fe:65:d7:a1",
"nwk": 62854,
"status": 2,
"lqi": "232",
"rssi": "-42",
"last_seen": "1637474708.0542076",
"node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 266,
"profile_id": 260,
"manufacturer": "_TZ3000_cphmq0q7",
"model": "TS011F",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 69
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_cphmq0q7"
"id": 5,
"name": "model",
"value": "TS011F"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 1
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 1794,
"name": "Metering",
"attributes": [
"id": 0,
"name": "current_summ_delivered",
"value": 0
"id": 2820,
"name": "Electrical Measurement",
"attributes": [
"id": 1291,
"name": "active_power",
"value": 0
"id": 57344,
"name": "Cluster",
"attributes": []
"id": 57345,
"name": "Cluster",
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"model": "TS011F",
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 266,
"input_clusters": [
0,
3,
4,
5,
6,
1794,
2820,
57344,
57345
25,
10
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
Log zigbee en debug
2021-11-21 07:03:57][DEBUG] : http://127.0.0.1:8090/device/command type : PUT
[2021-11-21 07:03:57][DEBUG] : {"ieee":"54:0f:57:ff:fe:65:d7:a1","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-11-21 07:04:03][DEBUG] : http://127.0.0.1:8090/device/command type : PUT
[2021-11-21 07:04:03][DEBUG] : {"ieee":"54:0f:57:ff:fe:65:d7:a1","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-11-21 07:04:05][DEBUG] : {"devices":{"bc:33:ac:ff:fe:6d:7f:91":{"1":[{"1":{"value":"69","cluster_name":"Basic"}}]}}}
[2021-11-21 07:04:13][DEBUG] : http://127.0.0.1:8090/device/command type : PUT
[2021-11-21 07:04:13][DEBUG] : {"ieee":"54:0f:57:ff:fe:65:d7:a1","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-11-21 07:04:15][DEBUG] : http://127.0.0.1:8090/device/command type : PUT
[2021-11-21 07:04:15][DEBUG] : {"ieee":"54:0f:57:ff:fe:65:d7:a1","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-11-21 07:05:04][DEBUG] : http://127.0.0.1:8090/device/command type : PUT
[2021-11-21 07:05:04][DEBUG] : {"ieee":"54:0f:57:ff:fe:65:d7:a1","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-11-21 07:05:05][DEBUG] : {"devices":{"84:2e:14:ff:fe:1b:a2:22":{"1":[{"1":{"value":"80","cluster_name":"Basic"}}]}}}
[2021-11-21 07:05:07][DEBUG] : http://127.0.0.1:8090/device/command type : PUT
[2021-11-21 07:05:07][DEBUG] : {"ieee":"54:0f:57:ff:fe:65:d7:a1","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
L’image avec fond transparent
Merci d’avance de ce que vous pourrez faire.
