oui IP fixe pour le Hub et j’arrive bien à le pinguer
Je viens de faire un rollback, plus de message de cron et ca reponds :
000|[2023-09-20 19:23:04]DEBUG : Sortie console : {"sequence": [], "global": {"locale": "en-US", "timeStampHash": "9b00f4b1-51af-4d43-95e3-92ad7a25ce9f36b48727-e9f7-4f3f-bf87-46adabb58d46/83f092eb-d5e8-4d89-92d5-711b9009d19bfdf53f33-896a-4ecc-80fc-d777e0cb1f7c6620247f-0704-4061-a7b5-5364d54ad1248838288hub+salonen-USmortyre@hotmail.comUSSilverlightWebClient02065866250False555192207europe%2fparisTrue8646247381;21b40876af3597fc483b281a5fb18fe4"}, "dataConsent": false, "content": {"contentServiceHost": "https://content.dhg.myharmony.com/1.0/Service/{providerId}", "contentUserHost": "https://content.dhg.myharmony.com/1.0/User;{userProfileUri}", "contentImageHost": "https://d1tk8oqnnsddt5.cloudfront.net/1.0/station/{stationId}/image;maxX=40;maxY=40", "householdUserProfileUri": "svcs.myharmony.com/res//household/4436063-8/daG36yqKagrr+P0ubxuU8WiWVDPBGO2OBQ7iiUMnU=/user/default", "contentDeviceHost": "https://content.dhg.myharmony.com/1.0/Device;{deviceProfileUri}"}, "activity": [{"activityOrder": 9, "enterActions": [], "baseImageUri": "https://rcbu-test-ssl-amr.s3.amazonaws.com/", "activityTypeDisplayName": "Default", "roles": {"ChannelChangingActivityRole": "36930490", "VolumeActivityRole": "71987077", "DisplayActivityRole": "63494863"}, "fixit": {"44575807": {"id": "44575807", "Power": "Off"}, "36930488": {"isRelativePower": true, "id": "36930488", "Power": "Off"}, "72747339": {"id": "72747339", "Power": "Off"}, "36930493": {"id": "36930493", "Power": "Off"}, "71987077": {"Input": "CBL/SAT", "id": "71987077", "Power": "On"}, "63494863": {"Input": "HDMI 3", "id": "63494863", "Power": "On"}, "45560926": {"isRelativeInput": true, "id": "45560926", "Power": "Off"}, "36930490": {"Input": "TV", "isRelativeInput": true, "isRelativePower": true, "id": "36930490", "Power": "On"}, "80151573": {"isRelativePower": true, "id": "80151573", "Power": "Off"}, "53551604": {"isRelativeInput": true, "id": "53551604", "Power": "Off"}}, "rules": [], "sequences": [], "isAVActivity": true, "label": "SATELLITE sur TV", "zones": null, "controlGroup": [{"function": [{"action": "{\"command\":\"0\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number0", "label": "0"}, {"action": "{\"command\":\"1\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number1", "label": "1"}, {"action": "{\"command\":\"2\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number2", "label": "2"}, {"action": "{\"command\":\"3\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number3", "label": "3"}, {"action": "{\"command\":\"4\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number4", "label": "4"}, {"action": "{\"command\":\"5\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number5", "label": "5"}, {"action": "{\"command\":\"6\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number6", "label": "6"}, {"action": "{\"command\":\"7\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number7", "label": "7"}, {"action": "{\"command\":\"8\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number8", "label": "8"}, {"action": "{\"command\":\"9\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number9", "label": "9"}], "name": "NumericBasic"}, {"function": [{"action": "{\"command\":\"Mute\",\"type\":\"IRCommand\",\"deviceId\":\"71987077\"}", "name": "Mute", "label": "Mute"}, {"action": "{\"command\":\"VolumeDown\",\"type\":\"IRCommand\",\"deviceId\":\"71987077\"}", "name": "VolumeDown", "label": "Volume Down"}, {"action": "{\"command\":\"VolumeUp\",\"type\":\"IRCommand\",\"deviceId\":\"71987077\"}", "name": "VolumeUp", "label": "Volume Up"}], "name": "Volume"}, {"function": [{"action": "{\"command\":\"ChannelPrev\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "PrevChannel", "label": "Prev Channel"}, {"action": "{\"command\":\"ChannelDown\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "ChannelDown", "label": "Channel Down"}, {"action": "{\"command\":\"ChannelUp\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "ChannelUp", "label": "Channel Up"}], "name": "Channel"}, {"function": [{"action": "{\"command\":\"DirectionDown\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "DirectionDown", "label": "Direction Down"}, {"action": "{\"command\":\"DirectionLeft\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "DirectionLeft", "label": "Direction Left"}, {"action": "{\"command\":\"DirectionRight\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "DirectionRight", "label": "Direction Right"}, {"action": "{\"command\":\"DirectionUp\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "DirectionUp", "label": "Direction