Debian 12.5 Jeedom Alpha 4.4.2 Plugin RFXCOM Beta -> DEMON NOK
Test sur VM Synology avec Fresh install DEbian 12.5 et Jeedom Alpha 4.4.2 sur plugin RFXCOM beta
+ touch /tmp/jeedom_install_in_progress_rfxcom
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
Launch pre-install of rfxcom dependancy
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
If you wish to install a non-Debian packaged Python application,
it may be easiest to use pipx install xyz, which will manage a
virtual environment for you. Make sure you have pipx installed.
See /usr/share/doc/python3.11/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
Reading package lists...
Building dependency tree...
Reading state information...
Package 'python3-serial' is not installed, so not removed
The following package was automatically installed and is no longer required:
libre2-9
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
+ echo 3
+ sudo apt update
Hit:1 http://ftp.fr.debian.org/debian bookworm InRelease
Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
Hit:3 http://ftp.fr.debian.org/debian bookworm-updates InRelease
Hit:4 https://deb.nodesource.com/node_16.x bookworm InRelease
Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
All packages are up to date.
+ echo 4
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3
python3 is already the newest version (3.11.2-1+b1).
libre2-9
+ echo 5
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pip
python3-pip is already the newest version (23.0.1+dfsg-1).
libre2-9
+ echo 6
+ sudo apt install -o Dpkg::Options::=--force-confdef -y build-essential
libre2-9
+ echo 7
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pyudev
python3-pyudev is already the newest version (0.24.0-1).
libre2-9
+ echo 8
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-dev
python3-dev is already the newest version (3.11.2-1+b1).
libre2-9
+ echo 9
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-requests
python3-requests is already the newest version (2.28.1+dfsg-1).
libre2-9
+ echo 10
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-setuptools
python3-setuptools is already the newest version (66.1.1-1).
libre2-9
+ echo 11
+ sudo apt update
Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
Hit:2 http://ftp.fr.debian.org/debian bookworm InRelease
+ sudo apt install -y pipx
pipx is already the newest version (1.1.0-1).
libre2-9
+ echo 12
+ sudo pipx install --force-reinstall --upgrade six
usage: pipx [-h] [--version]
{install,inject,upgrade,upgrade-all,uninstall,uninstall-all,reinstall,reinstall-all,list,run,runpip,ensurepath,environment,completions}
pipx: error: unrecognized arguments: --force-reinstall --upgrade
+ echo 13
+ sudo pipx install --force-reinstall --upgrade requests
+ echo 14
+ sudo pipx install --force-reinstall --upgrade setuptools
+ echo 15
+ sudo pipx install --force-reinstall --upgrade pyudev
+ echo 16
+ sudo pipx install --force-reinstall --upgrade pyserial
+ echo 17
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end rfxcom
+ rm /tmp/jeedom_install_in_progress_rfxcom
je vois du pixp comme sur xiaomi, serait ce lié ?
oui Loic a fait une modif dans le core…
Pour rfxcom j’avais déjà signalé y a un moment…
Et je crois que tu peux laisser tomber les tests en debian 12…
ok en effet je vais arreter de perdre mon temps sur Debian 12 pourtant Loic avait demandé des tests a un moment.
Et pour le post RFCOM désolé je n’avais pas vu ce post et la réponse de Loic. Mais pour autant ce n’est pas une solution…
Le post est marqué comme résolu pour recentrer les discussions sur le sujet sur un même post, inutile d’avoir des doublons.
et l’autre post n’est pas résolu donc tout va bien
