Bonjour. depuis aujourdhui je n’ai plus les fonctions d’clairage via xiaomi home. Les capteurs fonctionnenet seul les interrupteurs ne fonctionne pas. je suis en version 3.3.24. et en version 4.1.22 pour jeedom. dans le log error j’ai ca
[2021-05-05 11:12:04.607][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:13:03.789][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:14:04.178][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:15:06.070][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:16:03.751][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:17:03.839][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:18:03.931][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:19:04.324][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:20:05.618][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:21:03.902][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:22:04.291][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:23:04.680][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:24:04.777][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
[2021-05-05 11:24:58.551][ERROR] : SOCKET-READ------Exception on socket : IV must be 16 bytes long
[2021-05-05 11:25:01.255][ERROR] : SOCKET-READ------Exception on socket : IV must be 16 bytes long
merci d avance pour votre aide