Up"}, {"action": "{\"command\":\"OK\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Select", "label": "Select"}], "name": "NavigationBasic"}, {"function": [{"action": "{\"command\":\"Stop\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Stop", "label": "Stop"}, {"action": "{\"command\":\"Play\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Play", "label": "Play"}, {"action": "{\"command\":\"Rewind\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Rewind", "label": "Rewind"}, {"action": "{\"command\":\"Pause\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Pause", "label": "Pause"}, {"action": "{\"command\":\"FastForward\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "FastForward", "label": "Fast Forward"}], "name": "TransportBasic"}, {"function": [{"action": "{\"command\":\"Record\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Record", "label": "Record"}], "name": "TransportRecording"}, {"function": [{"action": "{\"command\":\"SkipBack\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "SkipBackward", "label": "Skip Backward"}, {"action": "{\"command\":\"SkipForward\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "SkipForward", "label": "Skip Forward"}], "name": "TransportExtended"}, {"function": [{"action": "{\"command\":\"Menu\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Menu", "label": "Menu"}, {"action": "{\"command\":\"Back\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Back", "label": "Back"}], "name": "NavigationDVD"}, {"function": [{"action": "{\"command\":\"Favorite\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Favorite", "label": "Favorite"}], "name": "NavigationDSTB"}, {"function": [{"action": "{\"command\":\"OK\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "SelectGame", "label": "Select"}], "name": "GameType3"}, {"function": [{"action": "{\"command\":\"Epg\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Guide", "label": "Guide"}, {"action": "{\"command\":\"Info\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Info", "label": "Info"}, {"action": "{\"command\":\"Exit\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Exit", "label": "Exit"}], "name": "NavigationExtended"}, {"function": [{"action": "{\"command\":\"Sleep\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Sleep", "label": "Sleep"}], "name": "Setup"}, {"function": [{"action": "{\"command\":\"Green\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Green", "label": "Green"}, {"action": "{\"command\":\"Red\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Red", "label": "Red"}, {"action": "{\"command\":\"Blue\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Blue", "label": "Blue"}, {"action": "{\"command\":\"Yellow\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Yellow", "label": "Yellow"}], "name": "ColoredButtons"}, {"function": [{"action": "{\"command\":\"Teletext\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Teletext", "label": "Teletext"}], "name": "Teletext"}], "imageKey": "Activity/A648AC27-8B04-4CAD-A2B2-82A83BCDB741.png", "suggestedDisplay": "WatchTV", "VolumeActivityRole": "71987077", "isTuningDefault": false, "type": "VirtualTelevisionN", "id": "20735269", "isMultiZone": false, "icon": "userdata: 0x4454c8"}, {"activityOrder": 8, "enterActions": [{"name": "SendCommand", "parameters": {"Modifier": "press", "Command": "directiondown", "DeviceId": "36930493"}}], "activityTypeDisplayName": "Default", "roles": {"PassThroughActivityRole": "36930493", "PlayMovieActivityRole": "36930490", "ChannelChangingActivityRole": "36930490", "VolumeActivityRole": "71987077", "DisplayActivityRole": "53551604", "PlayMediaActivityRole": "71987077"}, "fixit": {"44575807": {"id": "44575807", "Power": "Off"}, "36930488": {"isRelativePower": true, "id": "36930488", "Power": "Off"}, "72747339": {"id": "72747339", "Power": "Off"}, "36930493": {"id": "36930493", "Power": "On"}, "71987077": {"Input": "CBL/SAT", "id": "71987077", "Power": "On"}, "63494863": {"id": "63494863", "Power": "Off"}, "45560926": {"isRelativeInput": true, "id": "45560926", "Power": "Off"}, "36930490": {"Input": "TV", "isRelativeInput": true, "isRelativePower": true, "id": "36930490", "Power": "On"}, "80151573": {"isRelativePower": true, "id": "80151573", "Power": "Off"}, "53551604": {"Input": "HDMI 2", "isRelativeInput": true, "id": "53551604", "Power": "On"}}, "rules": [], "sequences": [], "isAVActivity": true, "label": "Satellite sur