Serait-il possible de rajouter ce model d’interrupteur pour volet.
Il est fonctionnel mais n’affiche pas la bonne photo
Voici les données brut.
"ieee": "00:0d:6f:ff:fe:b0:20:45",
"nwk": 1074,
"status": 2,
"lqi": "126",
"rssi": "0",
"last_seen": "1637016345.7439754",
"node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 514,
"profile_id": 260,
"manufacturer": "_TZ3000_8kzqqzu4",
"model": "TS130F",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 68
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_8kzqqzu4"
"id": 5,
"name": "model",
"value": "TS130F"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 1
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"id": 6,
"name": "TuyaWithBacklightOnOffCluster",
"attributes": [
"id": 32769,
"name": "backlight_mode",
"value": 0
"id": 258,
"name": "Window Covering",
"attributes": [
"id": 8,
"name": "current_position_lift_percentage",
"value": 0
"id": 61440,
"name": "tuya_moving_state",
"value": 1
"id": 61441,
"name": "calibration",
"value": 1
"id": 61442,
"name": "motor_reversal",
"value": 0
"id": 61443,
"name": "calibration_time",
"value": 100
"signature": {
"model": "TS130F",
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 514,
"input_clusters": [
0,
4,
5,
10,
6,
258
25
"class": "zhaquirks.tuya.ts130f"
Voici le log « zigbee ».
[2021-11-15 23:50:22][DEBUG] : {"devices":{"00:0d:6f:ff:fe:b0:20:45":{"1":{"258":{"8":{"value":"0","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x02","cluster_name":"Window Covering"}}}}}}
[2021-11-15 23:50:22][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::8 => 0 convert to 0
[2021-11-15 23:50:22][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::61440 => enum8.undefined_0x02 convert to 2
[2021-11-15 23:50:32][DEBUG] : {"devices":{"00:0d:6f:ff:fe:b0:20:45":{"1":{"258":{"8":{"value":"100","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x01","cluster_name":"Window Covering"}}}}}}
[2021-11-15 23:50:32][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::8 => 100 convert to 100
[2021-11-15 23:50:32][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::61440 => enum8.undefined_0x01 convert to 1
[2021-11-15 23:50:36][DEBUG] : {"devices":{"00:0d:6f:ff:fe:b0:20:45":{"1":{"258":{"8":{"value":"100","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x00","cluster_name":"Window Covering"}}}}}}
[2021-11-15 23:50:36][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::8 => 100 convert to 100
[2021-11-15 23:50:36][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::61440 => enum8.undefined_0x00 convert to 0
[2021-11-15 23:50:46][DEBUG] : {"devices":{"00:0d:6f:ff:fe:b0:20:45":{"1":{"258":{"8":{"value":"0","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x01","cluster_name":"Window Covering"}}}}}}
[2021-11-15 23:50:46][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::8 => 0 convert to 0
[2021-11-15 23:50:46][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::61440 => enum8.undefined_0x01 convert to 1
[2021-11-15 23:50:48][DEBUG] : {"devices":{"00:0d:6f:ff:fe:b0:20:45":{"1":{"258":{"8":{"value":"0","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x02","cluster_name":"Window Covering"}}}}}}
[2021-11-15 23:50:48][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::8 => 0 convert to 0
[2021-11-15 23:50:48][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::61440 => enum8.undefined_0x02 convert to 2
[2021-11-15 23:50:49][DEBUG] : {"devices":{"00:0d:6f:ff:fe:b0:20:45":{"1":{"258":{"8":{"value":"9","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x01","cluster_name":"Window Covering"}}}}}}
[2021-11-15 23:50:49][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::8 => 9 convert to 9
[2021-11-15 23:50:49][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::61440 => enum8.undefined_0x01 convert to 1
[2021-11-15 23:50:50][DEBUG] : {"devices":{"00:0d:6f:ff:fe:b0:20:45":{"1":{"258":{"8":{"value":"9","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x00","cluster_name":"Window Covering"}}}}}}
[2021-11-15 23:50:50][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::8 => 9 convert to 9
[2021-11-15 23:50:50][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::61440 => enum8.undefined_0x00 convert to 0
[2021-11-15 23:50:51][DEBUG] : {"devices":{"54:0f:57:ff:fe:08:d2:83":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}],"1794":[{"value":"93","cluster_name":"TuyaZBMeteringCluster"}],"2820":{"1291":{"value":"0","cluster_name":"Electrical Measurement"}}}},"00:0d:6f:ff:fe:b0:20:45":{"1":{"258":{"8":{"value":"1","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x01","cluster_name":"Window Covering"}}}}}}
[2021-11-15 23:50:51][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::8 => 1 convert to 1
[2021-11-15 23:50:51][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::258::61440 => enum8.undefined_0x01 convert to 1
[2021-11-15 23:51:59][DEBUG] : {"devices":{"00:0d:6f:ff:fe:b0:20:45":{"1":[{"1":{"value":"68","cluster_name":"Basic"},"65506":{"value":"27","cluster_name":"Basic"}}]}}}
[2021-11-15 23:51:59][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::0::1 => 68 convert to 68
[2021-11-15 23:51:59][DEBUG] : Search attribut for 00:0d:6f:ff:fe:b0:20:45 logicalId : 1::0::65506 => 27 convert to 27
