Nouveau crash du plugin , il semble que ce sit l’ensemble des ports USB qui tombe :
[120561.867879] usb 1-1.4: new high-speed USB device number 120 using dwc_otg
[120561.969266] usb 1-1.4: New USB device found, idVendor=12d1, idProduct=1f01, bcdDevice= 1.02
[120561.969286] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[120561.969297] usb 1-1.4: Product: HUAWEI Mobile
[120561.969351] usb 1-1.4: Manufacturer: HUAWEI
[120561.969361] usb 1-1.4: SerialNumber: FFFFFFFFFFFFFFFF
[120562.018005] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[120562.021056] scsi host0: usb-storage 1-1.4:1.0
[120562.929677] usb 1-1.4: USB disconnect, device number 120
[120564.431867] usb 1-1.4: new high-speed USB device number 121 using dwc_otg
[120564.533085] usb 1-1.4: New USB device found, idVendor=12d1, idProduct=1001, bcdDevice= 1.02
[120564.533104] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[120564.533115] usb 1-1.4: Product: HUAWEI Mobile
[120564.533125] usb 1-1.4: Manufacturer: HUAWEI
[120564.797910] option 1-1.4:1.0: GSM modem (1-port) converter detected
[120564.798377] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB2
[120564.798843] option 1-1.4:1.1: GSM modem (1-port) converter detected
[120564.799165] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB3
[120564.799684] option 1-1.4:1.2: GSM modem (1-port) converter detected
[120564.800787] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB4
[120643.120722] usb usb1-port1: disabled by hub (EMI?), re-enabling...
[120643.120759] usb 1-1: USB disconnect, device number 113
[120643.120774] usb 1-1.1: USB disconnect, device number 114
[120643.121557] WARN::dwc_otg_hcd_urb_dequeue:639: Timed out waiting for FSM NP transfer to complete on 5
[120643.121587] smsc95xx 1-1.1:1.0 eth0: unregister 'smsc95xx' usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet
[120643.121844] smsc95xx 1-1.1:1.0 eth0: Link is Down
[120643.121868] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -19
[120643.121878] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[120643.121889] smsc95xx 1-1.1:1.0 eth0: __smsc95xx_mdio_read: MII is busy
[120643.121925] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -19
[120643.121936] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[120643.121946] smsc95xx 1-1.1:1.0 eth0: __smsc95xx_mdio_read: MII is busy
[120643.121982] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[120643.146174] usb 1-1.2: USB disconnect, device number 115
[120643.150459] usb 1-1.3: USB disconnect, device number 116
[120643.150487] usb 1-1.3.1: USB disconnect, device number 117
[120643.151163] WARN::dwc_otg_hcd_urb_dequeue:639: Timed out waiting for FSM NP transfer to complete on 0
[120643.151294] usb 1-1.3.1: failed to send control message: -19
[120643.151856] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[120643.151938] ch341 1-1.3.1:1.0: device disconnected
[120643.152749] usb 1-1.3.2: USB disconnect, device number 119
[120643.158626] ftdi_sio ttyUSB1: FTDI USB Serial Device converter now disconnected from ttyUSB1
[120643.158765] ftdi_sio 1-1.3.2:1.0: device disconnected
[120643.160491] usb 1-1.4: USB disconnect, device number 121
[120643.162373] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[120643.162507] option 1-1.4:1.0: device disconnected
[120643.163362] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[120643.163492] option 1-1.4:1.1: device disconnected
[120643.165736] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
[120643.165879] option 1-1.4:1.2: device disconnected
[120643.166652] usb 1-1.5: USB disconnect, device number 118
[120643.316880] Indeed it is in host mode hprt0 = 00001501
[120643.504682] usb 1-1: new high-speed USB device number 122 using dwc_otg
[120643.504892] Indeed it is in host mode hprt0 = 00001101
[120643.716871] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[120643.716891] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[120643.717662] hub 1-1:1.0: USB hub found
[120643.717778] hub 1-1:1.0: 5 ports detected
[120644.004563] usb 1-1.1: new high-speed USB device number 123 using dwc_otg
[120644.104885] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[120644.104904] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[120644.107824] smsc95xx v2.0.0
[120644.158632] libphy: smsc95xx-mdiobus: probed
[120644.160204] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c4:3d:97
[120644.384576] usb 1-1.2: new full-speed USB device number 124 using dwc_otg
[120644.494293] usb 1-1.2: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=82.41
[120644.494312] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[120644.499752] Bluetooth: hci0: unexpected event for opcode 0x0000
[120644.580579] usb 1-1.3: new high-speed USB device number 125 using dwc_otg
[120644.683190] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.26
[120644.683211] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[120644.683222] usb 1-1.3: Product: USB2.0 Hub
[120644.683232] usb 1-1.3: Manufacturer: GenesysLogic
je continue de chercher !
Didier DANEL