Projo", "zones": null, "controlGroup": [{"function": [{"action": "{\"command\":\"0\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number0", "label": "0"}, {"action": "{\"command\":\"1\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number1", "label": "1"}, {"action": "{\"command\":\"2\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number2", "label": "2"}, {"action": "{\"command\":\"3\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number3", "label": "3"}, {"action": "{\"command\":\"4\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number4", "label": "4"}, {"action": "{\"command\":\"5\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number5", "label": "5"}, {"action": "{\"command\":\"6\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number6", "label": "6"}, {"action": "{\"command\":\"7\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number7", "label": "7"}, {"action": "{\"command\":\"8\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number8", "label": "8"}, {"action": "{\"command\":\"9\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Number9", "label": "9"}], "name": "NumericBasic"}, {"function": [{"action": "{\"command\":\"Mute\",\"type\":\"IRCommand\",\"deviceId\":\"71987077\"}", "name": "Mute", "label": "Mute"}, {"action": "{\"command\":\"VolumeDown\",\"type\":\"IRCommand\",\"deviceId\":\"71987077\"}", "name": "VolumeDown", "label": "Volume Down"}, {"action": "{\"command\":\"VolumeUp\",\"type\":\"IRCommand\",\"deviceId\":\"71987077\"}", "name": "VolumeUp", "label": "Volume Up"}], "name": "Volume"}, {"function": [{"action": "{\"command\":\"ChannelPrev\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "PrevChannel", "label": "Prev Channel"}, {"action": "{\"command\":\"ChannelDown\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "ChannelDown", "label": "Channel Down"}, {"action": "{\"command\":\"ChannelUp\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "ChannelUp", "label": "Channel Up"}], "name": "Channel"}, {"function": [{"action": "{\"command\":\"DirectionDown\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "DirectionDown", "label": "Direction Down"}, {"action": "{\"command\":\"DirectionLeft\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "DirectionLeft", "label": "Direction Left"}, {"action": "{\"command\":\"DirectionRight\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "DirectionRight", "label": "Direction Right"}, {"action": "{\"command\":\"DirectionUp\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "DirectionUp", "label": "Direction Up"}, {"action": "{\"command\":\"OK\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Select", "label": "Select"}], "name": "NavigationBasic"}, {"function": [{"action": "{\"command\":\"Stop\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Stop", "label": "Stop"}, {"action": "{\"command\":\"Play\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Play", "label": "Play"}, {"action": "{\"command\":\"Rewind\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Rewind", "label": "Rewind"}, {"action": "{\"command\":\"Pause\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Pause", "label": "Pause"}, {"action": "{\"command\":\"FastForward\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "FastForward", "label": "Fast Forward"}], "name": "TransportBasic"}, {"function": [{"action": "{\"command\":\"Record\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Record", "label": "Record"}], "name": "TransportRecording"}, {"function": [{"action": "{\"command\":\"SkipBack\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "SkipBackward", "label": "Skip Backward"}, {"action": "{\"command\":\"SkipForward\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "SkipForward", "label": "Skip Forward"}], "name": "TransportExtended"}, {"function": [{"action": "{\"command\":\"Menu\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Menu", "label": "Menu"}, {"action": "{\"command\":\"Back\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Back", "label": "Back"}], "name": "NavigationDVD"}, {"function": [{"action": "{\"command\":\"Favorite\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Favorite", "label": "Favorite"}], "name": "NavigationDSTB"}, {"function": [{"action": "{\"command\":\"OK\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "SelectGame", "label": "Select"}], "name": "GameType3"}, {"function": [{"action": "{\"command\":\"Epg\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Guide", "label": "Guide"}, {"action": "{\"command\":\"Info\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Info", "label": "Info"}, {"action": "{\"command\":\"Exit\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Exit", "label": "Exit"}], "name": "NavigationExtended"}, {"function": [{"action": "{\"command\":\"Ratio\",\"type\":\"IRCommand\",\"deviceId\":\"53551604\"}", "name": "Aspect", "label": "Aspect"}], "name": "DisplayMode"}, {"function": [{"action": "{\"command\":\"Sleep\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Sleep", "label": "Sleep"}], "name": "Setup"}, {"function": [{"action": "{\"command\":\"Green\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Green", "label": "Green"}, {"action": "{\"command\":\"Red\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Red", "label": "Red"}, {"action": "{\"command\":\"Blue\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Blue", "label": "Blue"}, {"action": "{\"command\":\"Yellow\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Yellow", "label": "Yellow"}], "name": "ColoredButtons"}, {"function": [{"action": "{\"command\":\"Teletext\",\"type\":\"IRCommand\",\"deviceId\":\"36930490\"}", "name": "Teletext", "label": "Teletext"}], "name": "Teletext"}], "suggestedDisplay": "Custom", "baseImageUri": "https://rcbu-test-ssl-amr.s3.amazonaws.com/", "isTuningDefault": false, "icon": "userdata: 0x4454c8", "type": "VirtualGeneric", "id": "32836967", "isMultiZone": false, "VolumeActivityRole": "71987077"}, {"activityOrder": 7, "enterActions": [], "baseImageUri": "https://rcbu-test-ssl-amr.s3.amazonaws.com/", "activityTypeDisplayName": "Default", "roles": {"VolumeActivityRole": "72747339", "PlayMediaActivityRole": "72747339"}, "fixit": {"44575807": {"id": "44575807", "Power": "Off"}, "36930488": {"isRelativePower": true, "id": "36930488", "Power": "Off"}, "72747339": {"Input": "Spotify", "id": "72747339", "Power": "On"}, "36930493": {"id": "36930493", "Power": "Off"}, "71987077": {"id": "71987077", "Power": "Off"}, "63494863": {"id": "63494863", "Power": "Off"}, "45560926": {"isRelativeInput": true, "id": "45560926", "Power": "Off"}, "36930490": {"isRelativeInput": true, "isRelativePower": true, "id": "36930490", "Power": "Off"}, "80151573": {"isRelativePower": true, "id": "80151573", "Power": "Off"}, "53551604": {"isRelativeInput": true, "id": "53551604", "Power": "Off"}}, "rules": [], "sequences": [], "isAVActivity": true, "label": "v\u00e9randa", "zones": null, "controlGroup": [{"function": [{"action": "{\"command\":\"0\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "Number0", "label": "0"}, {"action": "{\"command\":\"1\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "Number1", "label": "1"}, {"action": "{\"command\":\"2\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "Number2", "label": "2"}, {"action": "{\"command\":\"3\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "Number3", "label": "3"}, {"action": "{\"command\":\"4\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "Number4", "label": "4"}, {"action": "{\"command\":\"5\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "Number5", "label": "5"}, {"action": "{\"command\":\"6\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "Number6", "label": "6"}, {"action": "{\"command\":\"7\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "Number7", "label": "7"}, {"action": "{\"command\":\"8\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "Number8", "label": "8"}, {"action": "{\"command\":\"9\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "Number9", "label": "9"}], "name": "NumericBasic"}, {"function": [{"action": "{\"command\":\"Mute\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "Mute", "label": "Mute"}, {"action": "{\"command\":\"VolumeDown\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "VolumeDown", "label": "Volume Down"}, {"action": "{\"command\":\"VolumeUp\",\"type\":\"IRCommand\",\"deviceId\":\"72747339\"}", "name": "VolumeUp", "label": "Volume Up"}], "name": "Volume"}], "imageKey": "Activity/311D40B5-6CF9-4DA2-8820-E17012B852A1.png", "suggestedDisplay": "ListenToMusic", "VolumeActivityRole": "72747339", "isTuningDefault": false, "type": "VirtualCdMulti", "id": "21717930", "isMultiZone": false, "icon": "userdata: 0x4454c8"}, {"activityOrder": 11, "enterActions": [{"name": "SendCommand", "parameters": {"Modifier": "press", "Command": "directiondown", "DeviceId": "36930493"}}], "baseImageUri": "https://rcbu-test-ssl-amr.s3.amazonaws.com/", "activityTypeDisplayName": "Default", "roles": {"PassThroughActivityRole": "36930493", "VolumeActivityRole": "71987077", "PlayMovieActivityRole": "45560926", "DisplayActivityRole": "53551604"}, "fixit": {"44575807": {"id": "44575807", "Power": "Off"}, "36930488": {"isRelativePower": true, "id": "36930488", "Power": "Off"}, "72747339": {"id": "72747339", "Power": "Off"}, "36930493": {"id": "36930493", "Power": "On"}, "71987077": {"Input": "Blu-ray", "id": "71987077", "Power": "On"}, "63494863": {"Input": "SmartHub", "id": "63494863", "Power": "Off"}, "45560926": {"Input": "Bluray Player", "isRelativeInput": true, "id": "45560926", "Power": "On"}, "36930490": {"isRelativeInput": true, "isRelativePower": true, "id": "36930490", "Power": "Off"}, "80151573": {"isRelativePower": true, "id": "80151573", "Power": "Off"}, "53551604": {"Input": "HDMI 2", "isRelativeInput": true, "id": "53551604", "Power": "On"}}, "rules": [], "sequences": [], "isAVActivity": true, "label": "Oppo sur projo", "zones": null, "controlGroup": [{"function": [{"action": "{\"command\":\"0\",\"type\":\"IRCommand\",\"deviceId\":\"45560926\"}", "name": "Number0", "label": "0"}, {"action": "{\"command\":\"1\",\"type\":\"IRCommand\",\"deviceId\":\"45560926\"}", "name": "Number1", "label": "1"}, {"action": "
